Question about Dryers
Dryer stops in cycle, then i can restsrt it by pushing the timer knob after 20 minutes or so. it first started having problems with a sticky door switch and now is stopping.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Also, often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 04, 2010
  • jrstevens02 Jul 04, 2010
    hi rylee, when the dryer is on it continues to dry the clotthes but it continues to stop and then i am able to restart it after a bit. its a amana le8207w3what does a thermal fuse do?
    would the termal fuse cause these problems?
Timer knob not turning and its not heating up
If you are setting the knob to begin a cycle AND the drum turns when you start it AND the timer knob does not advance, the timer is likely defective.
Some dryers with truly automatic cycles (using moisture or temperature sensors) will not advance the timer if there is a no-heat condition due to a bad thermostat or heating element. This would show as the dryer tumbling a load forever and the clothes are cold and wet when checked.
If the dryer will not do anything at all AND the timer knob does not advance, check the power (circuit breaker/fuse), then the dryer door switch. When the door switch is defective or the door isn't fully closing, it stops everything, period. There is a thermal fuse on some machines that will also cause this problem.
Good luck from Detroit, MI.
Oct 19, 2011 | Dryers
How do I get my ge dishwasher to run? the lights
Hello there and welcome to fixya
If electrical power is available to the dishwasher but the appliance doesn't run, the problem is likely to be a defective door switch, timer, or selector switch. Make sure to turn off the power to the dishwasher before attempting any repairs
To solve a door switch problem, you may be able to adjust the door latch's strike slightly, using a screwdriver
then make sure the door closes securly, if this doesent work
please check the timer as follows
Dishwasher timer concerns can be classified into two general categories: the timer cannot be advanced manually and appears to be stuck or intermittent automatic timer advancement.
1. The timer dial cannot be advanced manually and appears to be stuck. Stuck timers are generally caused by objects that prevent the detergent cup from opening, or by a sticky substance between the timer dial and the control panel.
  • Objects that prevent the detergent cup from opening: If your timer will not advance, open the dishwasher door and check for items that may be blocking the detergent cup.
    Also, check the detergent cup:
    • It should be fully closed at the start of a cycle.
    • It should be fully open at the end of the cycle.
    • Almost fully open between main wash and final rinse.
    If it is in any other position, try to open or close the cup while at the same time rotating the timer. This should free it up. To prevent a reoccurrence, make sure nothing blocks operation of the detergent cup when the dishwasher door is closed and operating.
  • Sticky substances like orange juice that get between the timer knob and the front of the control panel on some models will bond the timer knob to the control panel. If you have this condition, it will be virtually impossible to rotate the timer knob while gently pressing the knob in toward the dishwasher. It will rotate normally if the knob is gently pulled away from the dishwasher while rotating the knob.
    This problem can be solved by gently pulling the knob away from the control panel and cleaning behind the knob with a damp cloth. Do not use excessive force because the knob is attached to the control panel on models affected by this problem. If this operation cannot be performed, service should be contacted to repair the problem.
2. Intermittent automatic timer advancement. This can be described as the timer can be advanced manually, but it does not advance automatically in spots for up to 30 minutes.
  • This is almost always a normal condition and always occurs on models with a "Delay Start" feature.
    Delay start timers increment or advance a couple of degrees once every minute or so during most of the cycle. However, during certain parts of the cycle they increment once every 30 minutes. This gives the dishwasher time to do the job of cleaning your dishes. The long increment times occur during "Delay Start", "Hot Start", "Normal Wash" and "Dry" cycles.
    The timer will not move at all during these delay periods. This is normal operation and service is not needed. If you notice delay times substantially longer than 30 minutes, replace the timer
  • Also ensue that you are getting adequate water pressure and the unit is getting water inside and that the water is at the right temperature 140 is the min. for most units
  • Please check the above and let me know what you have found so i can continue to help there is a lot of things to check but these that i have provided are the most common thing that need to be checked first ok?
  • Best regards Mike
Aug 21, 2011 | GE Dishwashers
Hi, Model: Maytag DE8410 electric dryer The cycle completes and the buzzer sounds, but does it not stop until I pull the door open. I think I also got it to stop by rotating the cycle knob as well. I...
the timer might be bad and the part # for it is 306040
it is safe to clean it when it is not plug in , just be cearful not to move the wire from the place they in.
if it is not big problem dont replace the timer its 100$+ so live it till the unit die ... it is old unit any way...
Mar 27, 2011 | Dryers
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Dryer stops but the timer continues on
Fixed! The "push to start" button was stuck. Must have been some dust. I pushed the knob a few times and that's all it took. Works fine now.
Dec 12, 2009 | Kenmore Dryers
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Kenmore dryer keeps on going and going
The timer is bad. It is located behind the knobs and can be replaced really easily. The price for a new timer is about 35 dollars. If this helped please rate
Feb 12, 2009 | Kenmore 64902 Electric Dryer
Stops during cycle
Maybe. Will the unit restart in the same position or do you have to move it? If it will work in the same position and all you're doing is waiting for a bit of cooldown...it could be a defective high limit switch that is resetting. If it will restart only after you move the timer, then change out the timer. This is a bit of a mystery since timers generally don't have 'dead spots'...they are designed differently than that.
Dec 24, 2007 | Kenmore 64902 Electric Dryer
Dryer only starts sporadically
your headed in the right direction. there are contacts inside the timer that have gone bad. the timer is in the console ofcourse. its not hard to replace and replacing it will solve your problem
Nov 25, 2007 | Whirlpool LEB6300 Electric Dryer
Dryers Logo
13 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
