Question about Microsoft Office Outlook 2007: Windows
Error message appears when I try to open my my outlook: "Cannot start microsoft outlook. Cannot open the outlook window"
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 308 Answers
Insert the cd (that is if you have it on a cd) or launch the setup file if its on your pc. Wait for the programme to start its check for installed version.
From the diplayed window of the setup select repair from the list (repair, remove). Make sure to use the same version for this to get it working again. Do get a registry repair programmes such as uniblue registry booster or tuneup utilities to repair the pc of corrupt files, do constant maintenance on your pc such as defragementation, check disk and the likes.
Good luck and let me know of the outcome should you need more help
Posted on Jul 04, 2010
    Problem Solver:
  • 7 Answers
You can also try going to Start | Run and typing:
outlook.exe /safe
To see if it's not something with your current profile or a plug-in.
If that works, you'll want to uninstall any recent applications that may have caused interference.
Posted on Jul 12, 2010
Microsoft Outlook 2013
In most cases it is the corrupted Navigation Pane settings file that prevents Outlook from starting successfully, so the first thing you need to do is to mend it. Here's how you can do this on different operating systems:
1. If you use Vista, Windows 7 or Windows 8, click the Start button. On Windows XP, click Start > Run.
2. Type the following command in the search field:
outlook.exe /resetnavpane
Note: Be sure to enter a space between outlook.exe and /resetnavpane.
3. Press Enter or click on the file in order to reset the Navigation Pane settings and then open Outlook.
Or try to repair your outlook.pst file using Outlook Fix Toolbox
Findit here https://www.fixtoolbox.com/outlookfix.html
Oct 23, 2015 | Microsoft Outlook
Getting an error on outlook mapi cant find the msncon.dll file
what version operating system did you install on . most likely it is not compatible with your OS
Jun 28, 2015 | Microsoft Office Outlook 2003 for PC
I keep getting an error message that says, "Microsoft Outlook. Cannot open the Outlook Window. The set of folders cannot be opened. Errors have been detected in the file C:\Users\my name\AppData\Loc
To resolve this problem, use the following steps. On the Start menu click Run. In the Run dialog box, type the following command:
Outlook.exe /resetnavpane
Note:
There is a space between "Outlook.exe" and "/resetnavpane" Click OK. Note If you are using Windows Vista or Windows 7, you may not see Run on the Start menu. In this situation, use the following steps to locate the Run option. On the Start menu click All Programs. Click Accessories. Click Run.
Apr 15, 2013 | Dell Computers & Internet
Logged on and my email icon was missing as well as other icons. tried to start outlook and the message is simply cannot start outlook. cannot make google my home page as dell4me contiues to override any...
This issue may occur if you deploy Outlook 2003 with the Microsoft Office 2003 Custom Installation Wizard and specify a personal folder (.pst) file in the Windows Installer transform (MST file) by using the Default location for PST files path option. The problem occurs because you specify a file name instead of a folder path.
To resolve this issue for future installations of Office, use the Custom Installation Wizard to edit the MST file. To do this, follow these steps:
  1. On the Change Office User Settings page (page 10 of 24), expand Microsoft Outlook 2003, expand Miscellaneous, and then click PST Settings.
  2. In the right pane, double-click Default location for PST files, and then type the path that you want in the Default location for PST files box. For example, type %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\.
  3. Click OK, and then follow the steps to complete the wizard. When you have corrected the MST file, deploy Office by using the correct MST file.
To resolve this issue for an existing installation of Outlook that is experiencing this problem, specify the .pst file by using the Mail icon in Control Panel.
Or If you are receiving and Err like
Error message when you start Outlook: "Unable to open the Outlook window," "No profile has been created," or "The list of Profiles cannot be loaded"Follow the step's below:This issue may occur on a computer that is running Windows XP if the Outlook.exe file was configured to open with the Windows program compatibility mode setting. When you set compatibility for Outlook to Windows 95 or to Windows 98/Windows Millennium Edition, Outlook displays this error message. This is because the location of the Outlook Profile information in the registry differs on a Windows XP-based computer.
To resolve this issue, follow these steps:
  1. Locate Outlook.exe.
    Outlook.exe is typically located in one of the following folders, depending on the version of Outlook that you are running:
    • Microsoft Office Outlook 2010 C:\Program Files\Microsoft Office\Office14
    • Microsoft Office Outlook 2007 C:\Program Files\Microsoft Office\Office12
    • Microsoft Office Outlook 2003 C:\Program Files\Microsoft Office\Office 11
    • Microsoft Outlook 2002 C:\Program Files\Microsoft Office\Office 10
    • Microsoft Outlook 2000 C:\Program Files\Microsoft Office\Office 9
  2. Right-click Outlook.exe, and then click Properties.
  3. On the Compatibility tab, click to clear the Run this program in compatibility mode for check box.
  4. Click OK.
  5. Try to start Outlook. If you receive error message again, use Method 2.
Regard's
Pcs365.8
Jun 16, 2010 | Microsoft Windows XP Home Edition
We cannot start e- mail, Error message is:
I think your email account is not the problem, but make sure your outlook account setting is correct.. It's a best bet to reinstall the Office.. Good luck...
Apr 29, 2010 | Microsoft Office Professional 2007 Full...
Cannot open Microsoft Outlook
I think you are trying to run outlook in Compatibility mode. Which is why Outlook window isn't opening.
You can try following solutions.
1) Search Outlook in start menu search box then right click on outlook and select Open File Location. You can see the following image for this.
2) Now select Outlook and right click on that & select properties.
You can see the following images for that. cannot-open-microsoft-outlook-w3i35ygaym0a2mtgexp5w2fh-2-2.png
3) Now click on Compatibility tab and Uncheck the checkbox "run this program in compatibility mode" and at last click on Apply then OK. You can see the following image for this.
Now, I hope Outlook will work properly.
Jan 22, 2010 | Microsoft Office Outlook 2007: Windows
Microsoft office
When you try to start a Microsoft Office 2007 or Microsoft Office 2003 program, you may receive the following error message or an error message that is similar to the following:
Error 25090. Office Setup encountered a problem with the Office Source Engine, system error: -2147023836. Please open SETUP.CHM and look for "Office Source Engine" for information on how to resolve this problem.
CAUSE
This behavior occurs when the following conditions are true:
* Two people installed Office on the same computer.
* Both installations were completed by using the AllUsers="" parameter to set the installation for the installing user account only.
* When both people were prompted to remove files that were copied locally at the end of Setup, both people did not remove the files.
* One of the two people removed Office.
RESOLUTION
To resolve this behavior, start the Setup program for Office. To do this, follow these steps:
1. Insert the Microsoft Office 2003 CD in your CD drive or DVD drive.
2. If the Setup program does not start automatically, locate the Setup.exe file on the CD, and then double-click the file to start Setup.
3. After the Setup window appears, cancel Setup, and then respond to the prompts to exit Setup.
Note: You do not have to complete the Setup program. Setup fixes the error condition when it is first invoked.
Sep 05, 2008 | Microsoft Office Outlook 2003 for PC
Outlook problem!!
uninstall office completely, restart your system and reinstall office completely...
Mar 15, 2008 | Microsoft Office Outlook 2003 for PC
Microsoft Office Outlook 2007: Windows Logo
99 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
