Question about Arrow Fastener ET2025D 3 In 1 Electric Staple + Nail Gun
I need to assemble a Arrow ET 2025 Stapler - Arrow Fastener ET2025D 3 In 1 Electric Staple + Nail Gun
Will the Arrow staples # 405 fit into my Craftsman 68464 staple gun ?
thats the picture of the manual staple gun
and the picture of type of staples you want
on the staple box confirms you can use the staples in that
sears craftsman
note the staple has inches and metric dimensions
all you need to check is the stapler eject system is not worn out
or cause a jam as you try to staple
if sticky .. try some sewing machine oil on the stapler workings
Oct 14, 2016 | Arrow Fastener 405 5/16" Flat crown...
Load staples in et50 arrow stapler
It will probably have a release at the bottom rear of the stapler. Just push the release in and down to release the rod/spring assembly (the release catch may be silver in color). Drop in a stick of staples the reinsert the rod/spring and reengage the release.
Dec 12, 2014 | Arrow Tools & Hardware - Others
How to put the spring back in the handle of Arrow T50 Stapler?
Ref. recocking the spring handle in your Arrow T 50 Stapler
1. secure the stapler in a vise. You need three hands to recock the handle spring.
2. Using a notched tack lifter hand tool, with one hand holding the handle so as to expose the spring, place the notched tool against the spring arm and force it to the rear. it will now be under tension.
3. Wiggle the handle into position so that you can quickly insert the clevis pin. Once secured, let go your handle that is now under tension. Replace clevis ring.
4. Dry fire to test.
Sep 18, 2014 | Arrow Staple T50 3/8"" Monel stainless...
How to take apart
Use a knife or small screwdriver to remove the little lock rings on one side of the stapler. DO NOT lose them With the lock rings removed, push the pins toward the other side of the stapler and remove them. Now the internal mechanism can be removed through the bottom of the stapler after you remove the staple "pusher" from the rear.
That's about as far as you can take that stapler apart.
Jul 28, 2014 | Arrow T50P ARROW STAPLE GUN
Reassembling powershot stapler
You might be able to get assembly instructions and/or a diagram from Arrow. Schematic diagrams usually pertain to electronic equipment
Jun 25, 2013 | Tools & Hardware - Others
Can not find staples for 502 ace liner stapler ,
Hi, I found them on amazon, click here and take a look: Staples Undulated For 07020 Clipper Plier 5000 BX. I hope this was helpful. Cheers
Jan 23, 2013 | Tools & Hardware - Others
I need to put in new staples. How do I do it?
This stapler does not swing open like a paper stapler. It has a little square metal piece at its heel (about the size of a postage stamp). Press in lightly on this metal piece as you move it up or down just a bit, to unhook it. Then pull out the piston and spring assembly, insert staples in the hole and replace the piston. You must use T50 staples (of various lengths). T35 and others will not fit. Good luck, Al K
Sep 01, 2010 | Arrow T50P ARROW STAPLE GUN
Instruction book for Arrow ETF50P staple gun . lost the instructions and can't figure out how to insert the staples in the gun
Look at the rear of the stapler. Push in then down on the stapler tensioner to release it from the rear of the gun. Slide the tensioner out. Next slide the new staples over the rail and into the gun with points down. Slide the spring tensioner back in and connect it to the stapler by maneuvering its clip down and then up.
Apr 19, 2010 | Arrow No.ETF50PBN Extra Heavy Duty...
How do I open the darn thing to add staples?
Thanks for the link to the manual, fixyajohn. However, it wasn't clear on how to open it. However, the manual gave me the clue that it was simpler than one would anticipate when you first start grabbing at it. Just push in on the flat panel on the rear of the stapler. That disengages a little hook from the slot in the body. Then pull the released assembly downwards and finally rearwards out of the channel. Very simple. techmag's answer just doesn't apply to the T2025.
Aug 20, 2009 | Staples Arrow T2025 Staple Gun For Flat &...
My jt 21m stapler is jammed and i cant get it to open
At the end of the stapler opposite where the staplers are driven out is a release. Push it in and turn it should come out with a long spring.
Jun 26, 2009 | Arrow Fastener Co. Lt Duty Staple Gun -...
Arrow Fastener ET2025D 3 In 1 Electric Staple + Nail Gun Logo
273 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Mike
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
