I have a Palm T5 which locked up. I have tried all variations of resets and have come to one set that brings me to a screen that has the target on it for the digitizer to center but will not work. If I do a soft reset at this point I get the Palmone screen with a line blinking at the top. This same line blinks regardless of either of the two screen I am able to see. Reading online posts hints at the digitizer having gone bad but I don't know this.
  • willferg Jul 05, 2010
    Advice was straightforward and most appreciated. I will attempt to locate a local electronics repair shop that can replace the digitizer pad per instructions.
    Thanks.
  • 6,993 Answers
yes, its true that the digitizer has gone bad. This is why the palm is giving you problem. You need to replace the digitizer of your palm in other to solve this problem.
Visit the you-tube video below, you and watch a video of how to replace a palm digitizer. This will help you to know what palm digitizer looks like.
But if you cannot do this yourself, maybe you should visit the nearest repair man to fix it for you.
Good luck.
Posted on Jul 04, 2010
  • 1 more comment
  • Walesarumi
    Walesarumi Jul 04, 2010
    here is the link: http://www.youtube.com/watch?v=SD7dHUJgM...
    You can check the right side of the link and you will find other related video that might be of help.
    Take care.
  • willferg Jul 04, 2010
    The replacement seems straightforward; however, I think I would rather get someone who is an expert on repairing these things to do the work. Do you know someone and do you have a rough estimate as to the cost? I have a backup of most of my data. Will lose the last 3 months but the backup contains over 10 years worth of info from earlier versions of Palm systems.
    Thanks.
  • Walesarumi
    actually we don't stay in the same vicinity, so I wouldn't know precisely where you can repair it, but if you take it to a phone repair shop, it should be fixed there for you or they can direct you to an expert if they can fix it.
    As for the cost, it varies, but it should be less the $80
    Take care.
Trying to reset my t5 wont hard reset
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 24, 2010 | Palm Tungsten T5 Handheld
Palm tungsten t5 won't boot past the Palm Powered
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your T5, so only do it if you have to. Hold the Power Button while you push the reset button. Continue with the instructions to finish erasing your device.
Feb 17, 2010 | Palm Tungsten T5 Handheld
I have a moving target on screen and can't access anything else?
pls try to hard reset like this if it helps see the link
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,t=ooccase,case=obj(15574)
if problem persists then yes u are gettin screen alignment problem bcoz of digitizer fault it is faulty u have to get it replaced but i dont think it is worth if warranty is out if u really want to do it then go to below link
http://cgi.ebay.com/Palm-Zire-71%2F72-Tungsten-E%2FE2%2FT--Touch-Screen-Digitizer_W0QQitemZ220375121035QQcmdZViewItemQQimsxZ20090310?IMSfp=TL090310122012r31943
http://www.bizrate.com/pdaaccessories/products__keyword--palm+e2+digitizer.html
I Recommend the Following Tools for this Repair
  • Case Opener Tool - Part Number: XX1521
  • Torx Driver - T5 & T6 Driver Set: XX1127
  • This is a complete screen for the Palm Tungsten E2 unit. This includes the LCD and Digitizer.
  • This is a refurbished screen and comes with a 30day warranty.
  • This screen will only work with the Tungsten E2 units and NO other models. All sales are final. No exchange refund or return. There is a 30day warranty with this item directly from PDAparts.com.
    FREE INSTALL DIRECTIONS
  • see the Video here
  • http://www.youtube.com/watch?v=ECCXp2dnuW4&eurl=http%3A%2F%2Fwww.gethightech.com%2FMerchant2%2Fmerchant.mvc%3FScreen%3DPROD%26Product_Code%3DPA1995%26Affiliate%3Dfroogle&feature=player_embedded
  • PLS RATE ME FIXYA FOR THE HELP
    Mar 20, 2009 | Palm Tungsten E2 Handheld
    T5 is frozen on the "Palm Powered" screen
    Remove the battery and let the palm sit for a day, reconnect the battery and do a hard reset. To remove the battery, you need a Torx T5 screwdriver. Carefully remove the cover making a note of the location of all the buttons in the case. The battery is connected by a mini 2 pin connector, just disconnect the battery by gently wiggling the connector and pulling.
    Mar 06, 2009 | Palm Tungsten T5 - Multilingual Handheld
    I have a Palm TX. 3Years old. 6 Months ago had to calibrate Touchscreen every day. 2 months ago had to calibrate touch screen 2/3 times a day. Recently can't calibrate touch screen. Targets go into loop...
    Same happened to my 3 month old TX. I just recharged it, and all was OK! Sounds strange at first, but in my hometown, it is very humid, so maybe it got some moist inside and that caused some variations in the power or battery or voltage... dunno, maybe you need some cleaning, or try to calibrate while plugged.
    Hope to be useful!
    Jul 03, 2008 | Palm TX Handheld
    Palm 700P stylus problems
    it sounds like it could be a warrenty issue, if you have restoreed the device and its still not working then you would need to get it repaired or replaced
    Jun 11, 2008 | Palm Treo 700p Smartphone
    Palm Tungsten t5 WiFi
    I suspect that you're in fact holding a Palm TX and not a T5 as the T5 does not have WiFi. If you're using the Palm SD WiFi adaptor, do a hard reset without the card.
    (hold down the ON/OFF button whilst using the reset pin to press the reset button. You'll be asked if you are sure you wish to reset. You'll then be prompted to choose the language caliberate the screen etc..)
    After that. Go and download all the updates and drivers from Palm Web site.
    Oct 04, 2007 | Palm Tungsten T5 Handheld
    Dead Palm
    Need to change the battery.
    Jun 01, 2007 | Palm Tungsten T5 - Multilingual Handheld
    Interrupted update - jammed
    An interrupted update will corrupt your ROM. I sincerely hope you'll get a better 2nd opinion, and from your post it seems like if theres a solution out there then you're not likely to miss it ;] Good luck, and let us know if you worked it out
    Apr 17, 2006 | Palm Tungsten T5 Handheld
    Computers & Internet Logo
    52 people viewed this question
    David Payne
    David Payne
