Question about Protron PLTV-32 Television
Tv just turned off and will not come on.tv was hot on screen side.
Is the little red light in front of the tv on? If it is not, it could be the power source. That happened to my PLTV-3250. I found replacement at Shopjimmy.com, and it is less than $118.
Posted on Jul 12, 2010
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 72 Answers
It may be the external in-line power blocks which are very hard to come by. However, I have managed in the past to find ones for my customers.
Here is a link to one source I have recommended several times for customers:
Click here=> AC/DC adapter
Price is $118 USD plus shipping.
Posted on Jul 04, 2010
My 55ld520 screen goes black, turn off for short time comes back on but then goes black again.
Start simple by using different cables, whether they be HDMI, VGA or standard COAX cables. They could be losing the connection. Also, it's possible the power supply is wearing out and it gets too hot. You might want to simply try some spray air duster type thing to clear out any dust that can make it hot.
Sep 20, 2014 | LG 55LH40 55 in. LCD HDTV
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Tip
TV shows either: black screen with: white vertical or, horizontal line
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
Dark Screen
It sounds like a back-light problem. Check all the CCFL back-lights.
May 08, 2013 | Samsung LN52a750R1FXZA
Tv screen is hot
A moderate heat will be generated while LCD TVs, when they play for long time. it is allowable. The heat generated is from its back light CCFL lamps. Do not cover the set with any type of coverings when it works. Keep a distance of at least 6 inches between wall and the back side of the TV.
Jun 20, 2012 | Vizio E550VA 55 in. LCD TV
Have a rca mcr66r400 tv set found a blown fuse on the +145v line replace fuse but still tv set wont turn on! hot is good
a risistor burn out and cannot reconised the number the two sides of the Tv screen is closing in
Oct 05, 2009 | RCA Televison & Video
Tv wont turn off or change chanells,sound up or down with remote or the side of tv
check the power supply and HOT if good ,re solder your tv maybe there's a lose connection
Sep 10, 2008 | Samsung DLP HL-P5663W 56" TV
Sanyo tv has trouble turning on... clicks self off
replace the electrolytic capacitors in the hot side of the power suply.
Jul 09, 2008 | Sanyo DS19310 19" TV
I keep blowing HOT on my Mitsubishi WS-65857
the high voltage splitter!!!!!!!!!!!!!!!!!!1
no dought! good luck
please mark the post with a fixya
Feb 08, 2008 | Mitsubishi WS-65857 65" Rear Projection...
Protron PLTV-32 Television Logo
79 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
