Question about Whirlpool LSR5132PQ Top Load Washer
No Spin Cycle
Goes through the wash and rinse but not the spin cycle It could be the lid switch but how do I test it
  • 478 Answers
Remove the top where the controls are. Pull off plastic part covering the two phillips screws pull fowards and up it flips over. In the right corner is a plug, unplug and place a jumper across the two wires that are not green, then put to spin, it should do so if its the switch.
Posted on Jul 05, 2010
Why does the lid lock light start flashing after the wash cycle and will not rinse or spin?
Lift lid, stick screwdriver into slot where lid latch-pin inserts and see if it goes into the cycle. If so, try adjusting position of latch.
Sep 01, 2014 | Washing Machines
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
f the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
f the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Sep 26, 2012 | Washing Machines
Hello my washing machine has stooped... it will keep washing but will not rinse or spin out.. please help
sounds like you have aproblem with the lid switch , that will keep yoor unit from spinning after the wash cycle then it goes to a rinse cycle as long as the unit cant spin it then can't rinse.
Mar 10, 2011 | Estate TAWB600JQ Top Load Washer
Machine won't shift from rinse to spin cycle
Your lid switch is broken.
Unplug the machine and check with your hand for broken pieces under the lid switch hole.
Replacing this can be really easy.
http://www.pdxappliance.com
Feb 27, 2010 | Washing Machines
Rinse and spin
there is a safety switch on the top...and when you close the lid it pushes down on that switch. investigate that switch and see if its just corroded or needs replacement...i have that same problem when i leave the lid open on my washer...then it works fine when i close it...so im figuring that your's thinks its still open. I hope this helps you out ! and give your wife a hug 8-)
Jun 05, 2009 | Washing Machines
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Mar 18, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not complete cycle
hi. i would check the lid switch fill the tub to low level let it start to wash stop the washer now put it to the spin cycle pull out knob close the lid slowly if it does not pump replace the lid switch now push on the lid. if it goes now .replace the lid switch .thanks te appliance doc. rate me please
Aug 22, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
179 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
