Question about Great Plains Industries Gpi& Fuel Pump
Do i have to drop the fuel tank on a chevy 1500 blazer to get to the fuel pump or is there another way?
  • 333 Answers
Yes you have to drop it since it is a blazer. If it was a pickup then you could just raise the bed. But I found a good way to drop it is use a ratchet strap hook it to the frame and driveshaft under the tank then you can drop it enough to get the pump out. And ratchet it back up to clamp it back.
However when you change the pump it would be best to drop it and clean it out real good before you put a new pump in. You would be amazed at all the trash that is in it. That is probably why it went out.
Have fun.
Posted on Jul 05, 2010
1994 chevy blazer fuel pump replace
Pretty straight forward. You have to drop the tank out from under the SUV there are 2 straps that hold the tank in place. Here is a youtube video of the process.
Jun 27, 2014 | Chevrolet 1994 Chevrolet Blazer/jimmy full...
I dont know where the fuel pump is located on my chevy blazer and when i find it how do i replace it? do i have to drop the gas tank?
yes you have to drop the tank as the pump is in the tank.WARNING you may end up putting lines and a sender in aswell if they are rusty.
Dec 02, 2010 | 1991 Chevrolet S-10 Blazer
Changing fuel pump for 1996 chevy blazer
Whats the problem? To change the pump you must drop down your gas tank. Make sure it is as empty as you can get it though! Once the tank is dropped you need to twist the retainer ring (usually with a screwdriver, and make sure its got some tape on it so it wont spark. then you can replace your pump.
Jul 05, 2010 | 1996 Chevrolet Blazer
How to change a fuel pump on a 2000 chevy 1500
The fuel pump is located inside the fuel tank. You can either drop the fuel tank and remove the pump or get 3 friends and unbolt the bed and then remove the pump. Once you have access to the pump, disconnect the fuel lines and electrical connections. Then remove the pump from the tank.
Apr 26, 2010 | 2000 Chevrolet Silverado 1500
Replacing a 2000 chevy blazer fuel pump and help
the gas tank will be needed to be dropped to gain access to the top of the tank to remove the sender with the attaching fuel pump on it. basicly you disconnect all lines first then the tank straps. the tank will be lighter if no fuel is in it too
Feb 13, 2010 | 2000 Chevrolet Blazer
How do you replace the fuel pump on a 1998 chevy blazer
You must drop the fuel tank its inside the tank.once you have tank down you will see a large round ring it has to be turned to be able to remove the fuel pump. reverse installation.
Jan 15, 2010 | 1998 Chevrolet Blazer
How do i get to the fuel pump on a 1997 s10 blazer
Unless there is an access panel inside the vehicle above the fuel pump, you will have to remove the fuel tank in order to access the pump. Do not forget to replace the fuel filter. Partially clogged fuel filter is one of the causes of a failed fuel pump.
Oct 10, 2009 | 1997 Chevrolet Blazer
Process to change fuel pump on 2001 chevy silverado 1500
take the six bed bolt loose and then take three buddies slide the bed back put in the new pump slide it back n place and put the bed bolts back in. if u drop the tank u can easily break the hard plastis lines that go to the fuel tank. u only have to take the fill lines and taillight wires loose this way its alot quicker, and easier.
Jul 29, 2009 | 2001 Chevrolet Silverado 1500
2002 chevy blazer fuel pump (4 door)
yes you have to drop the tank. you will also need a fuel line tool to unhook the fuel lines. before you drop the tank see if tou can reach and wiggle the electrical connection on the top of the tank. these pumps have a pigtail issue. please rate
Dec 08, 2008 | 2002 Chevrolet Blazer
Great Plains Industries Gpi& Fuel Pump  Logo
Top Great Plains Industries Garden Experts
Thomas Perkins
Thomas Perkins
Mai Lor
RSole
Are you a Great Plains Industries Garden Expert? Answer questions, earn points and help others
