Question about Fuji FinePix A345 Digital Camera
Hi i have a finpix A345 recently the viewfinder screen turned white what could be the fault
  • 747 Answers
What I've found with these cameras is that they can become overheated if left in a car, dashboard, or in direct sunlight. In most cases the screen will return to its "normal" after the camera has cooled down.
Posted on Dec 26, 2010
Recently I turned on my TV and I have vertical white area with some lines that are colored on the left side of the screen. The rest of the screen looks fine.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 04, 2015 | Sharp Televison & Video
Viewing Screen White Out
this seems to be a fault with the CCD of the camera
you will have to make a major repair
Sep 17, 2008 | Fuji FinePix A345 Digital Camera
White screen!
Hi
A white screen is associated with no signal being sent to the screen and not a fault with the actual screen itself.
Often this is caused by a loose connection where the wiring for the screen plugs in to the circuit board there is a little plug that can work itself loose and cause this.
If you feel confident about it you could open the camera and trace the LCD wiring to the circuit board. Ensure the little plug has not worked loose from its socket on the board.
The only alternative to this is that there is a component malfunction and this will require a service repair.
Hope this helps. Thanks for using FixYa.
Dec 22, 2009 | Fuji FinePix S5000 Digital Camera
The image in the viewfinder is now black and white and the LCD screen doesn't work
iam very sorry that you have this problem.When an LCD screen of DSRPD170P stops working it means that you have to get a replacement LCD screen. The replacement requires a qualified technical person. if you have such a person , then here are the details for ordering the LCD screen parts:
A-7078-956-A PD-217 board complete.
8-753-209-13 ACX500ENA
1-517-931-21 Tube fluorescent cold cathode.
Please note that the viewfinder of the DSR PD170 camera is always manufactured and supplied as black and white (not colour) so this is not a fault!
Oct 08, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
When I turn on the camera the viewfinder/display screen are white
if u take pics and they are also white in color and blank then my friend CCD failure! has occured just email FUJI or call them in ur region where u are get info at www.fujifilm.com they will repair free of charge it is the manufacturing fault , i had the same model S5000 and had the same problem and i got it repaired free from Fuji u have to call them , even thousands are facing the same problem all brands , they are repairing free of charge regardless to the nature of warranty see this link
http://www.imaging-resource.com/badccds.html
pls rate me FIXYA if i helped u
Mar 28, 2009 | Fujitsu Cameras
Powershot pro1 viewfinder show blank white
Hi
When the LCD screen is open the viewfinder will switch of and when it is closed the viewfinder will switch on. You can switch between the two by pressing Monitor select button to the left of the Eyepiece (Viewfinder). as you look at the back of the camera.
Hope this helps.
Jul 15, 2008 | Canon PowerShot Pro1 Digital Camera
LCD SCREEN
LCD = Lousy Camera Device? Get used to using the optical viewfinder. The LCD is great for reviewing images after you've taken them, but it leaves a lot to be desired as a viewfinder. Keeping your camera steady is no small feat at the best of times, but being forced to hold the camera away from your body to view an image through the LCD adds a new level of instability to the picture-taking process.
Mar 11, 2008 | Fuji FinePix A345 Digital Camera
Soft ware for fuji a345 to windows vista
This stinks. Just got this new computer with Vista Premium windows and now, cannot use
my FinPix 345 digital camera. Thanks Fuji
sanje43@yahoo.com
Feb 09, 2008 | Cameras
Fuji FinePix A345 Digital won't turn on
Have you tried using high-drain batteries? 2800mah rechargeables should do the trick. My A345 had all sorts of problems until I used expensive batteries and now it's been given a new lease of life! my camera wouldn't turn on half the time, when it did it turned off as soon I tried to use it, the shutter would refuse to open, all sorts of weird stuff - I have had no more problems since changing to better batteries (high-density Sony first of all, now I use rechargeable).
Jan 19, 2008 | Fuji FinePix A345 Digital Camera
LCD screen stopped working
sounds like the LCD screen viewfinder may have been twisted or accidentally catched or got hooked or snagged on on something at one stage and pulled something, if the screen went yellow it means the three wires going to it are possibly broken or the small white clip was slowly coming undone inside the Viewfinder for the red and green to no longer work to complete the image also indicates why the buttons on the viewfinder are not responding, try twisting the viewfinder very lightly whilst on, but most likely the small white clip holding the wires has come off at the elbow inside the camera
Apr 22, 2017 | Sony Handycam DCR-HC21 Mini DV Digital...
Fuji FinePix A345 Digital Camera Logo
47 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
