Question about Pyramid PB780 Car Audio Amplifier
Good morning friends, my name is Lucio simão, I have a pb780 amplifier model, it is blown open and noticed a trail is missing a diode in position (D 9), located in the middle of the plate, I would like to know the value of this diode. appreciate the attention, my e-mai is lucstones@ig.com.br
  • 24 Answers
Read messages
Posted on Jul 08, 2010
Additional detail about my AUREX STEREO AMP MODEL SB 130. I have change the rexridiwe / power diode but to no avail. This same result. The fuse rated 3.15 blown up 2 times. I wonder will is the cul
A module or an amp is doing a short cicuit. It's time to check if all transistors are valid. Be careful, bipolar and FET transistors behave differently. It can help to compare one by one each transistor from the RIGHT and LEFT amps. Good luck.
Mar 07, 2014 | Audio Players & Recorders
Sansui A200 amplifier dead right channel
Usually is a capacitor or diode blown open up the amp and look for any burnt marks on the motherboard
Feb 07, 2014 | Sansui Audio Players & Recorders
Yamaha no power
you need to check the power supply input of your amplifier using a multimeter set your tester into a dc voltage reading.then measure the power input you must have a DC voltage supply reading..open the cover check the fuse an open fuse will turn the unit to no power.there are causes of blown fuse a shorted power transistor at the circuit will blown the fuse you need to replace faulty transistors before putting up a new fuse...check also the diode at the power supply section ,faulty diode could lead to the same problem..
Sep 30, 2011 | Yamaha P-2500 Amplifier
I have a pmp6000 powered mixer. I was running an ipod in and sending out to one powered speaker. I heard a loud pop and smoke started pouring out of the mixer. I immediately stopped using it. This morning...
Cease using the mixer until it is repaired. One or both of the amps have blown. Further use MAY result in power supply damage. 1 to 6 switching power transistors will have blown and often a Zener diode or two. If the metering resistors smoked, there will be two small surface mounted transistors per channel blown wide open as well. These are all in the HCA2400 amplifier module.
Feb 12, 2011 | Behringer PMP6000 / B215XL Powered Mixer...
I have no sound coming from my amp a rotel rb 981 and rc 980bx . I was changing speaker wires and am afraid i have blown a fuse [but cannot find external one]. powers up but no sound
it is never advised to change wires while the amp is switched on. you may have blown your diodes on your post amp then you have a problem.
have you tried other speakers tested your speaker on another system to rule them out as OK?
if you open the case be careful not to touch any large capacitor as they may still be chared and can give you a nasty belt.
any fuses should be easy to find and to see if they are blown. ensure you get the same rate fuse when you replace. if you see any charing of diodes then i think repair may be costly. good luck.
Nov 12, 2009 | Audio Players & Recorders
Changing clerk name or deleting clerk name/code
Good morning! per review made on its operation manual, there's no topic or discussion about change or deletion of clerk name which would mean that you have to create a new one. In my opinion, this is made to identify accountability for the audit trail review, as well as to control possible fraud. best regards
May 11, 2009 | Casio Parts Cash Register PC Desktop
No output on channel B OF PEAVY2000AND1200
You missed something. Use the good channel (A) to compare resistance and or voltage readings against the defective channel. Obviously you've removed the dead short issues (AC fuse is holding) BUT your signal path is still askew. Any transistors/diodes under suspect should be removed from the circuit for proper testing....Glen
Apr 14, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Samson Servo 170 protection circuit problem!
my friend resistors and diodes don't just go off your circuit without a real problem. those parts gave up because of shortage on your power section, i suggest that you check your power transistros first along with the diodes and resistors.
noisy transformers... hmmmm why is that making sound? the solution there is to dip the power transformer to a thick shellac varnish let it there for let's say an hour then let it dry for a day. then place it back in your unit and see if still sounds
Aug 11, 2008 | Samson Servo 170 Amplifier
Pyramid PB780 Car Audio Amplifier Logo
37 people viewed this question
Top Pyramid Car Audio & Video Experts
Greg Cann
Greg Cann
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
