JABRA BLUE LIGHT FLASHES ON INSERT TO HOLDER, THEN NOTHING. i HAVE LEFT IT FOR DAYS, I HAVE CHECKED THE POSITION IN THE CRADLE, BUT NO HELP. CAN YOU ADVISE PLEASE.
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing. >Open the printer cover and the output tray. >Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the power light begins to flash.
>Press the ink button again.
If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This occurs each time you press the ink button until all expended or low ink cartridges have been indicated. Once all of the expended or low ink cartridges
have been indicated, the ink cartridge holder moves to the ink cartridge
replacement position when you press the ink button.
>Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover >Press the ink button and then the printer moves the ink cartridge holder and begins charging the ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
Hello due, your battery is dead or the battery circuit has an issue -just as mine-.
You can of course get rid of this problem by yourself if you have some skills...
Check this out: http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
If it is the circuit, then continue reading... "The circuit on
the internal battery has an issue and I cannot measure the voltage
through it correctly. The battery reads 3,55 V, while the circuit reads
0,55 V. So, I have the same problem as above then... A blue flash and
nothing else, no charge... I am going to remove the circuit of the
battery and connect it
directly to the charger pins. I believe this will not cause any issues.
At least, I will be able to charge the headset this way. I will post
once more should this method fails." This is my solution. And it worked. The headset in the cradle is looking at me with blue light on -charging!- Don't forget to take it out of the cradle after 2 hours as there is nothing there to protect the battery any longer.
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
