Kenmore All in One Model#417-89870800,removal of agitor.
  • wue2 Apr 18, 2008
    Bolt was on inside of cap,top of agitator underneath it is flat with a nut imbedded in it.
    Genius:
  • 1,028 Answers
Half inch bolt in center of agitator under cap remove then pull like crazy
Posted on Apr 18, 2008
How do I remove agitor to clean the filter. Our clean clothes have a much lint on them when they come out of the washer
Most agitators in top load washers are push on and hold on tight that way. There is space for you to insert fingers under the base of the agitator. Put fingers of each hand under opposite sides under the bottom, grab tightly, and pull up under control. The agitator should come out. Hope this helps. Unless you have the written instructions in your book that says otherwise. Good luck and let me know if it helps!!!
Apr 18, 2013 | Kenmore 24032\24036 Top Load Washer
Have a Kenmore Model 110, water leaks from the bottom. Want to disconnect the agitor from the motor . How is done. How do I dismantle it
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
Dec 18, 2010 | Kenmore 22422 Top Load Washer
I have water leaking from the bottom back of the machine during the rinse cycle i think
See the following:
If the hoses are fine, I'd also check the gaskets at the bottom of the tub.
Jan 06, 2010 | Kenmore 24032\24036 Top Load Washer
How do you get the inner tub all the way out of a old whirlpool machine.
First you must remove the agitor then you see a large nut tighened down wedging the inner basket down it would be best with a spanner and hammer wrench but if careful can be removed with a flat square metal rod and hammer once unscrew pull up and out to remove
Dec 05, 2009 | Whirlpool Washing Machines
Loose washer drum, load noise on spin cycle
your basket hub is stripped and to gain has a specific tool to remove and not destroy the locking nut for basket the agitor and items need to be removed it may be best to call a tech in your area
Sep 01, 2009 | Kenmore Washing Machines
The agitor is locked
Try unpluging the maching then start the wash from the the start. Here is the manual.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/8566930.pdf
Aug 12, 2009 | Whirlpool Washing Machines
CHANGEING THE BOTTOM BLADES OF THE AGITOR
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 11, 2009 | Kenmore Washing Machines
Washer not spinning
Is the agitator not agitating or is the whole tub not spinning? Does it drain? Ill post a tutorial for replacing agitator dogs tomorrow. It will be posted under tutorials here. www.shop.washermd.com Dave
Jan 14, 2009 | Kenmore 24902 Top Load Washer
How do I replace the dog agits on a Kenmore model # 92597200? I have the agitor out of the machine but I need to know how to get the dog agits out.
pull your top and bottom of the agitator apart then the holder for the dogs should fall out when you turn it upside down
Jan 07, 2009 | Kenmore 24902 Top Load Washer
Washing Machines Logo
457 people viewed this question
Top Washing Machines Experts
