Question about Whirlpool ACQ088 Air Conditioner
A/C will not come on
My unit number is ACQ088MROand it will not turn-on. I moved 4years ago and have not turned it on since 2006.
    President:
  • 1,515 Answers
Hi, have you checked for power , tripped breaker maybe? I would think it would be something along that line if it was OK when you left it. You may want to check that out and if you do have power, if this is a window , wall, or a free standing unit, I didn't look it up, but sounds like it from the numbers.Yes it is a window 115 volt unit. Unplug it and make sure the outlet if fine. From outside from a louver, see if you can use something long and slim to turn the fan motor to see if it turns. It wouldn't have a reset on it. I believe its a power problem. If a critter as made a nest inside, it may have used the wiring insulation for building a nest. I have seen this before. You may need to take a good strong light and see if you can remove some knobs and if you know there is voltage to it, check the power on switch for any damage to the wiring. I would start there. Do this and get back to me. It wouldn't be a compressor or motor as the unit has been off. If it had a very small leak in it the compressor wouldn't come on, but the blower/condenser motor would. Check these things out and look very well to see for anything out of place, burned wires, nest or chewed wires, anything. Does this model have any control led lights on the front of it that light up when it runs? If so, you know there is power to it. Please keep me posted and please be kind when rating me as far as my help to you. I will be here if you need me.
Sincerely, and Happy 4th,
Shastalaker7
A/c & Heating Contractor
Posted on Jul 04, 2010
My car has been sitting in my garage for about 4years and now can't restart it it's a Nissan skyline gt25t I have replaced the battery and fuel turns over but will not start
just a suggestion, pull number one sparkplug out, make sure the threads are grounded to engine metal, have someone turn it over a few cranks while your looking at the sparkplug electrodes to see if theres any spark, then go from there.
May 22, 2017 | Nissan Cars & Trucks
I have a 2002 super glide hd about 3 yrs ago my turning signals stopped cancellation by there self. then about 1 yr ago when I turn the switch on the turn signsals would blink about 5 times then about a...
Check the TSM. Remove the unit, and remove the cap on it. If you smell a burnt smell from it that is your problem. Those TSMs control nearly everything on the bike, eventually the bike won't start at all. Simple fix if you're carbureted, but the ECM will have to be reprogrammed if you're injected.
Oct 27, 2013 | 2006 Harley Davidson FXDCI Dyna Super...
When the car is turn on the stick shift will not move, but when the car is off it moves.
When this happend just a couple months ago to me it was the slave cylinder.
Dec 28, 2011 | 2006 Saturn Vue
I have a 2006 dodge charger SXT in which I recently purchased about a year ago. Just a few days ago I experienced that my car does not want to move forward of backwards? My shfter is NOT locked and my car...
t is most likely a faulty torque converter clutch servo/ solenoid
wiring and unit is suspect
while it may look that the pan cannot be removed to change the oil there is a way to do it
if you find a dealer too expensive find an accredited service center or specialist transmission shop and get quotes
the transmission will be generic as car manufacturers do not make their own transmissions but use ones built to their engineering requirements
If it appears sealed , then an accredited shop has the equipment to replace the oil by pumping in and pumping out the oil
May 04, 2017 | 2006 Dodge Charger
The a/c turns of after i move the speed knob pass
check your blower motor resistor, does the reg/ heat work on all speeds? if not take a look at teh resistor for the blower motor, or you may have a bad control unit that needs replaced.
Jul 18, 2010 | 2006 Mitsubishi Eclipse
Ice forming on top front part of unit
usually, ice build up is caused by low refrigerant levels (a dehumidifier is essentially an air conditioner). depending on the unityou may or may not be able to service it. Some of these systems are sealed at the factory and a pierce valve is needed to add refrigerant to the system.
May 07, 2010 | Goldstar DH504EL Dehumidifier
2006 sorento wipers wont go down all the way when off
The wiper motor has a park mode built in. It's one of two possible problems. The park mode is bad and the motor needs to be replaced. Usually this can be identified by the wipers stopping all over the place.
The second is that the linkage off of the motor has moved, and it will park in the same spot all of the time. Here you need to release the motor to linkage nut, and move the arms to where they should be, and retighten.
Sep 11, 2009 | 2006 Kia Sorento
Heating & Cooling Logo
70 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
