Question about Weber Q Grill
My burners light, but just a little bit, won't burn enought to cook.
    Sergeant:
    Champion:
  • 333 Answers
Bad regulator?
Posted on Aug 15, 2010
Cook top light wont turn off
On one burner the cook top light won't turn off and is a little warmer that the other burners that are off
Jan 27, 2014 | Whirlpool GY396 Electric Kitchen Range
Buners will not Fully Light
A burner doesn't work Heating elements eventually burn out. Sometimes, when an element burns out, you can see that the coil burns in two, or blisters and bubbles.
When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too. Also see the "A burner works only intermittently" section, next.
http://www.repairclinic.com/0088_13_1.asp
Jun 29, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Can I remove the burner that is burned out and only use 3 burners to cook with, will this stop the popping & tripping the breaker?
You should do little more homework.. Yes you can remove the burner if it's the culprit and causes a short and tripping the breakers. If still trips after you remove it you should look into replacing the harness for that burner.
Jan 12, 2014 | Hotpoint RB757 Electric Kitchen Range
I recently purchased a Toshiba PA3761U-1DV2 external multi burner/reader. I have a Toshiba Satelite Vista SP2 32 bit. The included software won't install. However the drivers did install and
It usually better using the burn software that came with the multi burner because it will be compatible with your multi buner. Windows media player burning cannot be compatible to all the burners on the market.
Mar 07, 2013 | Toshiba PA3761U-1DV2 DVD-RAM Burner
Burner won't light on both sides of burned
The burner is lighting back to the injector on the gas control. 2 things burner out of postion or burner is blocked needs cleaning, you can remove this and clean with air line or small bottle brush.
May 20, 2012 | Grilling
One burner wont light of the 3
Is the igniter not sparking or is gas not getting to that burner? Have you tried to match light that burner? Those three things is where you start troubleshooting the problem
If the igniter is not sparking, it could be that the igniter is covered with cooking grease or the wire to the igniter has come loose either at the igniter or the igniter module. And simply needs to be reattached (pushed back on).
If the burner won't match light, than it's not getting gas and should be removed and thoroughly cleaned. And while you're at it, remove and clean all the burners and the venturis valves.
Removing the buner burners on a Ducane grill is a bit of a task, so I have included a link to your Owners Manual to assist you. Pay particular attention to the section Annual Maintenance, starting on page # 28.
http://help.weber.com/manuals/ducane/2009%20Manuals%20pdf/Affinity_3100_4100_LP_OwnersManual_27010331_101508.pdf
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
May 10, 2011 | Ducane Affinity 3100
Hi I have purchased a 2nd hand Colman 431 stove . The instruction Manual wasn't with it. Looking for instructions Please. Hope you can help. Rob Tyler Toronto
I am not sure what to tell you, other than go to Colman's website for a manual. That will at least give you a parts list if you ever need it. But, these stoves are generally solid and reliable, with few things to know about.
What I do to operate:
  1. Set up stove: lid up and wings out, tank fully pumped (works best if no more than about 2/3 to 3/4 full) and installed with nozzle firmly into the socket above the right burner.
  2. Little lever on left of valve assembly--turn upward. Open valve a little bit to get fuel flowing to burner. Give it just a few seconds then light burner with match or lighter (watch your fingers!). It should light off pretty readily.
  3. Open valve a fair bit (anti-clockwise) and let it burn for up to a minute until the flame changes from yellow to mostly blue, and mostly around the burner and not up in the air. Turn little lever on left of valve downward.
  4. Re-pump tank to maintain pressure.
  5. Use valve knob to adjust flame intensity, and cook away.
  6. To use second burner, the key thing os to remember that it draws from the same valve, so when it is on the main burner goes down a bit.
  7. The knob for the 2nd (left) burner is a little flip-out on the left end of the stove. Open slightly, and light the burner. Only do this after the main (right) burner is burning blue.
  8. Use the main valve (on the tank) to adjut the total fuel flow, and the little handle for the left burner to adjust how much of the total flow goes to the left side. (You cannot burn the left without the right being on.)
  9. Pump as required to maintain pressure.
  10. The only real "part" that you might have to strip or replace is the "generator" which is the tube from the valve across the top of the right burner. The liquid fuel is vaporized in there, and is what needs to get warmed up when you start.
Feb 01, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
One of the burners does not light but it does have a spark at ignitor but it is not directed to burner port
Be certain the openings in the burner are free of debris. Boilovers can leave debris in the openings that will harden. Once this happens you cannot get the right mix of oxygen and gas for a flame to ignite. With the burner OFF, you can clean the openings gently with a toothpick to loosen the cooked on "gook." Then when you turn on the burner, the flame should burn off the residue and your range will be "cooking on all four burners!"
Nov 06, 2010 | Jenn-Air JGC8536 Gas Cooktop
My Kenmore cooktop will not heat properly, all 4 burners. They turn on and heat a little bit, but the burner on lights do not light up and the burners do not heat to full temperature. I closed my oven...
hi my name is mark, a service tech needs to check the voltage to the cook top. you will probably find improper voltage. check data plate for proper voltage should be 208v or 230v depending onwhere you live.
Feb 18, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Burners with yellow tipped flames
I have a G.E. natural gas cook top. All 4 burners have a lot of yellow flame all of a sudden. Is there an adjustment for this I could make? Please explain the best you can.
Jan 05, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Weber Q Grill Logo
121 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
paulcarew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
