Question about Kenmore Elite Oasis 27052 Top Load Washer
Will not agitate or spin. it just makes a horrible buzzing sound
My machine will not agitate. It will only make a buzzng sound. the sound gets softer as i change the settings from regular to delicate. I will not spin, but it will fill and drain
  • oldguy5 Jul 05, 2010
    Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
  • 1,557 Answers
Its either a broken drive belt (if it has one ) or the gearbox is either not engaging or is slipping
Posted on Jul 06, 2010
My washer started to make horrible sound when it tried to agitate. After draining water n removing clothes i tried just starting from rinse cycle. It filled up. It agitated w horrible sound but will not...
mine did this to me, need a new agitator. dependin on the age of yur washer, might need a new washer. it is a decision up to you. I bought a new set in the end, cost of part & time to install. Besides the age of the washer was a consideration i considered.
Mar 08, 2015 | Washing Machines
My portable top load kenmore washer model 110.42722200 won't spin. It drains water and all the light functions work, but it only makes a humming sound like it is stuck when it gets to a spin cycle and does...
I just repaired this exact model this weekend. If the machine will drain but doesn't agitate or spin (you have to put a screwdriver in the lid switch to see), it's usually a loose belt. This time I replaced the belt, but it still would not agitate or spin, and the motor was not turning, just a "buzz, buzz, buzz" when the washer attempted to supply power to the motor. The start capacitor for the motor was bad. Part number 3429938 which runs about $60. Not hard to access once you tip the washer over slightly, just DISCHARGE THE OLD CAPACITOR so you don't get a nasty shock.
Aug 05, 2010 | Washing Machines
Washing machine will not agitate or spin
If you can hear a buzzing sound during the spin cycle and yet the agitator is not spinning, then there is a problem on the motor itself. maybe you should change the motor or its windings.
Jan 03, 2010 | Hotpoint Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
"jackhammer" sound coming from my washer
# Balance the load
# Level the machine
# Inspect the water pump for a blockage
# Inspect the coupling
# Inspect the transmission
# Adjust the drive belt tension
# Check the motor bearings
# Check the drum brakes
Jan 09, 2009 | Washing Machines
Roper washing machine
roper washer made a buzzing sound when spining
Mar 30, 2008 | Roper RAX4233PQ Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
323 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
