Question about GE APN10AA Portable Air Conditioner
Compressor does not work and the digital display area shows "P2 " and Water full light keeps coming on and shutting unit i have mpk 10cr everstar portable unit and i lost owner manual book
  • 37 Answers
Don't forget that the little metal arm in the water bucket hole can be pulled down some to allow better contact with the bucket when the bucket is inserted.
Posted on Aug 21, 2010
  • 29 Answers
Empty the water tank, located at bottom of unit either left hand side or right hand side, normally removable.
all the best
Posted on Jul 05, 2010
Everstar MPK-10CR compressor keeps running after power off, on remote. Display blanks. Only shuts off when O/L @ wall plug tripped.
call in an electrician as there is a problem in the circuit allowing power from a neutral line and bypassing the switch
Jun 30, 2016 | Everstar Portable Air Conditioner MPK-10CR
What is the P2 code on an everstar mpk 10cr1
<b>Unit Displays P1</b><br /> P1 error indicates that:<br /> <ol type="A"> <li>The water tank on the side of the unit is full. <li>The water tank in not properly seated in the housing. <li>The switch at the back of the water tank housing is not engaged or is loose </li></ol> <br /> <i>Solution</i>:<br /> <ol type="A"> <li>Empty the water tank. <li>Make sure the water tank is properly secured in the housing <li>Remove the water tank for the housing and gently tilt the switch at the upper left hand corner of the housing towards you. This should allow the tab on the water tank cover to engage the switch. </li></ol> <br /> <b>Unit Displays P2</b><br /> P2 error indicates that the spill reservoir in the base of the unit is full.<br /> <i>Solution</i>:<br />Move the unit to a location that is suitable for draining water from the unit.<br />Remove the plug in the lower center of the back of the unit and allow the water to completely drain <br />(Remember to replace plug.)<br /> <hr color="#cccccc" size="1" /> <b>Unit Does Not Cool/The Green Light is not on. </b><br /> Is the unit in the Cooling mode?<br /> <i>Solution</i>:<br />Press the mode button until cooling mode is selected. <br />Lower the temperature setting on the unit to the minimum setting. <br />(The temperature setting of the unit has to be lower that that of the room)<br />Wait 3 to five minutes for the compressor to start running.
Jul 06, 2010 | Danby DPAC8020 Air Conditioner
P2 err on mpk-10cr it starts for about 5 seconds then p2 displays and it stops can you gide me to were the problem is
P2 error indicates that the spill reservoir in the base of the unit is full.<br /> <br /> Solution:<br />Move the unit to a location that is suitable for draining water from the unit. Remove the plug in the lower center of the back of the unit and allow the water to completely drain <br />(Remember to replace plug.)
May 25, 2010 | Danby DPAC8020 Air Conditioner
My unit displays P2 mode flashes red wont turn.....
Solution:
Move the unit to a location that is suitable for draining water from the unit. Remove the plug in the lower center of the back of the unit and allow the water to completely drain (Remember to replace plug.)
Remember...this is not the water tank on the side. This is the water than can collect in the bottom of the unit. Take it outside and drain it
Aug 20, 2009 | Heating & Cooling
Everstar Model MPK-10CR, What does flashing P2 mean?
p2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
Aug 13, 2009 | Danby DPAC8020 Air Conditioner
Midea MPK-10CR air conditioner "P2"
If the drip line is raised too high, sometimes the level inside will exceed the trip-point for the pan-level.
Try lowering the drip line so the water runs 'downhill' the whole way. If it still occurs, the sensor in the pan may be stuck.
May 03, 2009 | Midea MPM-08CR-BB4 Portable Air...
GE APN10AA Portable Air Conditioner Logo
983 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
