Question about Raypak Versa 130,000 Btu Above Ground Natural Gas Heater
Have a versa heater for my spa and it has electronic ignition. Nothing happens when I turn it on
    Top Expert:
  • Raypak Master
  • 5,075 Answers
If voltage to it see if safety circuit ok
Posted on May 25, 2016
PartsCenter
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
SOURCE: My Laars Lite 2 will not ignite.
I figured it out on my own.
Posted on May 04, 2009
  • 990 Answers
SOURCE: Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Posted on Dec 12, 2009
john224
  • 1378 Answers
SOURCE: My raypak versa spa heater was making a loud sound
Part one - The 'whoosh' or 'boom' at ignition. If those sounds describe your start up your jet(s) are clogged along the gas manifold. Follow the pipe out of the gas valve down to where the gas is shot into the heater. Those bronze ports have a small opening and spiders like to nest inside this area. Turn them out of the manifold and inspect them. You should find those closest to the ignitor are clogged causing the delay and then boom of ignition.
Part 2 - Have this happen enough and the roll out switch / fused link along the bottom of the heaters service panel will open up and disable the heater. It will look like a black rubber tube about 1/4 diameter by about 2 inches long -OR- a white ceramic block about the diameter of a quarter; either will have 2 wires to it and it will be 'close' to the manifold and jets you need to clean out. If you have a way to read resistance across this switch remove the wires from it and check it. If it is open it will need to be replaced.
Posted on Dec 16, 2009
  • 990 Answers
SOURCE: The heater does absolutely nothing when you turn
Unless there is water running out of the inside it is always repairable. You can start by pulling the burner tray and cleaning the unit and the burners. Also pull the wires and clean the leads and contacts. At 23 the heater is probally a milivolt run heater so a small drop in power can stop the heater from working. Often the problem will be the pilot generator or the gas valve. The generator should delevop 1/2 a volt to run the heater. This can be measured with a milivolt meter. You should get 500-700mv from the generator. If you get that and have no pilot you may need a gas valve and if not you probally need a new pilot generator and it would be best to replace the whole pilot assembly. If you live in Calif. or someplace that makes standing pilot obsolet you can probally find these parts on line through Ray-Pak.
But before starting check the filter to be sure it's clean. If you have had the pool for 23 years that goes without saying but I have to say it anyway.
After that you can use a jump wire and isolate each itim in the saftey circut (thermostat, high limits, presure switch...) just follow the wire when it leaves the gas valve and follow it to each item and jump across. If you find one of these itims to be the culpret it is just a simptom and their is probally another problem and the part just keeps the heater from working so as to keep it safe from that problem. Good luck and let me know what you find and we can go further if need be.
Posted on Mar 13, 2010
How do I diagnose ignition problem for raypak versa 055b ?
if pressure switch has voltage both sides check safety circuit if ok check ignitor
May 04, 2014 | Raypak Versa Propane Pool Heater - 55,000...
H250 heater will not ignite,no codes come up but it is"nt even trying to light on spa or heater it does absolutely nothing
If it is doing nothing then you need to investigate this with an electrical meter and find out where the power is not going...
The first place I would check is to see if you are getting power to the transformer...and then if 24v power is coming out of the transformer...
If this is happening the check the control module.. that is the next thing and is probably the bad part...
heatman101
Jul 05, 2011 | Hayward H Series Electronic Ignition...
I have a Laars Lite2 gas spa heater. I just replaced the Fenwal Electronic Eignition. When I turn the power on it starts the start-up process, the gas starts to flow, but no clicking of the igniter, just...
Check and make sure there is nothing fallen on the igniter or spider webs on it. Anything touching it can cause a problem. Make sure wire is not burnt going to igniter. Gas Valve will lock out after a time period if no Ignition.
Jun 20, 2010 | Jandy Laars Lt 250,000 Btu Heater
Heater not coming on
if voltage to unit then check transformer if voltage see if voltage to gas valve when igniting also check pressure switch
May 22, 2010 | Raypak Versa 130,000 Btu Above Ground...
The burners will not ignite
if the unit is used you might have to removed the burner and clean the pilot sometimes rust built in the hole and need to be clean out. I had the same problem.
Apr 11, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool heater cycles off and on
insert on hot water and see if open or close than on cold water and must reverse from hot. if nothing happen replace
May 29, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Raypak Versa 130,000 Btu Above Ground Natural Gas Heater Logo
73 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
