Question about Fuji Rod Repair Kit
I have a Fuji cmaera AV130 how do I attach hand
I have a Fuji cmaera AV130 how do I attach hand strap???
    Brigadier General:
  • 7,191 Answers
Kindly attach the hand strap as shown in the attached images:
Thanks for using FixYa.
Posted on Jul 04, 2010
Testimonial: "I had finally figured it out, but it would have helped very much Thank you"
In need the instructions
This is a seat post mounted bag, with attachments for the rails (2) on the bottom of the seatpost.
1. The straps going over the top of the bag will have to come apart. Removing them from the loop they pass through before re-attaching with the velcro.
2. Undo the straps and then feed them over the metal seat rails.
3. Re-assemble the straps in the same manner they were before and loosely attach the velcro. You will later tighten up the tension on these straps to snug the bag up under the seat.
4. Attach the velcro strap on the posterior of the bag to the seatpost.
5. Now the bag should be supported by the seat post strap and the seat rail straps (2). Hanging loosely and oddly from the seat area.
6. Tighten/snug the straps from step three, so the bag is drawn up against the bottom of the seat. Try adjusting all the straps on the bag until the bag appears to sit well under the seat.
7. DONE
Jan 05, 2013 | Avenir Bigmouth Seat Bag
Tip
How to wear a wrist strap when playing racquetball
Racquetball can be a very competitive and dangerous sport due to the close proximity between players. Regulations in the USA require that all players wear a strap to keep their racket from slipping and hitting themselves or other players. You would be amazed how many injuries are caused by slipped rackets and there is nothing more embarrassing than hitting yourself.
To put the racket ******** properly, place your dominant hand (if you are a righty the right hand) through the wrist strap that is attached to your racket. Using your other hand, take the racket rotate it in a clockwise motion, this will make the opening where your wrist goes through smaller making it less likely that your hand will come out of the strap.
Put the racket into your dominant hand and grip it so that the "V" formed by your thumb and forefinger should be aligned with the center of the racket's grip. Slide down the racket until the bottom of the racket is resting in the palm of your hand and your pinky is no longer holding the racket. When you get to this position you are ready to start playing.
It is important that you get a strap that is smaller but not too tight, a smaller strap will help to give you a wider range of motion and will give you the ability to hit the ball harder with more accurately.
on Jan 28, 2014 | Sport & Outdoor - Others
I need instructions for the genki house baby carrier and for the bubba moe baby sling
Here are Genkihouse Sling instructions - I tried to attach scanned copies of the instructions, however it exceeded the file size limit:
For front use
  1. Hold your baby close to your chest
  2. Still holding baby close to your chest, grab sling and place over baby - Genkihouse logo facing away from you, arrange baby's legs through leg openings. Alternatively, you can lay the sling on a change table with logo facing down, lie baby on top and put legs through leg holes then lift the baby and the sling onto your chest.
  3. Still holding baby close to you, place sling straps over your shoulders.
  4. Reach behind with one arm (still holding baby with the other) and firmly take the strap from behind opposite shoulder. Your other arm still holds the baby and sling.
  5. Thread the strap through D ring with one hand whilst your other hand still holds the baby.
  6. Simply 'hook' the strap through the D ring with your index finger.
  7. Do not change hands at this stage.
  8. Tension strap backwards - away from your back and don't let go.
  9. Feel the baby's weight now firmly supported by the sling at your waistline.
  10. As you continue to hold the same strap reach behind with the other hand and thread the second strap through its D-ring. The straps should criss cross over your back.
  11. Bring straps together, adjust tension to suit and tie a secure knot in the middle of your back.
  12. Check the position of the baby - you should be able to kiss his/her head.
  13. Baby can also face outwards when he/she gets older.
Jun 15, 2011 | Baby Gear
My display screen is crakced can i replace it on my own
Hi I am Vortash providing you are reasonable with tools and dont have an un steady hand yes easily .
It requires close inspection of the camera and a set of jewlers screwdirvers and patience .
A reseptical for all screws and a notepad to roughly sketch any areas that you are unsure of to refer to on re assembly . screens are usually attached by means of a plastic ribbon into a slot plug that has two clips one either side ease them out and the ribbon will be free dont just pull or the ribbon may break and the clips snap , you will probably need a pair of good tweezers to remove and replace this cable ..Be careful with the clips they snap very very easily ..
A replacemnet screen should be obtainable from Ebay Or Amazon quite cheaply .
One thing I will warn you off is static damage .
components in electronic equipment are highly suseptable to Static damage generated by the human body and surroundings .. one touch can destroy an Ic and your camera . you will need to be earthed to a static arm band strap to eliminate this . ( this is a strap that fits on your wrist that is connected to an earth point through a flexicable attached to the strap . they are quite long and give you ample work movement and can save you pounds from destroyed equipment ) hope this is of help regards Vortash
Jul 04, 2009 | Fuji FinePix A500 Digital Camera
I am trying to take photos with my Olympus FE-140, which is supposed to be a cinch to use and has been until now... Maybe I pressed something I shouldn't have, but it keeps taking me to Card Setup, and my...
format the card in a Fuji. Oly cams dont do a very good job formattng xD cards. Take it to a cmaera store and see if there is a Fuji you can use to format the card.
Nov 30, 2008 | Olympus Cameras
Need a new seat pad and straps!!
I needed new seat covers and called chicco uk on 01623750870 they provided one for £25, excellent service too. Hope this helps.
Sep 30, 2008 | Chicco Polly Highchair
Strap
hi clarkent,
  Should you want to attach a hand strap or lanyard to the phone, simply remove the phone’s back cover and lift up the right side of the ‘power’ button’s rubber to reveal the strap hole.
good luck
Jul 03, 2008 | Sony Ericsson K800i Cellular Phone
Digital camera( fuji fine pix z10fd)
hi friends,i am from india,few months (6 months) back i have purchased the fujifilm s5700 camera, but unfortunately the one of the pencil battery got leaked inside it, now in the one of the battery comoartment, out of total four battery compartment, some greensih fluid i can see. now after putting the fully charged battery, i am not able to switch on teh cmaera, i am worried a lot, it is under warranty period, of 2 years, but i am bit concerned, as few o my friends are saying that battery problem can not be fixed by teh manufacturer even in the warranty period.
please solve my problem, weather battteryleak problem be solved, and if solved, can it be repaired by manufecurer free of cost during warranty period.....
Mar 31, 2008 | Fuji Cameras
Highspeed spin is not stable...
Is this a brand new machine? If so make sure the shipping pins have been removed. They are attached to a yellow strap coming through rear of machine. Pull the strap straight out and there will be 3 pins that are attached to it. You should be able to move the basket and tub around by hand freely. If this is not the problem you may have a base pad broken or missing.
Oct 03, 2007 | Whirlpool LSQ9610L Top Load Washer
Fuji Rod Repair Kit Logo
146 people viewed this question
Top Fuji Sport & Outdoor - Others Experts
Nick Olsen
Mark Gough
Are you a Fuji Sport and Outdoor - Other Expert? Answer questions, earn points and help others
