I have a Carrier HFC-134a commercial chiller unit model 30HXA076RY-561AA. It runs 2 sides which are labeled A1 and A2. Over the past few weeks now the A1 side keeps shutting down (almost daily sometimes more often) with an alarm that says "A1 Failure - High Pressure Switch Trip". We've had a local hvac company come in to look at it a few times... One of them they were here for nearly 2 full days. They replaced some filters and did some diagnostics... Racking up a huge bill... But haven't solved the problem. It seems to me they either don't know what they're doing or they're trying to nickel and dime our company. If anyone can give me any suggestions it would be much appreciated. To me it seems like it would obviously be the pressure sensor in the A1 side as the actual pressure is dead on but I'm not experienced enough with this sort of thing to know for sure. Thanks ahead of time!
  • jack morton Mar 12, 2017
    Also, need to have your water loop checked out.
    Master:
  • Heating & Co... Master
  • 523 Answers
To start with, the more I look at a system, the more familiar I become with that unit. Also, these machines can make me look like a genius or a fool! If you have a pressure switch problem, it's more than likely an expansion valve issue. I've seen a 2 month old Carrier, 4 compressors at 6 tons each, fail due to their expansion valve having an intermittent miss, closing for no reason, or not opening upon demand. And I spent 3 weeks chasing this because when it fails, all you can do is see the code, troubleshoot a bit, call Carrier tech support, then reset it. I ended up calling out Carrier, yes they have field techs, and it took 2 of them about 5 hrs to figure it out. These 2 only work on chillers, and took them 5 hrs! They adjusted the settings and walked away from it, said it was cycling on to close(each circuit), had damaged the valve. Still under warranty but did not replace. If its not the cooling fan circuit acting up, it may be the expansion valve(s) acting up. In that scenario, the tech is going to need to camp out by the unit, and catch it in the act. If you get a second opinion, call a refridgeration company that has some background in chillers. Or call Carrier.Hope this helps!
Posted on Mar 12, 2017
KOakaKO
  • 135 Answers
SOURCE: Water dripping (almost running) out of the left corner of air handling unit. Help???
You're correct in checking the drain pipe, because it's become blocked. The only trouble is, you're trying to clear the wrong end. The condensate water is spilling out of the air handler because that's where the pipe has a clog. These pipes usually have un-glued joints next to the air handler, for times such as this. If you can't pull them apart, you may have to cut the pipes and reconnect tham with fittings from the hardware store. (which is a normal procedure.) I usually use a wet/dry shop vac when repairing this problem, sucking out the clog & the water, then blowing out the line to where it drains outside. I've also used the clothes hanger technique to drag crud out of the air handler fitting. Hope this is helpful. ;)
Posted on Aug 10, 2007
  • 230 Answers
SOURCE: A/C Fluctuating Pressures
I dont know what you mean by fluctuating. Do you mean small bounces? If so that can indicate non condensables like water in the line. It could be an indication of a weak compressor.
If they are slowly increasing and decreasing then the refrigerant levels could be the cause as well as a weak compressor. As 22 Yooper said. Make sure you are checking based on the superheat target pressures.
Posted on Jun 15, 2008
SOURCE: Goodman Model CK60-1C with White Rogers mercury tube thermostat
AIr flow is good. New filter.
Posted on Jul 29, 2008
SOURCE: Goodman GMS90904CXA Wont ignite, light blinks 3 times
I had the same problem, I had to remove the lower black rubber stopper right next to the exaust fan and hook up a drain to the unit, as soon as the water drained out the furnace fired right up.
Posted on Dec 11, 2008
rayname
  • 70 Answers
SOURCE: Goodman GMNT furnace goes into 'lock-out'.
check to see if your intake pipe or vent is clear this could cause a flame jump and make it look like a bad flame sensor let me know if this helps
Posted on Jan 08, 2009
134a american gas
Refrigerant HFC-134a or R134a
Weight 330 - 390 gms
With correct refrigerant:
Low side pressure 1.5-2.5 kg/cm2
High side pressure 14-16 kg/cm2
Sep 19, 2013 | 2011 Toyota Yaris
I WOULD LIKE TO KNOW COLOR CODE ON WIRING IGNITION SWITCH PLEASE. THANK YOU.
They all are not necessarily the same. What model and brand.
You must have the brand and model number to know this information. Some craftsman and their sister machines are connect as follows: B (battery) Red wire from fuse. G (ground -12V) L-black to reverse switch A2 Black to seat switch A1 blue to fuel shut off solenoid and hour meter M (magneto) grounds out ignition coil and connects to clutch/brake pedal S (start) white connects through clutch/brake pedal and attachment clutch then to solenoid.
The switch functions are: off M+G+A1
Run override B+A!
Rin B+A1 adn L+A2
Start B+S+A1
Aug 06, 2010 | Garden
Need to have a certain cell say OFF when it is a certain day
Use the test function.
Formula in cell A1 would be =text(a2,"dddd").
This would pick up the date from cell A2 and return the day of the week in cell A1.
Jun 06, 2010 | Microsoft Excel for PC
Model 30gx faults code
Hi, the indoor chiller unit blower section will have a sheet glued to a panel on the unit that will tell you where and what the code 302 means on the unit. Then you will be able to make the repairs you kneed.
Shastalaker7
PS the numbers above show that this is a 3 ton unit, 38CKC036. The error code more than likely will be 3 flashes from the board followed by 02 flashes. I may be wrong on that , so correct me if I am.
Mar 16, 2010 | Carrier 38CKC036 Air Conditioner
Need ref charge in ozs suct press at temp for superba 42
Refrigeration charge in grams will be found on the label with the model number and serial number. The type of refrigerant is also on this label and the type of refrigerant which is more than likely 134a. You can weight the gas in or you can charge to 10psi, then run unit and adjust up or down as required.
Mar 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Weight loss formula
Open excel and do the following...
A1: Weekly Entry B1: Weekly loss C1:Total loss
A2: Enter pound B2: Nothing Yet C2: Nothing Yet
A3: Enter pound B3:=if(a3="","",a2-a3) C3: =if(a3="",'',b3-b2)
Last thing you need to do is copy the cells A3,B3, and C3 and paste to the next row for every week.
Feb 24, 2009 | The Learning Company Achieve! Math &...
Excel formulas
hello
yes it is.
example
sheet1
A1 (50)
A2 (50)
sheet2
(A1)=
"=Sheet1!A2+Sheet1!A1" <-this is the actually code in sheet2 column A1
ok let me explain
in A1 and A2 in sheet1 you got 50 and 50 like numbers.
in A1 on Sheet2 you have = sheet1 a1 + sheet1 a2.
did you get it?
dont know else how I should explain it...
good luck
Oct 09, 2008 | Microsoft Excel for PC
Formular to show number and cell references
The formula for A1 is: =SUM(B4,B5)
A2 is: =SUM(C4,C5)
A3 is: =SUM(A1:A2)
To test this, put 25 in cell B4, 25 in cell B5, then 30 in cell C4, and 30 in cell C5.....the result in cell A3 is 110.
Hope this helps.
Mar 07, 2008 | Microsoft Excel for PC
Memory pairs
no place them this way if one kind is kingston or whatever a1 b1 and the other kind makes no difference as long as their in the right sockets/ a2 b2 these should be colored so if you have 2 of one kind and 2 of another you would keep them in the perspective colors ?dual ram is usually done this way you would have 1 gb in a1 and the other in b1
Oct 08, 2007 | ASUS P4S800D-X Motherboard
Heating & Cooling Logo
107 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
