We have a 8825 with the scanner and the scanner display is always reading "NOT READY" I do not see the lamp turn on when we power the scanner. At first the scanner would copy somethign but the page would be black instaed of the text or lines from our maps. Any thoughts? We have followed the instructions from the manual but they eventually sya contaact a repair person. Any sugeestions in the Billings Montana area? Thanks.
    President:
  • 2,072 Answers
The printer is either performing a reset, a copy quality adjustment, or is just warming up. Any of these procedures can last for at least three minutes.
Sounds like a fuser lamp has gone bad.
For a dealer that can probably reference you for service start here.
14.8 mi Replica Business Solutions, Inc. 670 King Park Drive Billings MT N (406) 839-9228 crduncan@hughes.net
Posted on Apr 18, 2008
Keurig B60 will not stay on
Turn off Auto Start. see manual page 17 for indstructions.
Feb 23, 2012 | Keurig B60 Coffee Maker
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    Where is the power button on a canoscan lide 70 scanner?
    There is no power button on mine. It gets its power from the high speed usb so it is always ready. Every time I boot up my mac I hear the scanner go thru a warm up scan. I have downloaded the twain plugin for photoshop and access it that way. The lamp will go on when you preview scan something.
    Feb 19, 2011 | Canon CanoScan LiDE 70 Flatbed Scanner
    I have umax 4700 scanner. When I tried to scan something it shows "scanner lamp has not warm up yet" & keep counting upto 30 seconds. It will take 4 to five time this exercise than it's ready...
    hi rakyansfi,
    Is that scanner old?because lamp has its own life span.
    it cannot scan if the lamp is insufficient power or light.
    regards,
    mastergani
    Dec 30, 2010 | Umax Astra 6700 Flatbed Scanner
    I have a Xerox 7356 Scanner which continually says: Not Ready on the display. Any suggestions on how to troubleshoot this problem or where to go on-line to research troubleshooting?
    it is likely the lamp.
    Easy fix.
    Buy a new lamp at a good lamp supply store. Type F32T8 SPX41
    Make sure the back plate is white and re-normalize the cameras.
    If you get the "NOT READY" message only after you insert an original
    then the problem is likely the motion sensor.
    Oct 14, 2010 | Xerox 8830 Copier
    My Canon copy NP 6035 if in turn it does not want to live. sound briefly returned to off himself. how the solution. thanks.
    The copier comes ON then it turns it's self Off , Correct? Turn the copier back ON and hold the Main power switch ON and the display will show a error code. Read it and let the copier turn Off. You most likely have a dead AC short. The error code maybe a E0202 or E000 . One of the lamps are blown or broken and shorting out. You probly have a blown scanning Lamp or fuse. You may also, have a shorted out Scanner Power Cable. It's black and powers the scanner lamp > sometimes the cable crack's and exposes the AC wire. That is a fun job. It may just be a blown fuser lamp.. Good Luck
    Sep 06, 2010 | Canon NP 6035 Copier
    Fi-4120c2 error Code
    The scanner does self-diagnostic when receiving Read Command (to start scanning) and displays the result if any error or alarm is detected.
    Error code-E3 in Fi-4120c2 scanner means "Light intensity check" . When this error is displayed on the scanner panel, TWAIN displays the following error-
    " Irregular status is detected in scanner. If this status recurs after power cycling, please give following Sense key and ASC code to your service provider.
    If ASC code is the following, please confirm following status before power cycling’
    - When ASC=0x580, confirm if the shipping lock (if any) is set at “Release” position.
    - When ASC=0x680, clean the sheet guide (white part) in ADF.
    (Error Code DS42001)
    E3 explains Optical alarm (back). This alarm occurs if the gain adjustment of the CCD amplifier does not succeed at a READ command for the first document, or during scanning.
    Probable causes:
    - The lamp, the optical system or white sheet guide is dirty.
    - Defective lamp or CCD.
    - Connector disconnected
    To check and resolve the issue, lease follow the steps provided below:
    1. Is sheet guide (white part) in the reading position dirty?
    #Open the ADF and clean the sheet guide (white part) and the glass.
    2. Is the lamp ON?
    3. Are the cables damaged?
    4. Are the connectors connected correctly?
    #Disconnect SCSI cable and turn the scanner ON. Open the ADF and press Cover open sensor to see if the lamp lights. If not, the error is caused by the defective lamp.
    5. Is the optical unit dirty?
    6. Are the cables damaged?
    7. Are the connectors connected correctly?
    # Check and Clean (ADF back):
    # Check if inside of the grass for Upper unit ASSY is dirty. Clean inside of the glass of the dust cover.
    9. If the issue still persists, then you may have to replace Optical unit.
    Hope the above information will be helpful.
    Please revert if you have further queries.
    Thanks & regards,
    TechSatya
    Oct 08, 2008 | Fujitsu fi-4120C Path-Through Scanner
    Xerox 8825
    hi im jules_09.have you tried changing you cleaning blade or roller?if yes check the exposure lamp my its deffective if not.also black copy is cause by over tone developer is also deffective
    Oct 02, 2007 | Xerox 8825 Copier
    Microtek Scanmaker 9800 XL
    JKL Components was able to create a new bulb for me. Worked perfectly. Call Larry: 818-896-0019 ext 124. Very nice, and very helpful
    Sep 12, 2007 | Microtek ScanMaker 9800XL Flatbed Scanner
    107 people viewed this question
    jasbo
    jasbo
