Question about Exercise & Fitness
Need manual for nordic track walk fit 5000 1995 manual treadmill, also resistance belt. and where do batteries go for digital readouts?
I can't help with the manual. But, if you reach under the area where the readout is, push up on the cord or any of the opening underneath the display will pop out. You should be able to find the battery compartment. The unit uses 2 AA batteries. If you find a manual, let me know.
Thanks.
Posted on Jul 26, 2010
  • 77 Answers
You can download a free manual at www.iconservice.com.
For a new treadmill, see www.treadmill-world.com
Posted on Jul 04, 2010
How do I adjust the walking belt?
If you can remove the necessary covers to find the adjuster mechanism(s) do so and then adjust one side of the belt until it runs true again. Otherwisw get a manual from the Nordic Trac website and follow those instructions.
Oct 04, 2014 | Nordic Track Nordictrack Exp 1000...
Increase speaker volume
you must read your owner manual. or download from
www.fitness.manualsonline.com
God bless you
Jul 29, 2013 | Nordic Track NordicTrack T9.1 Treadmill...
NTL 1192 is the product.
The reset switch is to close to main switch, reset it. See your instruction manual in section troubleshooting. for identify the reset switch. or download your instr. manual from www. fitness.manualsonline.com
God bless you
Nov 07, 2012 | Nordic Track Nordictrack C2200 Treadmill...
Nordic track c2420 how to reset treadmill
see the reset button to the side or main switch.and fix it.
God bless you
Jun 18, 2012 | Nordic Track Nordictrack C2420 Treadmill...
How to adjust the running belt??
Check page 27 in the owner's manual:
"If the walking belt slips when walked on, first remove
the key and UNPLUG THE POWER CORD. Using
the allen wrench, turn both rear roller bolts clockwise,
1/4 of a turn. When the walking belt is correctly tightened,
you should be able to lift each side of the walking
belt 3 to 4 inches off the walking platform. Be
careful to keep the walking belt centered. Plug in the
power cord, insert the key, and carefully walk on the
treadmill for a few minutes. Repeat until the walking
belt is properly tightened."
Dec 18, 2010 | Nordic Track NordicTrack Treadmill, A2550
My nordic track treadmill's walking belt stops when I start walking on it but the motor is still running although the front roller is not moving when I start walking on the walking belt. Do you think the...
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
May 17, 2010 | Nordic Track Exercise & Fitness
How do you adjust or tighten the belt on the Nordic Track A2750 The belt is riding to one side of the platform
If the walking belt is off-center, remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left idler roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
May 14, 2010 | Nordic Track NordicTrack A2750 PRO...
I have a Nordic Track treadmill C1800. When first
You have 1,2 or maybe 3 problems. 1st is you need to remove the cover over the motor. The belt that the motor turns may be slipping. You need to loosen the bolt that keeps the tension on the drive belt. Push down to tighten manually and then tighten bolt. While your in there you should check the drive belt for wear. If you have used the treadmill a lot it may need replacement. $20 from readmilldocter.com The walking belt if badly worn can be replaced for like $99 but probably is fine. put all back together and tighten tension. Should be able to lift walking belt 3 to 4 inches from center sides. Any less and its too tight. Its probably better to just replace the drive belt anyway. This should work. Do not over tighten ever. This is the cause of most problems.
Jan 18, 2010 | Exercise & Fitness
Exercise & Fitness Logo
2,120 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
