Question about Kenmore 54701 Dehumidifier
Warm to touch & cuts off also I want to remove complete cover to clean inside?
  • 857 Answers
The de-humidifier is a niche product. Its only job is to remove moisture from air to alleviate the problems of mould and mildew. It is very similar in operation to a window air conditioner.
A dehumidifier though will add heat to the room, while an air conditioner will remove heat.
The de-humidifier is an appliance that requires regular maintenance. This may be because it’s icing up, overflowing, not removing enough moisture, or simply time for a good cleaning to maintain its efficiency. If you don’t feel handy enough to attempt this project contact your appliance repairperson.
The following is a step-by-step method used to return your de-humidifiers to its peak efficiency.
Tools required
1 Multi pocket container (old ice cube tray)
2 Long handled brush
3 Oil can
4 Rags
5 De-greaser or spray detergent
6 Selection of screwdrivers
7 New filter
1… Remove water collection bucket and put aside.
2… Remove the filter from rear of machine. Filer is usually within a frame and simply pops out. If no filter proceed to next step. If it is a disposable filter simply replace it with a new one. Other types are made in a plastic frame and can be cleaned and reused. To clean a filter lay it flat in the sink and sprinkle surface with powder laundry detergent. Plug sink drain and turn on hot water. Cover filter with enough water to submerge. Soak for 15 minutes. Remove from water and rinse. Hang up to dry while proceeding to next step.
3… Remove the rear grille from the main body of de-humidifier. If none proceed to next step. If there is resistance then look for hidden screws. If grille locks into cover proceed to next step. Once removed place the grille aside until later.
Tip: Dehumidifier may use different types and sizes of screws. Use ice cube tray to segregate.
4… Remove metal cover of de-humidifier to access inner workings. Cover screws may be difficult to see because are often painted to match body color. Usually two or three screws along each side of base. Once screws are removed lift the cover straight up. Use extreme caution at this point. Front grille may be secured to cover. Some fronts are put together like a puzzle. Parts often interconnect or are screwed to one another. If front grille lifts off with cover try to separate before proceeding. Front grille may lock into groove along front edge of cover. Avoid pulling off any wires from humidistat or indicator light.
5… When cover removed this will expose the heating and cooling coil. They may appear as one but are actually two separate coils in very close proximity. Both will need to be cleaned.
Use a narrow brush to remove surface dust and dirt from the front and rear surfaces of coils. Use an up and down motion to avoid bending fins. Area between two coils must also be cleaned. Use caution, the fins are soft aluminum and can be easily damaged. Once surface dirt is removed, spray with de-greaser or light cleaner. There is a good product on the market called HVAC cleaner. As the name implies it is meant for Heating, Ventilation, and Air Conditioner coil cleaning. If this is not available Fantastic Spray cleaner used in kitchens and bathrooms works quite well. Remove dirt and excess cleaner by slowly pouring warm water into fins. Do not allow the water to enter any electrical connections or components. As an added precaution cover the motor with one of the cloth rags to protect it from the water.
6… With cover, rear grille, and front grilles removed locate fan motor for oil holes. Add a few drops of oil to each end of the motor body. Use a general purpose (3in1) oil or clean motor oil. A #30 oil is sufficient. Three or four drops on both ends of the motor body are sufficient. Add the oil slowly, pausing a few seconds between each drop. If added too quickly over-lubrication will result.
7… Straighten any bent fins. Use a fin comb if available. If no fin comb then use something soft such as a Popsicle stick. Straightening the fins will increase the efficiency of the airflow through the coils. Use caution as these coils are filled with high-pressure refrigerant.
8… Wipe any dirt from fan blade using a soft rag. Do not bend blades. This would cause a vibration that would harm the motor.
9… Vacuum all surfaces including front and back of grille assembly. Vacuum underside of metal cover. Vacuum dirt buildup from base and any other exposed surfaces.
10… Drain any water left in the base and allow it to dry.
11… When completely dry plug in and test operation. On some models testing may require temporary override of bucket overflow switch. Test that cooling coil begins to sweat water within few minutes of operation. If everything appears okay unplug and reassemble. Insert water collection bucket slowly to avoid damaging float switch mechanism.
Posted on Jul 04, 2010
How do I fix leaking dehumidifier?
units that leak some times are a total loss but not allways , sometimes its just not being used on level surface (water seeks level allways) , there are lots of ports inside that need to be kept clean for all the units water to drain out , look inside with a flashlight to see if any buildup is obvious that might be cleaned off ? if not a last effort is to remove cover to see 1st hand what cause is(remove power plug 1st) , rust /mold/dust are all common things to find inside that affect units operation
Jun 29, 2014 | Kenmore 50 pint Dehumidifier w/Electronic...
