Question about Philips 27PS55S 27" TV
I have a philips tv model # 27ps55s321 from 2002 and it has no sound now what should i do
I have a Philips tv model 51PW9303 I hooked up a brand new Playstation 3 and there is no sound
if you used hdmi it may no support audio...in that case just run a pair of av cables for the auido out..
Feb 18, 2013 | Philips 51PW9303 51" Rear Projection...
I have a 29" Philips TV model 29PT4824/94R. The
To make sure that the external speaker is good or deffective try to use others speaker.If the other speaker work it means that your speaker is deffective and if the other speaker not work it means that the problem is the sound output amplifier or driver of the TV.You need to check the inner part othe TV.The board of the TV inside at the sound section, just fallow the speaker wire to the board,that is the sound section.Check if theres a loose connection.
Jul 16, 2011 | Philips Televison & Video
I have a phillips model # 60pw9383-17f tv.sounds
Sound with no picture on this model is typically the HVG/Flyback.
Sep 04, 2009 | Philips 60PW9383 60" Rear Projection...
TV doesn't come on
Your SSB Module is Bad Part # PH3912725881.
Jan 02, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
PHILIPS TV SOUND PROBLEM
My phillips tv model # 55pl9773/17 sound is too low when im watching regular tv, but when i switch from tv to av1 or av2 (watching a dvd movie or playing video games) the sound is normal. How do i get my cable TV to sound the same?
Sep 28, 2008 | Televison & Video
Philips tv
Try rebooting it. If it does not work, then looks like your TV needs service.
May 18, 2008 | Philips 27PT6441 27" TV
Philips model ptv915 model # 60P8341a
  • sound  off & on is dye to loose contact in sound section
  •  plz check
  • speaker wire or connector loose.
  • speaker defective.
  • loose contact or print loose in sound section.
  • supply to sound section.
  • sound output ic or print loose.
  • hopr this will help
  • good luck.
Oct 19, 2007 | Philips Magnavox 27MS343S 27" TV
Philips 27PS55S 27" TV Logo
187 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
