Question about Bose Wave Radio
I have a bose wave music system (radio and cd ) I can not get the remote to work I actually have 2 remotes because this happened before Is there any way to reprogram the remote and yes i have changed the battery
  • 10,319 Answers
I have no idea of the exact model you have since they have been produced since 1985. Older Wave Music System & Acoustic Wave Music system II require a CD software update to work with this accessory. The Wave Radio II cannot be updated and the accessory will only work with systems made after a certain manufacturing date.
Posted on Jul 04, 2010
Wave radio comes on randomly
Random is truly a difficult problem to solve, if no pattern of failure can be detected. It sounds as though the alarm may be at fault. Is the alarm on and set to radio, CD, or beep? If radio, that could pinpoint the problem. If you have another, mechanical alarm, use it for a couple nights with the Bose Wave alarm off. If the Bose still acts up, then it isn't the alarm. Try unplugging the unit, waiting at least 30 seconds, and plugging it back in, which will cause you to need to reset the alarm. Alternately, remove the Bose cover and blow out dust. I find the Bose susceptible to dust as a cause of malfunction, which may point to the cause being the compact design of the unit. Good luck.
Jul 09, 2013 | Bose Wave Music System CD Shelf System
Lost remote control for bose wave model number AWRCC1 will the additional bose acoustic wave music system remote control work
Check this site to get setup codes and model number of a suited universal remote control. It has many details you want. Check this site too.
Apr 21, 2013 | Bose Wave radio remote control - Graphite...
I own Wave Redio/CD. My new remote is Wave Music System and does not work. Why not?
The Bose Wave Radio and Wave Music System use different IR codes. It is no other reason other than Bose made the remotes incompatible. This is often done to prevent interferance with systems that may be close to each other.
Jun 10, 2011 | Bose Televison & Video
My bose wave system is no responding to the remote. Anything I can do?
The only user serviceable part of this fine system is the battery in the remote. The battery used in most of these remotes is the "button" or "coin" type cell "CR-2032"You can find these at Walmart, Radio Shack, CVS etc. for just a few bucks. Bring the remote batteries with you to match to a replacement.
If that doesn't work, you may need a replacement remote or the radio may need repair.
Sep 21, 2010 | Bose & Wave& Music System
The remote for my Bose Wave radio-CD no longer works. I have changed the battery and put a new battery into another Bose remote--no luck and I want to play my Christmas CDs! Help!
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug it back in
  • Make sure you’re pointing the remote directly at your Wave® music system. If the system is placed above table-top height, be sure to angle the remote upward while pointing
  • Check for possible sources of interference with the remote’s infrared (IR) signal, such as bright lights or solar glare off of a window. Make sure nothing is blocking the path of the signal from the remote to the Wave® music system display. The remote will not work properly if there is something directly in front of the display
  • Wipe off the small clear lens on the front end of the remote
  • The remote is designed to work within 20' of the system. Greater distance may cause intermittent response
Dec 05, 2009 | Bose Wave Radio
Can the new 5 cd changer work with the older Bose
It will work as a manually-operated AUX input, but since there was no remote for the original system so that function won't be available.
Nov 29, 2009 | Bose Wave Music System CD Shelf System
CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Jun 28, 2009 | Bose Wave radio/CD remote control -...
Bose wave music system
Check remote and replace its batteries.
Does this remote work on any other device?
Sep 16, 2008 | Bose Wave Radio
Remote control of Bose WaveMusicSystem
First have the remote tested. You can buy a basic Infra-red tester at Radioshack for about $6. If the remote is putting out signal, the Bose will have to be serviced. Call them and get an RMA # and they will fix it for a flat rate.
Sep 20, 2007 | Bose Wave Music System CD Shelf System
Bose Wave Radio Logo
167 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
