I bought a Vizio model VF550H 55"LCDHDTV120h from ebay. It worked great the first 6 hours then it started powering off every 30-60 minutes. It will not power on immediately, could take up to 1 hour to power on again.
  • Donald DCruz
    Donald DCruz Jul 04, 2010
    Since it is a new purchase , you must be having a warranty on the machine and hence do not attempt to do anything so as to cancel the warranty. I suspect that it is apoweer related fault and could be expensive, hence call up and fiile a complaint immediately. Good day
  • nc_cif Jul 05, 2010
    No, I have stated very clearly that I bought this tv from Ebay. If it was a purchase with a warranty, I am not so dump not to know that. I have also stated that the problem is power related unless you ddi not care to read or understand the problem. It is powering off after about one hour of clear pictures. It will not power on for a long time. Sometimes it's taking over one hour to power on and when it does, the previous channel comes on. So the problem is power related!!. I paid you to resolve a power relate problem. I did not pay you to tell me that the tv is powering off because of a power related problem. That i already know!! So can you solve the problem as you promised in your advertisement or can I have my money back, please?
  • Televison & ... Master
  • 17,130 Answers
Sorry, I am trying to help but with the clarification.Knowing that you are aware of the fault I would suggest that you strt your check from the area of the Power driver, Switch mode transformer and the Main capacitor.Please check on the +B at the time of power off. If the main voltage stays and if the sub supply votage to the processor also is in the standby mode, then you will have to check on the timer cut off output from the processor. Assuming that you have not set up the delay timer off , you will have to check for the switch on/off trigger from the processor. Another component that could be erratic could be the the optocoupler that switches the SMPS. If you can test the voltage on switch off , it would be confirmed. Please check these voltages , look out for any heating components that could detach on heating and on cooling resume the connection, this could be the wire wound resistors, coils or the power drive transistors/ diode. Please smell for any such heating but please do it with caution when the power is connected.
I am sure you understand that that could be several related component weakning in this complaint which will require a through voltage test analysis when the set comes to the fault. So make a note of the voltages during the working condition and do the same during the failure time, make this note and check the area relted to the switch-on/ off that is the trigger from the processor/ the optocoupler/ the feedback from the error amps.Another way to get this culprit is to use a freezing spray on the suspected area which is showing a thermal runaway. If on cooling the set jumps back to power(do this spray only with power off) Probe on to get the defective component... check onthe electrolitic capacitors in this area.
I have responded only thinking that an inexperienced check could sometimes prove expensive. So it is only an advise to go about. I hope you will take this test with caution.Good Luck. Good day
Posted on Jul 06, 2010
What are the symptoms of a bad psu for vizio m550nv
Vizio 0500-0612-0030 Power Supply / LED Board for M550NV
www.shopjimmy.com/vizio-0500-0612-0030-power-supply-...
ShopJimmy
$77.42 - ‎Out of stock
This Vizio 0500-0612-0030 Power Supply / LED Board for M550NV (0500-0612-0030) works for these ... The odds we'll get it soon: Bad (What does this mean?).
Vizio 55" M550NV 0500-0612-0030 LCD Power Supply ...
electropartsonline.com/vizio-55-m550nv-0500-0612-0030-lcd-power-su...
Vizio 55" M550NV 0500-0612-0030 LCD Power Supply Board Unit Motherboard. ... Any tears or bad connections between boards must be replaced FIRST. 2.
EASY HOW TO FIX LED Vizio TV- no power - YouTube
? 6:13
https://www.youtube.com/watch?v=9xZcTWr2yV0
Nov 5, 2013 - Uploaded by Tampatec
DiY How to Fix led / lcd Vizio TV service repair - no power service repair ... I can not get it to power on so I ...
Jan 17, 2016 | Vizio M550NV 55 in LCD HDTV
55" model. Why does it play for a couple of hours, then shut down?
Sounds like you have a parental setting on the tv that is set to only allow 2 hrs then shuts down... try going into the menu and looking for parental settings or sleep settings... if that isn't it try spacing the tv away from the wall to allow circulation... it may be over heating... next would be to get a circuit checker for the wall plug and make sure the polarity is right at the power source... you would be surprised at how many homes are wired bkwards... usually sign of this problem is electronics in your home seem to burn out with in 6 months or sooner... tester has 3 to 4 lights on the bk of it and looks like a wall plug.. costs about 5 $
Jun 09, 2015 | Vizio Televison & Video
Remote code for Vizio E552VLE
This incompatibility issue is a frequent problem.
Jan 24, 2014 | Vizio VF550M 55 in. LCD HDTV
I had a power surge at my house, after that happened none of my HDMI inputs work. All others do work, this is on a 55" Vizio
Might need a new main unit or power supply, not 100% certain. Try out a company named ShopJimmy.com for parts, I've used them with great success in the past. I included a link to their site from your model page. Hope that helps!!
TeeVeeMan2@gmail.com
http://www.shopjimmy.com/catalogsearch/result/?q=VF550M
Sep 02, 2011 | Vizio VF550M 55 in. LCD HDTV
Black screen no power up
Tries tv unplug,replug the tv back about an hour later.Tv will be resetting itself.Tv might work again.If not the tv power supply board is it dead.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whloe new refurbish power supply board for the replacement.
Jun 10, 2011 | Vizio VF550M 55 in. LCD HDTV
I purchased a Vizio 32' VA320M off of ebay and it arrived today, I hooked it up watched it for a couple hours this morning, played a little xbox on it and went to sleep. I woke up tonight and was...
This tv have the main Tuner signal board have intermitten problems.Return this tv for a refund.Can't return it make a claim with Ebay,Pay PAL or ur credit card if pay by credit cards.
May 12, 2011 | Vizio L32 32 in. LCD HDTV
Vizio 42 inch tv Power Not working
power supply problem sounds right to me.
Dec 07, 2008 | Televison & Video
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
