Question about Garden
We have a Sears sump pump back up with no manual. How do we find one. Looked on line but did not have any luck. Can you help us?
  • 3,600 Answers
You can order one from sears from thier 800 number parts store but will cost you since you did not give the size or model number I can't look it up for you. reply to this with model number and I wll get it for you.
Posted on Jul 04, 2010
Kubota M 5030 2.8 6 cyl. Diesel in oil sump. Why?
Diesel gets in the sump from an seal leaking in the fuel pump through to the drive gear and out into the sump. If it has an inline pump( one where the injector lines are in a row at the top of the pump) the fuel will be leaking past the plunger elements and into the pump sump which then drains back tot he engine sump. IF it is slight but consistent sometimes injectors will dribble when shut down and the fuel will by pass the piston rings into the sump. Talk with a diesel pump and injector repair specialist for any faults particular to the Kubota fuel system
Apr 03, 2013 | Cars & Trucks
Tip
Sears kenmore he2 front load pump filter maintenance
Kenmore HE2 front loader. We had a problem with all the cycle lights blinking. I took that access cover off and found 4 years of lint and muck with a few fabric items in that sump. There is also a second troubleshooting manual taped to the back of the access door. after cleaning the pump filter it worked fine. This should be in the owners manual but its not, they say to call the service guy and be charged an arm and a leg
on May 09, 2010 | Washing Machines
Need a parts manual for this washer, it is leaking from the bottom
Could be a Tub Seal, or leak from Sump Cap to Drain Pump/Drain line.
You need to remove front cover and inspect. Follow saftey warnings in the Service Manual
The Service Manual for reference. Sears Parts Direct for reference.
Aug 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water will not drain
Here is the Service Manual for reference. Sears Parts Direct for reference.
What makes you say the drain pump/line is clogged? Have you taken an error code to the display of ND for no drain? Is the machine is a FAV6800A or FAV9800A?
Is the machine failing in spin cycle of the wash cycle?
Can you supply more info regarding your no drain issue?
If there is a drain line/pump clog we would start at the Sump Cap disconnect the drain line from it and inspect the Sump Cap for debris. We would have to check if the input hose is blocked or the impeller of the drain pump blocked.
The drain pump is a tight work area I will attach a Pic of the Drain Pump location for the FAV6800A/FAV9800A machines with the Outer Tub removed. It’s located on the right side of the machine. You will see the short drain line hose from the Sump Cap to the input of the drain pump and the exit drain line clearly in this pic. But before all that I would have you place 5 gallons of water in the machine by bucket fill then turn on the drain pump in Service Mode and time the wash tub to empty the water fill about 25 seconds max. That would give me an idea if we are dealing with drain pump/line restriction issue.
Pic of the drain pump on the left side of the machine base and the motor controller on the right side……Rich
May 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Update on Neptune TL extraction problem
Mike,
No problem just will help me and other linked to on going troubleshooting efforts. I did the same thing when I started.
I was logged in under my other forum name dh1200s any way this statement ""They should be stiff to rotate thru the transmission gearing but will move."" is wrong I can't rotate the tumblers by hand but check for that free wheeling tumbler. I'll add a comment about your request ""Is there a way to test the tumbler speed or to run the machine with the door open to see if they are spinning?"" Yes do you have the Service Manual?
Here it is;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Look in the SM it will show you how to raise the washer top from the base. Just make sure the washer is not signaling for water fill or you spray some water around. I’m going to post this under my FAV6800AWDIY forum name.
If you feel the need to tear down the drain line system here are a couple of pics to start ya off. Make sure when you remove the drain line from the Sump Cap on reinstall is snug up against the Sump Cap. To remove the Sump Cap to empty a coin or two and other possible debris it will twist CW to remove. When you reinstall watch you don’t pinch the rubber O-Ring. Place some towels under the Sump Cap to catch excess water.
Sump Cap and some stuff I found in mine but I had no wet clothes issue just doing DIY maintenance.
My Solution to preventing Drain Line clogs and broken Drain Pump impeller.
Better shot of the Drain Pump lay out and exit hose. I was doing a Outer Tub Bearing replacement. It will be a tight work area. That's why I came up with the Sump Cap filter screen.
Good Luck with you project and I will try to help if I can....Rich
Apr 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Gettin an EE2 error - replaced the fule filter at the tank, removed and cleaned the sump screen, no luck. Does the sump screen on this stove fit into the sump with the open aspect of the screen facing the...
The open end goes toward the back of the heater.
Next try cleaning the flue.
Other potential causes for an EE2 are malfunctions of the circuit board, flame sensor or or fuel pump.
-Helping Hands Services
Fairbanks, Alaska
Oct 11, 2009 | Rinnai Toyostove Direct Vent Heater:...
Sump pump drain
Storm sewer or rain water run off area. In other words , almost anywhere where it won't come back in.
Mar 12, 2009 | Genius Wayne Submersible Sump Pump With ...
Pump support
Follow these steps to replace a malfunctioning sump pump. If you are starting from scratch and want to put in a completely new sump pump and drain line, you should have a professional plumber do any actual piping unless you have an advaced knowledge of those techniques. Locate the sump pump in your basement. Unplug it to avoid possible electrical shock or personal injury. Find the place to disconnect the pump from the drain line. This is usually either a screw-together type union or a rubber coupling with hose-clamp fastenings. Both are quickly and easily undone. Remove the pump from the pit and allow it to drain for a few minutes. Any plastic piping or fittings that comes from the water outlet opening and goes up to where the pump connected to the drain line needs to be removed and saved to reattach to the new pump. Take the pump with you to your local hardware store, plumbing-supply house or home-improvement center. They can help you pick a replacement that requires the same power source and provides the same drain-line hookups and pumping capabilites. Reattach any piping and fittings in the same way that they were on the old pump. Set the new pump in the pit and reconnect the union. Plug in the pump. You can test the pump by filling the sump pit with buckets of water.
Aug 27, 2008 | Belle Group BHB30 - for 8 gallon Hydraulic...
Garage door
Disconnect the door from the opener and manually lift to see if it is binding.
Jan 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Manual
Have you tried the Sears Parts Site for a manual ? Try http://www3.sears.com/ Good Luck...Larry
Jun 11, 2007 | Kenmore 95002 / 95004 Electric Kitchen...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
