Question about Canon Office Equipment & Supplies
We have a Canon ImageCLASS MF6590 and its only about a year old, with light usage. It keeps getting paper jams. I have tried to clean the rollers with an alcohol swabs but that hasn't done any good. What can I do?
  • 2,427 Answers
Well this happens when the rollers themselves wear off....
`.) try fanning the paper before placing in machine
2.) store paper in a warm dry place..
3.) the feed treader (where you place the paper) it has feed gears,, clean the gears..
If those fail the rollers have warn too much,, you will need to replace them,, they are consumable parts..
Posted on Jul 04, 2010
  • kathrynhills Jul 04, 2010
    I've fanned the paper, used several different types of paper, cleaned the rollers. How do I clean the gears?
My Canon ImageClass MF6590 keeps flashing a message " Check Document". There was a jam in the Top document feeder tray but it has been clearsd now. My printer will not take but half a page before jamming...
That suggests either that the jam or clearing it physically damaged something, or that despite looking carefully there is still at least a little bit of paper jammed in there somewhere. I do't know how often my printers have jammed on something very much smaller than my little finger nail...
Feb 04, 2014 | Canon imageCLASS MF6590 Copier
Canon imageCLASS MF4350d paper jams
can you be specific, where does paper jams occures?
If in adf, try to clean the adf pickup rollers, if in cassette, open the printer and remove the toner cartridge, now you are able to see the pick up roller from the cassette and clean him with alcohol or water.
Hope that helps!
Jun 14, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
Feeder takes paper in partially then stops feeding
Hi, clean the rollers with alcohol, and check for any foreign material inside adf.
Jul 17, 2010 | Canon imageCLASS MF6590 Copier
Imageclass mf5530 jams from paper tray, bypass
Clean the pick up roller, try to see where is stuckes. In some cases the roller holders breaks down and roller wont turn.
Jul 04, 2010 | Canon imageCLASS MF5530 All-In-One Laser...
Canon MF6590 stuck in processing/data mode. Answers fax, but does not print. Go to copy, sticks in scanning mode. Powered off. No change.
Check whether any piece of paper is stuck. This may due to paper feeder/out roller may having the issue. Replace/repair will resolve your problem.
Thank you for using Fixya.
Jun 21, 2010 | Canon imageCLASS MF6590 Copier
Document too long error message during 2 sided print job
clean all paper pick up, feed and separation rollers. That means that paper is "late" on sensors.
But you also should check the sensor flappers. If they are worn out replace them, the problem also can be the flapper of registration sensor.
May 23, 2010 | Canon imageCLASS MF6590 Copier
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
PAPER JAM ON LEFT SIDE, PAPER DOES NOT COME OUT
Open the left cover and inspect the paper tray and the fuser unit.90% paper jam in the fuser/exit unit.Inspect and clean the rollers and the fingers.
Oct 02, 2009 | Canon imageCLASS MF6590 Copier
False Paper Jam Signal Canon MF5730
Try changing the quality of your paper.
Roughen up the rollere guides a little to you get better grip. Clean rollers with alcohol and use a green scrub mit to lightly rub the surface of the guide reels.
Hope that helps yours work too
Please rate our help to keep service online
Aug 19, 2009 | Canon imageCLASS MF5730 All-In-One Laser...
35 people viewed this question
old marine
old marine
