Question about Ovens
El micro-ondas smeg se autoconfigura. Esto lo hace solo sin que nadie oprima ningun boton del panel central. Es decir, se queda pitando esperando la entrada de datos: tiempo, tipo de coccione, etc. Pero nadie apreto ningun boton Que puedo hacer?
    Genius:
  • 1,417 Answers
please translate in English language .
to get fast replay
thank you,
Posted on Jul 05, 2010
Smeg uk60mfx schematic
Check back of the oven or inside control panel. Turn off the power first!
Oct 26, 2013 | Smeg Ovens
Oven and grill not heating up, model no se 336ss-5
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Dec 04, 2011 | Smeg Ovens
Smeg Elect.Oven. No light or any movement. Checked fuse and plugs etc it is ok what is the problem
First, you need to determine that you have the correct voltage for the oven. Is this a wall oven or a free standing range? Did you recently use the oven right before the malfunction? Do you have the model number?
Mar 23, 2011 | Smeg Ovens
We have a GE Profile cooktop in the house we bought. I found the manual from previous owners of house and it is a JP350. It has white knobs (4 large and one smaller one). I would really like to have...
Bonjour, j'ai un four GE Profile électrique acheté en 2006 et lorsque je veux me servir du fourneau, tous les boutons digitaux sur lesquels j'appuie donne comme résultat "LOC On". La plaque fonctionne toujours bien c'est seulement pour la programmation du four que j'ai un problème. Est-ce qu'il se peut que j'ai appuyé par mégarde sur quelque chose qui verrouille les commandes car jusqu'à dimanche dernier il fonctionnait bien? Comment régler ce problème? Merci à l'avance
Nov 05, 2010 | GE Ovens
No ignition
EL HORNO NO SE APAGA EN LA TEMPERATURA SELECCIONADA Y CALIENTA DEMASIADO
May 20, 2010 | Imperial ICVD-1-H Turbo-Flow Gas Single...
How to reset SE 108 x
Customer Service
Here are three things to try. First, on page 64 of the following manual link below, it discusses how to delete the data to the timer clock before turning off the oven. More about programming the clock precedes that but it looks like something you could try. Secondly, I have to wonder what would happen if you just unplugged the stove and left it unplugged for maybe a half hour. Maybe it would magically reset the function of concern. Lastly, you might consult the SMEG techarea below. If that gives no satisfaction, you may have to consult a SMEG technician. Here is a google link to the manual I was examining followed by the smeg tech webpage link which you can register for to use:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwiQp8_spt3VAhWGQiYKHZCyD9cQFgguMAE&url=http%3A%2F%2Fwww.smeg.co.nz%2F%3D%3DihtNy8jZPYfrOmUNPKkD9A%3D%3D%2FUSERS%2520MANUAL.pdf&usg=AFQjCNErxuPY_fiXPK7Aop9YNSPCpA6PZA
SMEG TechArea for registered users:
www.smegtech.com
Aug 17, 2017 | Stoves Ovens
Replacing thermocouple on smeg oven
Look at the bottom of the oven and see if you can remove the panel, if its all one piece then take out broiler pan and look inside to see if you acan get to the pilot burner. Good Luck
Jan 11, 2009 | Smeg Ovens
SA280X or SE280X?
go to google then click on shopping it is the best way to get items hope this helps.
Oct 17, 2007 | Smeg SE280X Stainless Steel Electric...
Ovens Logo
53 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
