Question about LG DLE3777 Electric Dryer
Not driying clothes - LG DLE3777 Electric Dryer
  • LG Master
  • 43,501 Answers
Hi, If you have a gas dryernot driying clothes - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your not driying clothes - 2_bing.gifsrc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gifElectric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jul 11, 2010
Dies when put in gear
Place it in the suibn and let uit driy out some more. YOu may still have a wet electricial contact.
Aug 10, 2014 | CanAm 2007 Outlander MAX 400 H.O.XT
What is the best on-line store to but hunting cloths?
Try this: http://www.cabelas.com/catalog/browse/_/N-1100943?WT.srch=1&WT.tsrc=PPC&WT.mc_id=google'meh_General_General%2B2'USA&WT.z_mc_id1=sYVEWO2sX&rid=20&pcrid=16293457403&gclid=CNbv0pnXgLUCFYpY3godVAkAZA
its has everything!
Jan 24, 2013 | Hunting
How do I wash my dog's clothing?
As with anything, always read the label for instructions on how to wash the clothing. I would also use a hypoallergenic laundry detergent because my dog was allergic to the detergent we once kept in the house.
Dec 31, 2012 | Dogs
I am repairing my 1995 camaro with a 3.4 litre, i am replacing the intake gasket and the air intake plentum gasket, and valve cover gaskets, I am ready to reassemble and need to know were some bolts go,...
ok, common error. First group your bolts by their lokeness. length,diameter, and thread.. Then if you have 4 holes, find 4 bolts that fit. they should all protrude the same amount,about 1/2 in. Finger start only,about3-5 turns, use no tools. regardless of length if its in the right hole it will protrude the same as the others. Driy run if neededbut use no force on any of them. Good luck. Contact me if you have a question. If you force a long bolt down, you can punch a hole through something and a bolt too short won't take the torque or strip. phone 909 630 3192
Jul 08, 2009 | 1995 Chevrolet Camaro
Changing the headlight bulb. I installed the new bulb and still does not work. what to do next. also how do i remove the lense as it is full of water
Ck yhe voltage at the plug, and the water? hmmmmm. Drill a 1/8" hole at the lowest point and let it drain. Once you get your light working leave it on to driy out th lens when driving, then dab clear silicone on the hole without forcing any into the lamp. Unless you find the leak you will be needing this handy dandy modification on a regular basis. The Lens is glued over and onto the reflector. I hate when they do that. Good luck.
Jul 06, 2009 | 1991 Chevrolet C1500
C6 Transmission wont shift into 3rd gear
The shift shaft has stuck. The modulater shifts threw all gears so if you pull the hose off and there is no fluid leak then the modulater valve may be good. You could try turning the adjusting screw inside the vachumm hose and if that does not work pull the oil pand and lube all the shift solinoids they may have rusted fron condensation. Use a screw driver to get it to move the shift levers and buy some lucas trasmisson oil and run it in there it will soften the seals. Hope this helps.
May 13, 2009 | 1981 Chevrolet Corvette
My dryer work,but has a noise when it is driying.
You may just have a squeaky pulley.If you take off the back and turn it on you should be able to locate it.Hit it with a little wd40 or silicone spray.
Len West
Feb 19, 2009 | Maytag Performa PAV2200
An Old Gas Kenmore 7870701
Michael, here are a few things to check. Can you turn the drum by hand? If not you may have something in the blower wheel binding the motor. You can acess the blower by removing the back panel and removing the two screws under the vent screen on top. Once the back panel is removed the blower wheel will be behind the vent. Three or four screws and it's off. If the blower wheel is ok, it may be the motor itself going bad. Have someone hold the door switch down and while pressing start, give the drum a turn. If it starts running, it's probably a bad motor. Other things to look for is bad rollers. If they are bound up it may prevent the dryer from starting. Check these things out first...Catriver..post back.
Jan 03, 2007 | Kenmore 72602 Gas Dryer
LG DLE3777 Electric Dryer Logo
60 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
