Question about Kenmore 22422 Top Load Washer
Actuator switch on the lid fell off, how do I fix it?
  • 5,911 Answers
If you are referring to the lid switch, it is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If the switch has come completely off , or if you determine the switch to be defective, the following link explains how to access and replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price of a replacement lid switch is about $20 - $30 if you perform the repair yourself. Prices will vary between sites so shop and compare. If you have questions, or need additional assistance, please post back with your complete MODEL NUMBER and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on Jul 04, 2010
Testimonial: "Wow!! Thanks for the quick and most helpful response. We got the new part from Sears and hubby has installed it already. Thank you soo much for your help!!"
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section for the cabinet and you should see the Lid Switch:
Next see the following for how to release the console, unplug the Lid Switch and remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=674cce697ea638332f3f0d46dccfb223
If the screws holding the switch have simply come loose, you can re-tighten them. Otherwise, you may want to use a slightly larger screw to hold the switch in place.
2008 Cadillac CTS push button to open trunk sometimes works
Do you know anything about automotive electronic's ? The trunk release is controlled by electronic control modules . Having the vehicle check for DTC'S - diagnostic trouble code's should be the first step in the diagnostic procedure . Then reading how it work's !
Factory service repair info.
Rear Compartment Lid Release System Components
• Body control module (BCM)
• Remote control door lock receiver
• Interior rear compartment lid release switch
• Exterior rear compartment lid release switch
• Rear compartment lid release actuator
• Trunk release relay
Rear Compartment Lid Release Operation
The interior rear compartment lid release switch receives a signal from the driver door switch assembly (DDSA). When the interior rear compartment lid release switch is activated, the signal circuit is pulled to ground. The DDSA interprets this and sends a GMLAN serial data message to the body control module (BCM) requesting the rear compartment lid be released. The BCM responds by applying battery voltage to the trunk release relay control circuit which energizes the TRUNK RELES relay. The trunk release relay is supplied with battery voltage at all times. With the relay coil energized, the relay switch contacts close allowing battery voltage to flow to the rear compartment lid release actuator causing the rear compartment lid to release. The rear compartment lid release actuator is permanently grounded at G402.
The trunk release relay is located in the rear fuse box located under the back seat.
Dec 23, 2017 | Cadillac Cars & Trucks
Can not open trunk on a pontiac soltice. No clicking sound from remote or switch in glove box fuses are ok
The rear compartment lid release system consists of the following components:
• Folding top cover actuator
• GMLAN serial data link
• Keyless entry transmitter
• Rear compartment lid ajar switch
• Rear compartment lid release switch
• Remote control door lock receiver (RCDLR)
• Trunk fuses
Rear Compartment Lid Release System Operation
The rear compartment lid can be released by operating the rear compartment lid release switch or pressing the rear compartment lid release button on the keyless entry transmitter. When the rear compartment lid release switch is operated, the rear compartment lid release switch signal circuit to the body control module (BCM) is switched to ground. The BCM receives the rear compartment lid release switch input and applies ground to the trunk release relay control circuit. This energizes the trunk release relay coil, closing the switch side contacts, allowing battery voltage to be applied to the rear compartment lid release actuator and folding top cover actuator, releasing the buttresses and opening the rear compartment lid. Ground for the rear compartment lid release switch is provided at G300. The rear compartment lid ajar switch, rear compartment lid release actuator, and folding top cover actuator are provided ground at G301. The rear compartment lid will not release until the vehicle speed is zero and in park.
Do you know what DTC'S - diagnostic trouble codes are ?
DTC B3265 01 : Trunk Relay Output Short to Battery
DTC B3265 06 : Trunk Relay Output Short to Ground or Open
Do you know what a relay is an how it works ? TRUNK release relay located in the underhood fuse / relay box.
VEHICLE RELAYS Operation Diagnosis
Jul 22, 2017 | Pontiac Cars & Trucks
Spin cycle doesn't work on washing machine
If this is a top loader then check the lid switch. A common failure is the lid switch fails.
Inspect the lid to make sure the plastic component "Lid Switch Actuator" Has not broken off from the lid. The actuator protrudes through the hole identified by the red arrow above and actuates the switch. A quick check is to listen for a distinct click as the lid closes.
No click no spin. With click if switch bad no spin. A qualified technician needs to replace the switch if bad. The lid removes easily of course power must be off by unplugging the washing machine.
Dec 21, 2015 | Washing Machines
How to replace lid switch on maytag atlantis washer
see the video, and fix it. God bless you
Sep 25, 2012 | Washing Machines
My Roper top loading washing machine won't spin. I've determined the little plastic "nail" in the lid isn't connecting. If I push down in the hole the machine will spin. Any way to...
Hello Cathy,
The" little nail"...lid switch strike is very easily replaceable ..they are slightly different by model,reply with your exact model number and i will give ya the part number for it. The model number is going to be on a label on the rim inside of the lid area
GENE
Aug 28, 2011 | Washing Machines
Center peice will not turn
If everything else is working and it just won't spin, there is good chance that all that is wrong is a bad lid switch or the lid switch actuator. The lid switch's location depends on the brand and model. But usually you can find a little slot around top of the washer where the lid closes. You should be able to push a pencil into it and here it click. That is the switch. On the lid, there should be some type of actuator (stick that goes thru the hole) when it is closed. On older Whirlpools, the actuator was bad about popping off and falling into the tub. On older Maytags, the switch is behind the lid..under the lip.
When the switch if broken or the actuator doesn't actuate the switch, then the machine thinks the lid is open and , for safety reasons, won't allow the drum to spin. If you can't find the switch locally, you can order it online.
Hope this helps
Jan 21, 2011 | Washing Machines
The cycle will not go into the next cycle unless I press on top of the lid to get it to the next cycle. Is ita repair that can be fixed?
Yes, unscrew the lid switch actuator and put some paper shims in between the base and actuator, listen for a click when you close the lid
Jun 12, 2010 | Whirlpool LSR5132PQ Top Load Washer
When checking out the lid switch on my roper washer as jsrock suggested in another post, i heard a screw drop from the inside of that area which caused the lid switch to become unmounted completely. also,...
Top lid pull up. Look in seam between top and front cover. On each side you will see where top clips to front cover. Put a screwdriver in there and lightly pry up till clip releases. Front cover will now pull up and be removed, so you could get what fell in.
Jul 26, 2009 | Roper RAS8445KQ Top Load Washer
Machine stops after wash cycle, restarts when i bang the lid.
sounds as if hte lid switch is not activating correctly, the lid actuator is actulle hte under side of left hand door hinge. if you lkift the lid and feel under the left side og the lid you fell the metal lid hinge, simply slip a hollow shafted screwdriver over the hingeitself and bend slightly back, this will make the lid come in contact with swict a little bit easier
Dec 12, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Thin Twin washer/dryer
Check the lid switch, the machine will not spin or drain without the lid switch being activated. You should be able to see if the switch actuator is broken or missing, look in the slot where the lid's plunger drops into, if you can see the gray plastic actuator, set the machine in the spin cycle and try to depress the switch with a flat screwdriver, if it runs, the switch is cracked and needs replaced, if the actuator looks fine, and you can hear a distinct "click" when you press down on it, it may be a problem in the timer, but check the lid switch first, that's most likely the problem.
Sep 18, 2008 | Whirlpool LTE6234D Top Load Stacked...
Kenmore 22422 Top Load Washer Logo
129 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
