Question about GE JE1390 Microwave Oven
Yesterday my GE JE1390WA, stopped working. After being dead for about 30 minutes it came back on, but sounds like a fan is continuosly running and says RESET. If I do nothing it makes fan noise for a while and then dies again. If I unplug and plug back in it says RESET and if door is shut it makes fan noise. This happened last year and I called repair person. He opened it up, Plugged it in and it worked, he shrugged and said no problem and collected $75.
  • GE Master
  • 17,129 Answers
Please disconnect the set, open the cover of the oven , then the front panel assembly. Inspect carefully for any signs of insect/ coakroaches within the set, if so use a good blower to clean the inside, use a hot air dryer to warm for any insect dirt. once you have finished checking for any loose connections and the clean status, close the cover back and check on the set. If it does not work well try settting the clock and test. Hope this helps. Good day.
Posted on Jul 04, 2010
Why is my GE Advantium SCA2001 blowing the main fuse?
Yeah pal, you've not gone deep enough yet. You'll find a power wire bare inside the unit, pull it apart and tape that wire up to stop it from grounding out and blowing the fuse.
Aug 31, 2014 | GE Microwave Ovens
ONLY 3 YEARS OLD, SHUTS OFF COMPLETELY AFTER ABOUT 3 MINUTES, THEN DISPLAY COMES BACK ON ASKING TO SET CLOCK
How long does it stay off? 30 to 60 minutes?? Sounds like the cooling fan is not working or air vents on the unit are blocked.... I saw one unit years ago with this complaint that when the customer turned on the MWO, the fan came on and pulled a curtain covering the pantry up to it, blocking the air flow and causing it to overheat and shut off....
Sep 11, 2009 | GE Microwave Ovens
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Microwave dead even though power works
It sounds like the magnetron overheated and opened the thermal fuse on the magnetron.
This can be caused when the internal cooling fan is not running or by a magnetron that is failing.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
The magnetron will have a 5 to 9 year warranty. Your manual will tell you that.
You can download GE owner's manuals and installation instructions here.
If needed, GE may send you a replacement magnetron. GE Customer Service is here.
Dec 04, 2008 | Microwave Ovens
Works up to about 5 min. then waits about 20 min. to cook again. HELP
When you say shuts off, do you mean it goes dead as if someone unplugged it, or does it stop as if someone hit the Stop pad?
If it is going dead, it sounds like the magnetron is overheating and opening the thermostat.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Sep 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My ge microwave after running for about 3 to 4 minute it shuts down and will not start up again for 30 minutes model # TH903659B JVM 1650 JVM 1651 what is the problem thanks
If the fan comes on when you put the unit into a cook cycle and all sounds normal otherwise, you most likely have a bad magnetron tube. (Google "GE magnetron failure" and watch how many complaints and articles pop up). The tube overheats and trips the thermal relay causing the unit to shut off until it cools back down and comes on.
Very, very common problem on these models although GE will not admit it.
Jul 11, 2008 | GE Microwave Ovens
Ge spacemaker xl microwavejvm1840
It sounds like two separate problems.
1. It sounds like your magnetron is overheating and then the thermostat trips, cutting the power until it turns off, then it closes to power it back up.
It's essential that the internal cooling fan (I don't mean the hood / vent / exhaust fan) is running to be sure the magnetron stays cool.
2. It also sounds like your vent / hood / exhaust thermostat is sticking or the triac on the circuit board is leaky, causing the vent fan to stay on.
But you may want to check the owner's manual. It is designed to stay on if the temperature of the stove top is above a certain level.
-.htmYou can usually find helpful exploded view diagrams and order parts by entering your full model number here.
-.htmPlease reply back here if you still need help.
-.htmWe're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL 1800 touchpad motor sound
that sound comes from fan motor, please replace or service fan motor ..
Sep 25, 2007 | GE XL1800 1100 Watts Microwave Oven
GE JE1390 Microwave Oven Logo
244 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
