Question about Sunbeam 6198 Toaster Oven with Convection Cooking
No thermostat control......... oven always on...... Is thermostat serviceable ??
In my case, the contact points of the thermostat were corroded and sticking. Using a emery board (nail file) placed between the points, I polished them up. Now all works like new. Remember, work with oven unplugged.
Posted on Nov 28, 2016
  • Sunbeam Master
  • 17,130 Answers
Please remove and check if there is any short in the wiring to the thermostat.It is important to replace with the same type/model as it is not advisable to repair unless for an emergency if the same type is not available, could be adjusted with a local one.
Please ceck with the help of multimeter for any shorts/ in the circuit. Hope this helps you Good day.
Posted on Jul 04, 2010
Breville smart oven no heat or convection fan. LCD and controls working and can hear the oven clicking on.
The fan probably operated on the heat... I would tackle the THERMOSTATS, heat elements (at least 2) and/or fuse first.
My favorite supplier, appliancepartspros, struck out on Breville
(never-mind) I'll add a couple of credible ones at the bottom.
Sears parts is a good information source... but very pricey ($$$$) for the EXACT SAME PARTS you can get elsewhere...
If you can determine from your OWNERS papers which part you want to try first... get the operating parameters... and and check with a volt meter (ohms scale... power OFF)... for continuity on the FUSE, heaters & thermostat.
There is a possibility your control board (PCB) is at fault... it seems to be getting scarce... Turn it over and look for a burned/broken solder joint.
http://www.ereplacementparts.com/breville-bov800xl-smart-oven-parts-c-116052_116061_116092.html
In any case... get three prices...
In the event that PCB is the issue I do recommend LOOKING TO SEARS because of their parts support and warranty...
Good luck (finding the FUSE).
Breville BOV800XL Smart Oven Parts
Parts and Accessories
Sears Appliance Parts
Mar 04, 2016 | Breville The Smart Oven Convection Toaster...
Black & Decker Toaster Oven - elements cycle on and off, which makes for a SLOW cook.
Oven has three modes: 1) oven mode cycles elements on and off to maintain a specific temp setting for up to 60 min. 2) toast should keep all elements on for a few min. 3) broil mode top elements only always on, up to 60 min. Make sure you have dials in correct position and use the toast timer.
Apr 17, 2014 | Toaster Ovens
Unit power on light is illuminated but no heat from heating element,
The thermostat may have failed. It could be adjustable mechanically but not electrically.
Nov 06, 2013 | Anvil SAA8003 Stainless Steel 3000 Watts...
Have T4800 Convection Oven, need fan, motor and thermostat. Cannot locate any parts.
Not knowing where all you have checked, here is contact info for customer service for electrical appliances from Farberware: Electric Appliances
farberware-electric@saltonusa.com 1-800-233-9054
If that doesn't work, then here is an address that will give you a list of sites that carry oven parts:
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 16, 2011 | Farberware T490C 1500 Watts Toaster Oven...
Cant set temprature can only get 210 c
Look up your nearest small appliance shop and order a new thermostat. When thermostats go, they get stuck on high, with no temp control.
Feb 03, 2010 | Toaster Ovens
Oven has No Temperature Control
Yes they are servicable and you can do it yourself easily if you're handy. Go to smallappliance.com for parts, or just search "small appliance parts" and you will find a few places that have B&D parts. I'm pretty sure the thermostat switch is available for your oven. You will need the model # from the oven.
Jan 24, 2010 | Black & Decker Textured TRO700 Toaster...
Model 460/5 can not control the heat
I would have to say that your issue is thermostat related.  The thermostat only send a signal when temperature is reached, not what the current temperature is.  So if it is malfuntioning, the desired temperature will never be reached.  Therefore, not sending a signal to cut the heat, even though it is 350.
Mar 04, 2009 | Farberware T490C 1500 Watts Toaster Oven...
Overheating
Try CG Industries in Chicago, IL - they rebuild a wide variety of electronic thermostats. Their number is 630-216-5050.
Feb 08, 2008 | Waring CO1500 1700 Watts Toaster Oven with...
Sunbeam 6198 Toaster Oven with Convection Cooking Logo
432 people viewed this question
Top Sunbeam Toaster Ovens Experts
Andrew Taylor
Andrew Taylor
Are you a Sunbeam Toaster Oven Expert? Answer questions, earn points and help others