How do I access the filter on my LG (LHD659EBL) dehumidifier, how do I clean the filter, and how often should it be cleaned?
To find and remove the filer. First, turn the unit OFF & unplug it. Then remove the water bucket. The filter frame & handle will be located at the top of the bucket holder just behind the front louvers. If you have never removed and cleaned the filter, it may have a piece of plastic tape on it, which was used for shipping. Remove the tape & discard it. Pull the filter frame's tab handle straight down and remove the filter. It can either be vacuumed or if it's really dirty, washed in warm water and a mild dish washing liquid. Rinse thoroughly and shake off any access water. Allow it to dry completely, before reinstalling it. Never operate the unit without the filter in place. Doing so could cause damage to the unit.
Clean the filter at least once every two weeks.
Hope this helped you and thanks for choosing FixYa.
Sep 16, 2011 | LG LHD659EBL Dehumidifier
My humidifier runs continuosly, but is not collecting any water. When I touch the right side, where I imagine the motor is located, it feels very warm. I have unplugged it for a few days, then tried...
There are 4 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter in place. As it could damage the unit.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity sensor may have failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 26, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
The fan is running, but it is not removing moisture. The compressor does not appear to be coming on. I removed cover and cleaned inside. There was not very much accumulation of dust on the coils.
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35% If you have an analog unit
(no LED Screen), set the humidity extraction knob to Maximum.
the unit without the filter.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this info helps you to further troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 25, 2011 | Whirlpool AD50DSL Dehumidifier
My machine runs but it does not gather any water even though I know the humidity in the room is high. The humidity displays 60% room and it will not decrease to 35% set, even though the machine is running...
There are 5 basic, but solvable reasons for what you described. Of these 5 you have already completed 2 of them.
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen
I hope this helps you to further troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 17, 2011 | Maytag M7DH45B2A Dehumidifier
Unir ran good for 8 months then cut off with current humidity reading LO. Humidity is not LO. Have to set below 40% then runs all the time. The AUTO humidistat sensor must be broke. 1 year...
In addition to a faulty humidistat sensor, there are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
problem.
If none of the above solves the problem, contact Haier Customer Support
1-877-337-3639, before your warranty expires.Haier units will generally show an E1 code if a sensor or circuit is faulty and unit will not run at all.
I hope this helped you troubleshoot & solve the problem
Aug 11, 2011 | Haier DE65EJ Dehumidifier
Fan works. Filters and clean. Heater a Can aster seems warm. Room is damp. Unit does not produce water
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.. Yiu have already cleaned the filter, so that one's covered.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a mechanical unit
turn the control knob to Mai=ximum.
level
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope his helps you to further troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 02, 2011 | Goldstar DH304 Dehumidifier
When starting the dehumidifier the fan starts blowing and the compressor sounds like it starts but there is no water accumulation in the bucket as it runs over time. So far all I hvae done is remove the...
level
problem.
I hope this helps you troubleshoot & solve the problem. Thanks for choosing FixYa.
Jul 23, 2011 | Whirlpool AD40USR Dehumidifier
I noticed today our Goldstar dehumidifier was running, but the back was all frosted up. What does that mean?
That's an indication, that the filter needs to be removed and cleaned.
Turn the unit OFF & unplug it before removing the filter. You can vacuum the filter or if it's really dirty, wash it in warm water and dish washing liquid. Rinse thoroughly and allow to completely dry, before reinstalling. Never operate the unit without the filter installed.
If the coils continue to frost, but not defrost, they also should be cleaned.
Jul 18, 2011 | Goldstar DH304 Dehumidifier
Is there a filter in the 65 pint dehumitifier and if so how do i clean it!!!
Yes, there is a filter in it or it should be. Since you didn't say which model you have, it is in one of two places. Before attempting the filter removal turn the unit OFF and unplug it.
1. It can be accessed by removing the bucket and just inside the bucket holder at the top, behind the louvers on the front, you will see a tab type handle. This is the frame for the filter. Pull it down to remove the filter.
2. There will be what looks like a pull door on the right hand side of the unit, behind the louvers. Pulling straight out on that will remove the filter.
The filter can either be vacuumed to clean it or if it's really dirty, wash it in warm water & dish washing liquid. Rinse thoroughly and allow to completely dry, before reinstalling it. NEVER operate the unit without the filter installed, as it could cause damage to the unit.
Hope this helped you. Please let me know. Thanks.
Jul 02, 2011 | Haier 65-Pint Dehumidifier
Kenmore 54701 Dehumidifier Logo
59 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
