Question about Whirlpool 24 in. ADG6962iX Built-in Dishwasher
ADG6962iX Built-in Dishwasher .The start light is continiously flashing .When the start button is held in .The dishwasher appears to start emptying but the light continues to flash
SOURCE: cda dishwasher
I have just developed the same problem on my CDA CW492 - did you find a fix for this problem?
Posted on Jul 24, 2008
SOURCE: flashing light
I had this problem at home too, it turned out to be a kink in the water outlet pipe. I straightened out the kink in the pipe, put duct tale around it to strenghten it and the dishwasher has been working perfectly since.
Posted on Sep 22, 2008
SOURCE: my dishwasher model adp 941 won't start - start led flashes
exactly the same problem today with an AD9520
Don't know the cause but from reading other posts re dishwasher problems I tried holding start but on for 5 - 10 seconds and it seemed to clear the symptoms at least. It ran for a short while and stopped but the flashing had stopped and I could start a wash cycle which is now running!
Posted on Dec 14, 2008
sclarke7
  • 222 Answers
SOURCE: whirlpool dishwasher model number GU3600XTSY2 is
The clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Posted on Mar 26, 2010
rylee_smith
  • 8619 Answers
SOURCE: dishwasher quits running and clean lite keeps flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 06, 2010
Dishwasher asko 1895 the pump the working the lights are flashing but the machine is not working
The lights flashing is telling that there is a fault in the dishwasher.
I am assuming you have emptied the dishwasher after the drain cycle failed to work due to the pipe block.
You will have to make a fresh start. Empty the dishwasher, turn the power mains switch off and on to reset the dishwasher.
Start a new cycle and see if flashing lights stop flashing. If still same problem you will have to note which light(s) are flashing and send a post on this page. There is a chance the impeller in the drain pump may have sufferred some damage due to drain block depending on how long the motor operated before you found the problem with the drain.
Jan 04, 2013 | Asko 24 in. 1895 Built-in Dishwasher
Dishwasher will not work
I had the same problem. on the same machine. when this light flashes it means that it cant easily intake or drain the water. just clear the filter located down the tube and clean all of its parts and the valve wich is down from a metal stipe next to the filter. after this press continiously the start button. this should do it!!!!
Dec 11, 2012 | Miele 24 in. G692SC Plus SS Free-standing...
Dishwasher will not start. The clean light is flashing on and off. If I push the cancel button it appears to be draining but there is no water in the tub and it just continues. When I push the start...
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jan 20, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
Hi
-high temp wash
-heated dry
-high temp wash
-heated dry
Thanks
Rylee
Jun 03, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
Kenmore dishwasher 665 Lock on light
You may have a stuck button as this will cause flashing of lights, try pushing button and see if it returns if not strike lightly above it with plastic spoon etc.
If this does not work u can buy the control panel from Sears for 190.00 but first go to searspartsdirect.com then type your model no. In required space click on shop parts on appropriate model, then go to troubleshooting then to won't start, then go down to how to replace control panel.
According to instructions you will only need torx screwdriver and less than 30 minutes to replace.
Jul 13, 2017 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher wont start, light are flashing
should indicate that a power failure has occurred try pushing start cancel then reset options and re start
Feb 12, 2009 | Electrolux Frigidaire Professional Series...
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
Indesit DV620 Dishwasher
You have a internal leak in the dishwasher...there is a safety float system in the base (below where you put the dishes in!) of the unit, which in the event of water in the base will stop the cycle and activate the drain pump continiously.... You will have to open the unit and find the leak. Don't know these models, but usually you have to remove side panels and front panel, drain water from the base and re-start....then check with flashlight where the leak is. Oshie
Jun 21, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Whirlpool 24 in. ADG6962iX Built-in Dishwasher Logo
20 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
