posted by Tony872 on Apr 17, 2008
I have tried to set the Asus Wifi-b card up on my pc so I can use my broadband from my pc on my nokia N95 or my play my DS online.
Setup seems find picks my name up but I can never get a connection
with my nokia n95 or my Nintendo DS try units in local wifi shop all works good.
Could some one tell me the settings I should use on the Asus software to get this hardware to work so I can browse the internet on my Nokia N95 from my connection and play my DS online
Comment by Tony872, posted on Apr 17, 2008
No I do not have a wireless router but I can borrow one of my mate Netgear ADSL router.
But if I have to get a wireless router what would be the point of the wifi b card cause I see s set in the manual where no router is required.
Im confused
Help please
Im confused
Help please
1 Other User Has The Same Problem
Comment by dipen1984, posted on May 21, 2008
can anybody tell me steps for setting my broadband in my n95
Best Solution
Hi Tony872,
Do you have a wireless router hooked up to your broadband modem?
If you do not, you will need to purchase a wireless router to hook up to your broadband modem if you want to have wi-fi in your home.
Here is a link that will provide you with some wireless routers that are available.
http://www.bestbuy.com/site/olspage.jsp?id=pcmcat62200050104&type=category
I hope this helps you out.
Sincerely,
Agent Xiong
Sincerely,
Agent Xiong
Comment by Agent Xiong, posted on Apr 18, 2008
Hi Tony872,
If you do not have a wireless router broadcasting your broadband internet, there is no way you will not be able to go online with your DS, Nokia n95, or your computer with the wireless network card. The Asus wifi card does broad cast wifi signal and will only work if it is able to locate a signal or if you are broadcasting a signal yourself. So, you will need to hook up a wireless router to your cable modem to be able to go wifi in your home because the wireless modem will broad cast your broad band service. However, once you hook up a wireless router to your modem, I suggest you secure your signal or else anyone in rang of your signal will be able to get online.
Sincerely,
Agent Xiong
Sincerely,
Agent Xiong
Rating Locked! (?) Tony872 has rated this solution as Helpful
Solution #2
posted on Apr 28, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I can't edit my post, sorry, but wanted to add that the card only works for computers with windows, so you can't connect a mac, a phone, etc. Sorry for the double post.
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I'm very confused by this! I also have an ASUS wifi-b card on my desktop PC which acts as a wireless router for my laptop. The desktop has a wired broadband connection. I'm definitely connected to the internet via this connection as I had to enter the key that I set up on the desktop machine when I set it up and encrypted it when I connected on the laptop. I use the soft AP mode internet connection sharing set up, the first listed in section 2.5 of the manual. I know it works!
Suggest a new solution for this problem
Post a New problem for ASUS WIFI-B Network Adapter
Email this problem
Email this problem
Can you Help with these Network Adapters problems?
Repair Service
Find Network Adapter Repairman Near You:
