Question about Cell Phones
No volume with my vbt2050 - Cell Phones
  • Cell Phones Master
  • 17,130 Answers
You will need to replace the earpiece with the same type after carefully opening using the rright tool Pleae attempt to do this only if familiar or else keeping this view in mind get an estimate with two service centres before you decide.hope this helps. good day
Posted on Jul 04, 2010
Vbt2050 jabra motorola - i need ear hook replacements
have you tried searching for a replacement on AMAZON or EBAY
Feb 22, 2010 | Cell Phones
HK-760 Bluetooth dongle, pairs with my HP computer but after inserting the passkey, the computer starts searching for the peripheral device drivers without which a connection between my jabra VBT2050...
This device, according to the Jabra website, is intended only for phones, not PC's. The PC is searching for a driver in order to know how to communicate with the device. Since the VBT2050 does not have the necessary software contained within itself, the PC starts searching for device drivers. There are none that I could find on the Jabra website, so I don't think it is intended to be used with a PC.
Feb 20, 2010 | Adapters.com Bluetooth USB Adapater, USB...
Vbt2050 jabra codefor blackberry bluetooth
Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Sep 27, 2009 | Jabra BT5010 Bluetooth Headset Wireless...
My jabra vbt2050 will not go into pairing mode. I hold the on off button down for 5 seconds and the light just flashes three times then waits and flashes three times and so on. I cant get the light to stay...
Taken from another headset fix here at fixya - worked for me w/VBT2050 Mar 09, 2009- had the same issue...but i never got any notification that something was wrong or needed to be repaired...holding the volume up and down and call answers buttons all at the same time works!! Wait til the light is on constantly...and then follow the bluetooth menu on ur phone. Awesome fix!-
Jul 18, 2009 | Jabra Bluetooth Headset with Adjustable...
Is the jabra VBT2050 compatable with the blackberry storm?
should be . all Bluetooth devices should be compatible i believe.
Apr 26, 2009 | Jabra BT350 Bluetooth Headset Headset
Jabra VBT2050
The above solution only lacks one small item. Part of the pairing procedure is to hold the on/off button for the recommended 5 seconds to power up, but the light will NOT become constant until you hold both the power button AND the round center button on together until the light remains constant. Then you can pair the two devices.
Jan 27, 2009 | Jabra BT250 Consumer Headset
Jabra VBT2050 Not detecting
On The Blue Tooth You Have To Hold The On Off Till The Light Flash's Blue Red Over And Over Then Search For It On Your Phone.
Once You Find It It Will Be Recognized For Now On. Just Hit The Button On The Blue Tooth One More Time To Stop The Sync Mode.
Jan 19, 2009 | Jabra BT350 Bluetooth Headset Headset
Jabra VBT2050 headset won't pair with blackjack II
ARE U FOLLOWING THE CORRECT PAIRING PROCEDURE
pls follow this
ok here u go first turn on the bluetooth func in ur mobile, now while ur bluetooth headset is off press the power centre big button for like 10 sec until the blue light stays on continously not blinking position ok then search for bluetooth devices in the phone bluetooth config ur headset will come up like JABRA VBT2050 select it then it will ask u for pairing code input 0000 and press ok ur device is now connected u will see the blue light which was continous b4 now blinking it means ur haedset is connected , u have to complete this process in almost 1 min bcoz there is a timeout for this process , now try any call u will hear it in ur headset
pls rate me fixya for this if it helped
Jan 13, 2009 | Motorola Mobility H350 Wireless Headset
Setting up Jabra VBT2050 Bluetooth
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
Dec 26, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra vbt2050 won't connect
Jabra VBT2050 - You have to hold the round button in until the light stays lit (about 20 seconds) this will put it in discoverable mode, the pin is 0000, I have AT@T service and it works just fine. Hope this helps out!
Dec 21, 2008 | Radio Communications
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
