Question about HP OfficeJet G85 All-In-One InkJet Printer
Feeds more than 1 sheet
This printer feeds 2 sheets instead of 1.
  • 39 Answers
Yes, I have had the same problem at times. The best solution is to 'fan' the paper well (put air between the sheets) BEFORE putting it in the tray. Also, tap down the front edge of paper (that enters the printer) to align the sheets better. You can also clean the rollers with a damp rag to help traction. Hope this helps!
Posted on Jun 24, 2008
DP80F FAX WILL NOT FEED ONE PAGE AT A TIME. IT WILL TAKE 1 PAGE , 5 PAGES , 2 PAGES . HOW DO I FIX THIS MACHINE TO FEED ONE PAGE AT A TIME
Potential solution: When putting in several sheets of paper, grab the sheets by one end, and fan the papers (spread them) at the other end. Reverse your grip and do the same thing to the other end.
Reason: paper is cut by a shear. If the blade of the shear is not perfectly sharp, it crushes fibers into the edges of the adjoining sheets. This causes the sheets to misfeed in the random way you describe. Ruffling the paper before putting it into the printer separates the pages so they will feed properly.
Nov 07, 2011 | Toshiba DP80F Printer
Hi Canon LBP 1120 paper feed and paper jam problem: My Printer mostly take in multiple paper sheets instead of taking just one sheet. Sometimes the extra sheets are taken in while the printing sheet...
You need new pickup rollers
google search "LPB1120 pickup rollers" and find your nearest dealer. usualy quite easy to replace as long as your a "can do" person
Mar 18, 2011 | Canon LBP 1120 Laser Printer
How to install paper in oki microline 320 turbo printer
Paper Loading
Rear Feed, Continuous Forms
Use the rear-feed path for printing on single-thickness,
continuous-form paper.
Use the single-sheet path (top feed) for graphics or charts.
! If you have paper in the paper path, be sure to remove it
before installing rear-feed paper.
1 Lock Lever
2 Upper Tractor Cover
3 Pins
4 Lower Tractor Cover
32T-26.eps
1 Move the paper lever to the position marked "REAR."
32T-11.eps
2 Grasp the tabs lift off the paper separator.
3 Pull up on the lock levers and open the tractor covers.
Then, move the right tractor to fit the width of the paper.
32T-27.eps
4 Place the first two holes in the paper over the tractor pins
on either side. Close the tractor covers.
32T-29.eps
5 Move the left tractor to align the edge of the paper with
the appropriate reference mark (1). Then, push back the
lock lever.
32T-29A.eps
6 Adjust the position of the right tractor to center the holes
in the paper on the pins. Then, push back the right lock
lever.
32T-29.eps
7 Install the paper separator. Place the wire guide (1) on the
pull-up roller assembly (2).
32T-31.eps
8 Press FF/LOAD. The paper feeds into the printer.
! The factory default setting for the Top of Form (where
the printing should begin) is one inch down from the top
of the page. To change the setting, see "Using Your
Printer, Top of Form (TOF)."
Top Feed (Single Sheets)
Use the single-sheet path for letterhead stationery, memos,
and individual envelopes.
! If you have continuous-form paper in the path, press
PARK to remove it before loading single sheets.
1 Make sure the printer is on and deselected (SEL light off).
2 Place the paper lever in the position marked "TOP."
32T-12.eps
3 Open the carriage cover. Raise the paper separator to the
single-sheet position.
4 Make sure the wire feed guide (1) is secured in the sheet
guide.
5 Adjust the paper feed guides (1) for the width of the paper.
Place a sheet of paper in the separator. The paper will feed
into the printer.
32T-15.eps
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 04, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
The scanner takes 2 sheets of paper at a time instead of 1 so only 1 is being scanned. I've tried a different paper that is thicker than regular printer paper and it's still doing it.
There is a pad below the feed roller that wears out. It is called a ****** pad, it retards the feeding of extra sheets of paper. That pad will need to be replaced. Once it is it will stop multisheet feeding.
Apr 01, 2010 | Xerox DocuMate 152 Pass-Through Scanner
The paper isnt going through
If the paper feed rollers are not clean, they may slip and cause paper feeding problems.
The problem may be alleviated by performing paper feed roller cleaning.
1. Open the Printers folder.
- For Windows XP Home Edition Click/Select "Start," "Control Panel," "Printers and Other Hardware," and "Printers and Faxes."
- For Windows XP Professional Edition Click "Start" and "Printers and Faxes."
- For Windows 2000/Me/98 Click/Select "Start," and "Settings," then "Printers."
2. Right-click the icon of the printer for paper feed roller cleaning, and select Properties from the displayed list.
3. Click the Maintenance tab and click Roller Cleaning. 4. Remove all sheets of paper from the auto sheet feeder, and click OK. 5. Confirm the message to be displayed, and click OK.
Do not try other operations until printer's operation completes.
6. When the printer's operation is completed, follow the confirmation message to load three new sheets of A4 or letter-sized plain paper in the auto sheet feeder
7. Click OK.
8. Confirm the message to be displayed, and click OK.
Do not try other operations until all the three sheets are ejected.
Memo: The printer prints nothing on those sheets.
9. When all the three sheets of the paper are ejected, paper feed roller cleaning is completed.
10. Click OK.
Performing Roller Cleaning is completed.
Nov 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My HP C6180 sometimes pulls 2 sheets from the ADF instead of 1 at a time when copying multi-paged document.
Get some resin powder ( or similar) rub onto the feed in rollers  they get shiny and don't grip properly. Inkypete
Apr 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
SOLUTION(S): Reset the Sheet Feeder Gears
If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
home position, which may not be possible if the paper stop cam is not in the correct position.
PROCEDURES
1. Remove the sheet feeder from the unit.
2. Remove the sheet feeder motor from the sheet feeder assembly.
3. Remove the drive gear from its spindle.
4. Realign the lifting tray gear and paper stop cam gear.
5. Reinstall the drive gear and sheet feeder motor.
6. Reattach the sheet feeder to the print unit.
7. Reassemble the unit.
Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Printer feeds 1 and a half pages and jams every time.
PUT 1 sheet in at a time nd it will be fine
just dont put loadz in at da same time
Oct 17, 2008 | HP Officejet 5610 All-In-One InkJet...
Sheet feed
Shuffle the sheets and 'Fan them before inserting into the slot.
Dec 09, 2007 | Lexmark E323 Laser Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
130 people viewed this question
Seeker5211
Seeker5211
