Question about Eddie Bauer Booster Seat
Have seat similar to this one. Mine is product number 41767. The extention legs fold up but do not line up with the holes. What's the trick? Thanks
How re assembly my car seat after wash it:
Most Graco Car Seats use a belt system that feeds from below the car seat up through the slotted holes alongside where the baby's legs will be. The belt will go up throught the clasp system that has 2 latches the plug into the ****** release that goes between the child's legs. Next up to the chest clasp and out through the top holes on the upper back of the car seat. Once through those holes it will thread into a fastner on the back of the car seat. If you have a model number and date of manufacture you can go to gracobaby.com and download a manual for free. If you need help getting it simply post a reply here with your model number and I will get it for you. Good luck and safe travels.
Aug 14, 2012 | Graco Baby Gear
Chair booster seat legs won't collapse for storage
This should help. I've included a section from the user guide for Cosco's On-the-Go Fold Up Booster (41767B)
The full User Guide can be found here: http://www.coscojuvenile.com/usa/eng/DJGFiles/ProductDocuments/87_9-25-2006_124247.pdf
Jun 01, 2012 | Baby Gear
What is a folding table?
A folding table is a two or four legged table that can be flattened via hinges on each of the legs. Folding tables are very convenience because they tend to be very light weight and can save space.
May 29, 2012 | Furniture
MITSUBISHI 380 VRX 2008 How do you remove the headrest
Neither of the answers are actually correct.
Yes you need to press the button PLUS use a number drill or similar in the little hole on the opposite headrest leg @ the same time. The headrest will come out very easily when you do bothe these things @ the same time.
Apr 27, 2012 | Mitsubishi Cars & Trucks
I can't seem to fold my my Kolcraft lil sport stroller.
We're sorry to hear that you'rehaving difficulty folding your Kolcraft Lil Sport stroller. Just belowthe canopy, on both sides, you may find two plastic tabs that can be pulled upto fold the stroller. If you are still having difficulty, please contactour Customer Service team at 800-453-7673, 8 am-6:45 pm Monday - Thursday, or 8am-3:30 pm Friday, Eastern Standard Time. You can also email us at customerservice@kolcraft.com. Please have the followingavailable when you call: 1. Product model number 2. Date of manufacture Both the model number andmanufacture date can be found on the rear leg or fabric tag on the back of thestroller seat.
Jul 02, 2011 | Kolcraft Lil Sport Ahoy Stroller
Don't have the directions to put evenflo exersaucer together, need help. Is there somewhere I can get the directions? reg. number 07T-0538604
Instructions
    • 1 Place the large, round base on the floor. The outwardly curving edge should be facing downward.
    • 2 Attach the three pedestals to the base. To do so, insert your finger into each pedestal and loop the spring within around the hook found on the base in the appropriate holes. Insert the three plastic tabs on each pedestal into the base, locking them into place.
    • 3 Press the wider end of a lower leg assembly onto each pedestal piece. By wiggling the lower leg assembly side to side, you will eventually snap the pieces into place.
    • 4 Hold the seat ring in your lap with the open edge facing upward. Press each of the six wheels into the wheel holders around the edge of the seat ring. Each wheel will snap into place when positioned correctly.
    • 5 Insert the cloth seat into the seat ring, aligning the diamond on the cloth seat with the triangle on the seat ring. Each plastic tab lining the edge of the cloth seat attaches to a peg on the seat ring. Snap these connections into place.
    • 6 Hold the Exersaucer tray on its side and press the seat ring into the center. Once the seat ring snaps into place, it should be able to spin in place.
    • 7 Attach the three spring caps to the Exersaucer tray. These spring caps cover the three large holes in your tray, and are attached by a firm clockwise twist.
    • 8 Attach the upper leg assemblies to the upper leg crowns. These crowns act as the "socket" and the upper leg assemblies act as the "ball." By pressing them together with a click, the upper leg assemblies can twist and rotate in place.
    • 9 Turn the tray upside down and press each upper leg crown base into the round holes in the tray with a firm twist. Each upper leg crown features a height adjustment hole, which will face outward when properly attached.
    • 10 Turn over the tray so that the upper leg assemblies are facing downward. Insert each upper leg assembly into a lower leg assembly, being sure to pull away the height adjustment tab to allow the assemblies to slide together.
    • 11 Press each toy into its respective port on the surface of the tray. The toys each have a distinct base, which clicks into the correspondingly shaped tray port
May 10, 2011 | Toys
I don know how to fold my rear seat down in my 2002 chevy silverado 2500hd. I can make the bottom seat fold up but I want to bring the back of it down. Do I have to take out the seat all the way or is the...
The rear seat backs do not fold down in these trucks, the seat bottom lifts up to gain access to the compartments below but the seat back does not fold down. The only thing you can do is physically remove the rear seats.
Oct 16, 2010 | Chevrolet Silverado 2500HD Cars & Trucks
1987 GMC VanDura electric fold-down seat
If it's anything like my 1994 Vandura, you have a small panel of rocker switchers above the rearview mirror for turning your interior lights and other gadgets(tv, vcr, etc) off and on.
The leftmost switch on mine moves the electric bench seat up and down, *and* forward and back. The trick is that you have to hold it down to make it move.
With mine, even though there are four actions:
- slide seat forward
- slide seat backward
- fold seat down
- fold seat up
there is only one rocker switch.
So what you do is hold "up" on the switch and see what it does. If it slides the seat in either direction, up for your van is for both sliding forward *and* back. To do the opposite direction, just wait a second then press the same button the same way a second time.
If up makes it fold, it's the same principle. Hold the rocker switch depressed in the up position to make it fold up. Wait a moment and repeat to make it go down.
It wasn't intuitive for me either but once you know and play with it a bit it makes sense. Probably better than having four switches up there anyway :)
Jan 26, 2009 | 1987 GMC VanDura
Need directions on how to fold legs
Hi, I can fix this.
First, on the bottom of the legs, there is a thumb latch, press that all the way down into the hold it is in. do this on all three legs.
Then once that is done turn the whole thing to the left, it should fold in two, on the sides, there are three latchs that go into the hole next to the small legs, those latches secure it in place.....
To unfold, simply press on the holding latches, and pull up.
Good Luck.
Gordon & Shirley
Nov 17, 2008 | Evenflo ExerSaucer SmartSteps ABC Stroller
Eddie Bauer Booster Seat Logo
74 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
woodzowl307
ray gallant
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
