Question about Dishwashers
Is the washer coupled to the hot or the cold supply pipe
  • 145 Answers
It should be hooked to the hot water supply.
Posted on Apr 17, 2008
Want to bypass the pump
Usually, water supply goes to the dishwasher from under the sink and should have a separate shut-off valve for both the hot supply and the cold supply. If you have these valves, you could disconnect the supply to the dish washer and drain water out of the pipe. then you can disconnect the pump discharge to get most of the water out of the pump. I hope you understand that a dripping faucet will allow enough "heat in the water" to prevent freezing.
Mar 13, 2015 | Dishwashers
Water not heating
Dish washers only use water supplied from the hot water side of the pipes under the cabinet or sink, so if you installed the dishwasher yourself, be sure that you ran your inlet water line and connected it to the hot water side, and not the cold water side. The dish washer has heating elements inside the machine to dry the dishes, not heat the water. If this is hooked up correctly and you are still getting cold water to heat the dishes, the problem may be that the unit is too far from the hot water tank. In that case, you may need an auxiliary hot water tank installed near the dishwasher under the cabinet. They make small tanks for such purposes.
Dec 14, 2014 | Dishwashers
Is it a cold water or hot water fill
It's your choice.There's only a single supply hose and with most dishwashers that means cold fill only, but as this is a compact basic worktop model the manual supplied suggests that users connect to a hot water supply.
In real-life situations though, the water drawn from the hot supply often isn't instantly hot so all you do is drain cold or tepid water from the supply pipe and let it get replaced with wasted hot water which then cools in the pipe! If the machine features condenser drying like many dishwashers, then cold water is essential for it to work. A final consideration is that unless your hot water is supplied at mains pressure (such as in a combi-boiler or megaflo system) then the water pressure from a hot water storage tank will not often be high enough and you'll have to use the cold supply.
Jul 13, 2011 | Bush DW5F 22 in. Dishwasher
I have recently changed my dishwasher over from a direct hot water pipe into the dish washer, to a cold water pipe but the temperature lights keep flashing and then the cycle, which has barely begun,...
A dishwasher requires a hot water line to operate properly. The dishwasher is indicating the water is too cold to even begin a cycle.
Charlie
Jan 09, 2011 | Dishwashers
GE models in the Medle East (problem with heater and salt)
Cold is probably more efficient unless you have solar heating or your how water cylinder is right next to the washer with minimum amount of piping otherwise by the time the hot water reaches the machine it will have enough in it anyway :p I dont have much experience with water hardness issues as water in my region is quite soft but you can get tablets containing? softener as well as detergent... yes?
Feb 25, 2010 | GE Dishwashers
Water Connections
In the US dishwashers are usually connected to the hot water supply. Although the ASKO 1850 I believe has an in line heater. Using hot water supply will reduce electrical useage.
Interestingly we use to have ASKO washer and it suggested only using cold water hook up as it heated its own water. I guess this was a feature if one's laundry area does not have hot supply, but it made no sense in CA to heat water with electricity.
Nov 11, 2009 | Asko 24 in. 1805 Built-in Dishwasher
How to install pipe work,hot or cold fill?
You probably want to split into the hot pipe for washer. Never good to wash dishes in cold water. Soap doesn't get all the way and can cause cancer down the road from intake of too much dishsoap.
You can go to howstuffworks.com or youtube and view installation videos which are helpful.
Oct 01, 2009 | Dishwashers
Water supply for dish washer
normall water is cold water for dishwasher
Jun 03, 2009 | LG Dishwashers
No hot water
Hi Jon, is this a new machine that you have just got? if so it sounds like the hot and cold water pipes are on the wrong way round. If not sounds like a thermostat problem
May 29, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Hot and/or cold fill
A dishwasher usually fills with hot only. Actually it will fill with whatever is connected to it.
Premmy
Oct 27, 2008 | Hotpoint Dishwashers
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
