Question about iRobot Roomba - Sage Bagless Robotic Vacuum
I turn it on and it does not move just play a tune
  • 10,319 Answers
Remove the coverings and clean out all expose dust and dirt
It will run if thoughly clean inside
The contaminates do screw up these vacuums very much so
Posted on Jul 04, 2010
When connecting handgrip to sheath wand it seems there is play in connection, turning powerhead on and off.
Sounds like you have a worn latch, check for a replacement. One certain models you can move the connector closer to the hose opening. For the most part it needs replacement, there are few fixes for this problem
Jan 06, 2015 | Electrolux Lux 5500 Canister Vacuum
My husband ran over my daughters shirt with our Dyson DC17 animal. Now it's making this horrible load ratting noise. I've taken the head off. Clean the beater bar. The belt is in tact. No
First make sure there are not any of the rubber cogs missing from the belt, it may be wise to replace the belt anyway because the cogs may be worn. Make sure the brush roll does not have any play in it anywhere and that It fits tightly in the nozzle housing without any play. If there is any play or wiggle that will cause it to move.
Apr 21, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have just purchased a wireless doorbell but it does not explain how to change the tune, please help.
Most wireless Door bells go ding-dong! Does your doorbell play Greensleves, or Home on the Range?
Did you get 2 buttons with it?
One is for the front, which makes the bell chime one way and the other is for the rear and it makes it chime differently.
Jun 29, 2011 | Vacuums
I have a Miele Solaris that is having an intermittent power problem. The power will not turn on unless I push the cord winder button at the same time as the power button. I have disassembled the vacuum and...
These type of cord retractors have a set of contacts which sometimes get corroded or bent. Or maybe the reel has become wobbly.
As the cord reel moves, these contacts should have enough pressure stay in contact with the tracks on the reel at all times.
You sound like a handy person, so you would have to take the assembly right out of the machine and perhaps be able to correct the situation.
Some of these contacts are easily accessible, and others not so easily.
While you have the old assembly out anyway, you also might be able to buy a new one to replace it.
Without a close look it's hard to guess what to advise you.
Maybe a vac repair shop could throw in an tune up as well?
Check the motor brushes and so on?
Jun 17, 2011 | Vacuums
High pitched sound when beater bar is engaged
Switch the machine off at the wall. Take plug out the socket.
Take a 2 pence peice and unscrew the 3 plastic screw on the bottom. In here you will probably find a build up of dirt etc. This dirt also gets into the fine tuning of the brushbar.
Take some WD40 and spray this on the moving partsm aking sure you het the edges, nooks and crannies.
Feb 16, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My irobot (Roomba)is only working for 10 mins then
It should take about 6 hrs to charge. I had the same problem and reset the charging circuit. 1) Charge it until the green light comes on. 2) Unplug and pull battery out. 3) hold down the power on button 15-30 seconds. 4.) Put the battery back in, plug in the charger (direct - not through the dock) and charge for 72 hrs. Then, run at Max clean until the "I'm dead" tune plays.
May 12, 2010 | iRobot 4150 Roomba Vacuum
The red light is flashing and then there is a four note tune that plays - I don't know what is wrong with it - I cleaned the brushes and it still does it
I bet you have a roomba? if so you probably need to replace the battery, reset the unit, then charge for 16 hours straight, go to roomba dot com the site is very helpful, Don the Vacuum Doctor Alb,N.M.
Oct 29, 2009 | Vacuums
Brush bar wont turn, Bissell smells like burning rubber
The belt just goes from the motor shaft to the brush roll. Do the ends of the brush trun freely, or is one of them froze up, if so replace the brush roll. If it is ok, try to turn the brush roll by hand, maybe the belt got pinched and won't move.
Aug 25, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Roomba does not do anything
My Roomba has had a battery issue for some time now. I haven't used it in quite a while (months, years, I don't know for sure) because it would complain of a discharged battery after only a few minutes of cleaning. However, now when I finally tried to use it again, a new problem appeared.
Now, it charges normally, if I plug the cord directly into the Roomba. It will not mate with the home base, however, even if I place it on the contacts manually.
When I start it, all the buttons come on green. I then press a button to make it begin cleaning. The motor whirs up and runs for about 1 second, then it shuts down. About one second later, the power light and lights behind whichever button(s) I pressed (to give it a job) flash green then the system sits silent, and doesn't do anything else.
May 31, 2008 | Roomba Robotic Floor Bagless Vacuum
Dyson 07 won't stand up
I talked to Dyson support (they are open 6 days a week, try them if you're stuck)
Turn the vacum on it's side. Look on the side that has Bare floor/carpet control. There is a hose with two yellow buttons. Detach the hose. On the square side, look for a black button. Depress the button, then release. On the square side, slide the square up until it locks in place.
Now try to see if it will go upright (it should)
Finally, re-attach the hose.
Apr 18, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
iRobot Roomba - Sage Bagless Robotic Vacuum Logo
41 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
