Question about Toyota Vehicle Parts & Accessories
How to put the prestige aps25ch 1200 foot range in valet mode
How do you put the prestige aps25ch 1200 foot range car alarm in valet mode to prevent the alarm from going off in stormy weather
    Problem Solver:
  • 11 Answers
ALRMM SHOULDN'T GO OFF IN STORMY WEATHER UNLESS U GOT A LEAK SOMEWHERE OR YOUR SENSOR IS TO SENSITIVE
Posted on Jul 26, 2010
Underneath the dashboard on the left side there is a metal on/off switch that sits next to your left foot. The car had di. today and when trying to jump it (get it going again) the cars alarm started...
After market alarm or remote start. Every time I find them on a car with a security or electrical problem, I tear them out. Fixes the problem 99% of the time.
Mar 10, 2015 | Toyota Cars & Trucks
Alarm remote not functioning properly, no valet switch.
i would think the button is activating the fob, or when you put new battery in is it the right way or you may have pushed something inside and its come lose off the board, it would need opening up and having a look, and testing the switch.
Jun 10, 2017 | Audiovox Prestige Code Alarm Remote Alarm...
I lost remotes,how do i bypass alarm?
Locate the valet/override switch. You may have a push button LED or, it may be located under the drivers side of dash. Turn igniton on press and release push to manually override alarm. Turn ignition off then, back on. Press and hold push button for approximately 5 seconds to put alarm in valet.
Jul 18, 2012 | Car APS25CH Prestige 2 Button Remote...
How to disable or reset a Prestige car alarm. Purchased a used car with an after market Prestige alarm installed. Alarm somehow tripped and shut off the ability to start the car. I can't find a valet...
The valet switch,on the newer Prestige alarms, is a push button LED or, it's incorporated into the antenna. In both cases, turn the key to the on position, then press and release the valet switch. The alarm will respond with two chirps confirming that it is disarmed. You may now start the vehicle. After you successfully disarmed the alarm, turn the key to on position, press and hold the valet switch for approximately 5 seconds, the LED will come on solid. Turn the key off.The alarm is now in valet. You can take it out of valet in the same manner.
Oct 28, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
I have a audiovox car alarm model as-9490-4p how can i hook it up?
GO TO:
TECHSERVICES.AUDIOVOX.COM
DO NOT PUT WWW IN FRONT.
REGISTER
THEN CHOOSE TECH DOCUMENTS FOR YOUR MODEL.
Nov 28, 2009 | Car APS25CH Prestige 2 Button Remote...
The alarm wont let my car start. i turn the key and now response. how do i get the engune out of sleep
look for your valet switch. It should be under the dash(a little red button). put the key in the ignition, turn all the way until the instrument cluster lights on, then press on the valet switch for a couple of seconds until you hear the alarm chirp. You're now in valet mode and it should be ok to start the cart.
Oct 28, 2009 | Audiovox Prestige Code Alarm Remote Alarm...
My audiovox prestige alarm only does slient. How do I get it back to chirping ? model # aps02bt2
Simple....
1st turn the ignition key on than off
2nd within 10 seconds press and release the valet button switch 3 times.
If you did it right you will hear 1 chirp to indicatate the chirps are back to irritate and ******** all your neighbors.. just kidding. good luck
Jul 31, 2009 | Car APS02BT2 Transmitter for...
How do I disarm a audiovox prestige car alarm?
Locate the valet/override switch (button), (if you can't locate it, try tracing the wires under the dash from the main unit, usually a black and gray or black and red set of wires). Turn key to "RUN" position then press the button, the alarm's LED should light up solid at this time indicating valet mode as been set.
Jun 14, 2009 | APS20B Prestige Keyless Remote Alarm
The car arms but the alarm does not chirp
try turning your key on and flip the valet switch, your alarm is most likely in valet mode (youll know cause the led stays on) if that doesnt work, turn the key on and off then toggle thye valet switch 3x and that'll turn off silent mode. Good luck, Martin @ lessco electronics
Feb 25, 2009 | Car APS25CH Prestige 2 Button Remote...
Vehicle Parts & Accessories Logo
266 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
ashburton
Colin Stickland
Colin Stickland
jamie suver
Level 1 Expert
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
