Question about Epson Stylus Pro 9600 InkJet Printer
How to upload firmware to 9600 - Epson Stylus Pro 9600 InkJet Printer
    Genius:
  • 1,447 Answers
Download the driver from this site
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes&oid=-10235&infoType=Overview
after extracting/unzipping the file it will include a pdf file on how to upload the firmware
hope this help, have a nice day!!
Posted on Apr 17, 2008
Bricked. firmware needed
It's kinda hard to answer these when we don't know the product name or model number. If the device has an RS232 serial port, you can usually use it (9600-8-N-1) to get to the boot menu, and there is often an option to upload firmware via XMODEM.
Caveat: if the boot menu gives you the option of increasing the baud rate above 9600, use that before starting the transfer. 9600 baud means ~9K/sec, which translates to roughly 2 minutes per Megabyte.
Feb 28, 2014 | NetGear Computers & Internet
Firmware on main board 10000100 error
Live (free support) chat with Epson:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&category=Products&infoType=Contact&oid=14397&prodoid=19302859
Nov 06, 2013 | Epson Stylus Pro 9600 InkJet Printer
FIRMWARE ON MAINBOARD
Did you send the old board back Normally it is a removable chip and replacement boards don't come with them you have to Remove & replace
John
WON'T POWER UP SHOWS HD ERROR 177
Either the HD is bad or you will need to reinstall the O.S. /firmware.
the firmware is avail on the alesis site.
hope this helps.
dave
Jun 08, 2009 | Alesis MasterLink ML-9600
NO POWER UP
dave
Problem with writting from hd to cd
try to reinstall the O.S. /firmware.
dave
Dec 22, 2008 | Alesis MasterLink ML-9600
Firmware Update Fails
I'm not sure this will help, but per Magellan (see below), the firmware update must be run twice as your firmware is earlier than version 3. I have a GPS 315 with v2.03 and can't find a cable to update mine. My GPS 315 does not appear to have a cable connection either, just a screw port on the back for a carrying strap. Was your homemade cable wireless? How did you make it?
You must follow instructions exactly to avoid corrupting your unit's flash memory.
  1. Select the .zip file and save it to your hard drive. Open the .zip file using WinZip.
  2. Connect your receiver to your PC using the PC or Power/Data Cable.
  3. Turn on the receiver and press the NAV key.
  4. Make sure the batteries are at least 50% full.
  5. Select the MAGUP executable file from your PC.
  6. Follow the instruction until you see the message Upload Complete.
  7. If your unit's software version is earlier than 3.00, you will be prompted to turn the unit on again and load the software a second time. Follow the instructions.
Jul 19, 2008 | Magellan GPS 315 GPS Receiver
Epson 9600
Are you sure it is not 10000020?
If so, it is a CPU error:
􀂆 Cause of trouble:
Defective circuit board or faulty CPU soldering. Program trouble or generation
error.
􀂆 Remedy:
• Firmware Reinstallation
• Replace the MAIN Board
Firmware re-installation has to be done by either replacing the ROMM or through the parallel interface with a PC
This is all according to the svc manual. I'm not a tech.
May 10, 2008 | Epson Stylus Pro 9600 InkJet Printer
Video incompatibility?
The driver & Catalyst Control Center for the ATI Radeon 9600 Series is listed below for Win XP home & Pro. Lasted updated Jan-16-2008.
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/gamesite/8-1_xp32_dd_ccc_wdm_enu_57717.exe
Your install will run better if you remove previous software versions for the Radeon 9600. If your attempt to remove old software fails. ownload & run ATI's cat-uninstaller.exe found here.:
http://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&questionID=1447
Jan 20, 2008 | Intel Motherboard
Epson Stylus Pro 9600 InkJet Printer Logo
234 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
