Question about Microsoft Xbox 360 Console
My xbox console won't turn on and everything is hooked up
  • gkevin99 Jul 04, 2010
    xbox 360 console will not turn on.
  • 10,319 Answers
Have a volt meter? If so check the power packs output on the voltage and compare it to the voltage rating on the power packs specifications
Posted on Jul 04, 2010
    President:
  • 3,278 Answers
Hello, Kevin.
Be certain that the components are snug and check all the wires.
Also, flip the switch if connected to a power surge protector (or connect directly to an A/C outlet).
Hope this helps.
  • NinaE Jul 04, 2010
    Didn't hear back from you ...
    If you're still looking for a solution ...
    If still under warranty, return for a replacement.
    If not under warranty, you may need to replace your power supply or motherboard.
Xbox won't turn on
Check ALL your electronic equipment. Then contact your insurance company and tell them to open a claim, while you are talking to them see if they will pay for an electrician to come out and check the wiring in the house. If you only rent, they wont but you should have everything checked.
As far as the Xbox is concerned, lightning is destructive to all the components in unit. There is nothing that you can do short of sending it in for a replacement unit.
Aug 12, 2012 | Microsoft Xbox 360 Console
Xbox 360 reset to factory settings
You can scroll all the way over to the right to find the settings option from there you can select everything you need. Go to storage then go to the device you are using to store your stuff and press "Y" and then Format. That should reset your device for use.
Dec 20, 2017 | Microsoft Xbox 360 Console
It green screens after 10 mins
Are you using hdmi cable. If so your hdtv needs to have it's hdmi port reset .First unplug everything even the TV and xbox. Then disconnect everything and unplug every thing from the wall outlets. Then plug the TV back in and hook everything back up. The HDTV even with the power off can have it's hdmi port bumped so you need to unplug it to reset the ports.
Thank you
May 09, 2010 | Microsoft Xbox 360 Console
When a game is inserted into the xbox 360 console it won t play the disc. on screen it says please insert xbox game
I had the same problem with my Xbox a while back. Call Microsoft Xbox support. If they tell you that your warranty is no longer valid just keep hassling them until they hook you up. Worked for me!
Sep 01, 2009 | Microsoft Xbox 360 Console
Xbox 360 won't turn on.
Its dead.
99$ to fix if you didn't buy it used.
All 360's will fail at some point. Just built poorly.
Jul 05, 2009 | Microsoft Xbox 360 Console
My xbox 360 turns on with 4 green lights but i can not see any picture or sound
it sounds as if you have a connection unhooked or loose somewhere. Double check all audio and video cables are secure and in the correct position. If that doesn't work try troubleshooting by trying a different tv or removing all connections from tv and xbox and re-hooking everything back up.
Feb 19, 2009 | Microsoft Xbox 360 Console
Xbox360 red lights of doom
un hook your everything on your xbox except your power cord turn off xbox then wrap you xbox with atleast two towels now turn xbox back on and leave wrapped for 20 minutes then after about 20 minutes un wrap it and let sit for about 15 minutes now plug everything back in and turn it on this method should work for about a week or so until they find a real solution to the problem
Mar 25, 2008 | Microsoft Xbox 360 Console
Sound with no picture
Have you looked at the side of the cable and made sure that the switch is set correctly? you have to select either HDTV of AV I believe. If that isn't the problem, try hooking it up through a different input on your television. I don't think it's your xbox because with any hardware failure, you would get the RRoD (red ring of death). I would definitely troubleshoot the TV. Try to hook up a regular DVD player in the input that your xbox is in and see if it works.
Jan 29, 2008 | Microsoft Xbox 360 Console
XBOX SHUTS OFF.
You could have a faulty power supply. Have you checked to make sure everything is hooked up properly? When you turn your xbox on have a look at the light on the power brick, its usually green when its working fine and orange when the xbox is turned off, if its red there could be a problem with it.
Hope this helps
Jan 09, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
