Question about Fantom G-Force MegaDisk 1.0TB 7200RPM USB 2.0 16mb cache (MDU1000) Hard Drive
Fantom GF1000EU Hard drive: When I turn the drive on. My computer recognizes the drive is plugged into the usb It does show up in the device manager as pantom dive. The drive does not show up in my computer and so there is no way to acess it. I have an hp touch smart with windows 7 how can I fix this. Thank you for your help
4 Suggested Answers
anjana03
  • 361 Answers
SOURCE: Fantom GF1000EU Hard drive: When I turn the drive
there is extra port of power and data attach in hdd and also use cable join this port. some time this port and usb cable loose and damage so we can not look hdd in computer. once atime change another case to check hd. (nepal)
Posted on Oct 13, 2009
JulesPCaut
  • 702 Answers
SOURCE: Unrecognized FANTOM HDD volume
From your description you seem to have a problem with the boot record on the external hard disk. There are tools that can sometimes recover such problems. I read about it in an article about external hard disk troubleshooting. No personal experience with such tools though.
Posted on Nov 11, 2009
issken
  • 1472 Answers
SOURCE: Cannot acess drive in Windows 7. Tried changing
afdancer
If the drive is working on your Windows XP system then most likely the drive letter that was assigned to the drive got bump by another device. The link below will help you assign another drive letter to the drive.
http://www.fixya.com/support/r4176803-change_drive_letter_in_windows_vista
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Aug 13, 2010
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
Pc recognizes the device in device manager list but not in my computer window
You could check Computer Management > Disk Management. It should show up. If it does not a have drive letter it is not recognizing the format structure and sees it as new. I would test on a different system before committing to any changes.
Aug 27, 2012 | MicroNet Technology Fantom Green drive 15...
My Fantom Greendrive is not being recognized by my computer whats the problem?
make sure the lead/s that attach to your hard drive are securely seated
if your computer came with a motherboard disc the drivers could be on it
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Mar 10, 2012 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
My computer doesnt recognize Fantom Drive titanium II. i am having windows 7 installed in my system. please help how to solve this problem
Dose it show up as drive letter E:/ under device manager in disk drives?(Check out:right clicking my computer icon on your desktop,select disk manager)
If so,try right clicking on my computer and selecting map network drive.(You'll get the same results by right clicking on network neighborhood icon on your desktop and selecting map network drive.)This is the method many people use to assign a drive name (i.e.,letter) to a drive.Then you can recover data from hard drive with data recovery software like Tenorshare Data Recovery.It can recover data after deeply scanning your hard drive to look for lost data.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
Aug 27, 2011 | Fantom Titanium II (TFD250U8) 250 GB USB...
My Fantom 1G GForce is not recognized by my computer, the drive isn't spinning and it is making a ticking sound. Help!
if your computer came with a motherboard disk the drivers could be on it
check all leads that are attached to this external hard drive make sure they are securely seated
click strart control panel administrive tools computer management device manager scroll through all of the devices if you see a yellow question exclamtion ? ! mark or a red X you will need to reinstall the driver right click on the mark select update driver if you can see the usb drive and its
not working ports(com&lpt)right click update driver
if this fails to fix the problem you might need to install a usb 2 or 3 card they can be easily installed and are very cheap
hope this helps
Aug 04, 2011 | Fantom Drives FD GForce MegaDisk 2TB ...
My 1 TB fantom green drive driver has been lost, what do i do?
There's no need for any software -- USB devices are designed to be "plug-and-play" -- the Operating System should recognize the device, and make it ready to be used.
Mar 04, 2010 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
Fantom GF1000EU Hard drive: When I turn the drive on my computer recognizes something is plugged into the USB, but it is unable to locate the drivers. The drive also does not show up in my computer.It does...
Oct 13, 2009 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
Not recognized
This may not be the external hard drive issue. Check your USB driver, under device manager. You might need to upgrade the driver. If you plug your external to another computer, you will see that is it working ok. Just re-installing XP might have not installed USB drive properly.
Jun 19, 2009 | Fantom Drives G-Force (GF500EU) 500 GB USB...
Not Recognizing Drive
I take it nobody else found an answer for this problem. Glad We saw this before we bought it :(
Mar 19, 2009 | Electronics - Others
FULL fantom external usb harddrive is not acknowleged after power outage running check disk.
ACS Data Recovery specializes in Fantom hard drives, and can perform successful recoveries on any model Fantom hard drive. If you have a crashed Fantom hard drive, please call us today to get a quote: 1-800-717-8974
unless you fancy trying to connect the drive inside the unit directly to a pc by taking the box a part.
Jul 18, 2008 | Fantom Titanium Hard Drive
Fantom G-Force MegaDisk 1.0TB 7200RPM USB 2.0 16mb cache (MDU1000) Hard Drive Logo
138 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
