Question about Whirlpool LER5636P Electric Dryer
Replace Dryer Door Switch
I have a Whirlpool Dryer model - LER5636PTO. The dryer isn't running, as I believe it's the door switch is faulty, I would like to know how to replace it, thanks for any assistance.
  • 5,911 Answers
Have you checked the dryer belt? The belt can also prevent a dryer from running. In either case you will need to open the dryer to access both components. this is accomplished by lifting the top panel and/or removing the dryer front.
If the model number is correct, just follow these steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing. The part number for a replacement switch is 3406107.
NOTE: At this point you can access and remove the door switch and replace a necessary. If you don't see the dryer belt wwrapped tightly around the drum, there's a good chance it is broken. Continue on with the next steps to replace the belt.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. If the belt is broken, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt (if required) and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Roper and refer to diagram H.
Replacement parts (if required) can be ordered on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number for a replacement belt is 341241. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also inlcude helpful exploded view diagrams that can help you locate and properly indentify the parts you may need.
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them. If you have any questions about this repair, please post back and let me know. I hope this helps you.
Posted on Jul 04, 2010
Testimonial: "Thanks.....The information was correct, appreciation......thanks."
    President:
  • 1,218 Answers
Good day,
Remove the lint filter. Remove the 2 screws under it. Then with a screwdriver pry up the front of the top cover on each end, one end at a time.
Lift it up and away from you. Avoid going beyond vertical,
You will see the switch and changing it is fairly simple using ordinary hand tools.
Testimonial: "Thanks....the information was spot on"
Whirlpool electric dryer model GEQ8811LW1. How do I get to the door switch to replace it? I used a putty knife to open the top, but there doesn't seem to be any catches to release the top.
Posted on Sep 11, 2010
How to replace dryer door switch on whirlpool model len2000jq1
Rob, I believe I may have answered this in an earlier post, here it is again, 1st and 3rd link, scroll down to how to replace dryer belt videos, it will show how to remove top of dryer and get access to door switch.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My LEN2000JQ1 Model Overview from PartSelect ca
Whirlpool Dryer Model LEN2000JQ1 Switch Door Switch
http://www.appliancepartspros.com/parts-for-whirlpool-len2000jq1.html
May 13, 2016 | Whirlpool Dryers
Dyer suddenly will not turn on
You need a new door switch, if the switch isn't working the dryer will not start.
Jan 29, 2012 | Dryers
.Whirlpool electric dryer will not work.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Here is the door switch.
Jan 10, 2011 | Whirlpool WED5200T Electric Dryer
Whirlpool electric dryer will not start Model # LER6644DQO
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jul 30, 2009 | Dryers
Our whirlpool 6th sense dryer model awz3413 will not turn on
3. Thermal fuse
4. Timer
Jul 21, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool electric dryer (Model # LER4634DQO). Dryer won't come on when we push the start button.
The dryer would not start with a broken door switch. Replace the door switch if found defective.
3. Thermal fuse
4. Timer
Jul 08, 2009 | Whirlpool Dryers
My whirlpool dryer will not start
OK, check the following areas to combat this no start issue.
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
If all the above checks out ok, replace the timer or control board.
Jun 14, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool electric dryer LEB6300 door
you have to lift the top cover. then from there you can access the door switch of the dryer.
look closely between the front wall and the top cover. pry the top cover slowly and push the plastic lock that is holding the top cover.
then you can see the switch now and replace.
tnx 4 using fixya,
drcool
Sep 08, 2008 | Whirlpool LEB6300 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
450 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
