Question about Craftsman Welding Tools
My craftsman 205690 mig welder will not feed wire serial# H06-538560
  • 6,826 Answers
Check button on the handle to see if it has current running to it. Check the motor that spins the wire to see if the coil inside is continuous using a multimeter, when unplugged.
Check that the wire is routed on to serrated grips of the wheel(s) that rotates to feed the wire.
Posted on Jul 04, 2010
I have a craftsman 20511 mig welder it will start welding without pushing trigger
Elmer, If you remove the gun assembly from the machine, if the machine is now not feeding wire, the problem is most likely the gun trigger is faulty. The switch contacts heat up and start sticking over time. If able too disassemble and clean trigger contacts. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CRAFTSMAN 934 205111 Operator Manual
commin problem with wire feed welder
Wire won stop feeding
May 02, 2016 | Craftsman Welding Tools
Cebora mini mig on trigger no wire feed ,power on?
Cebora mini mig on trigger no wire feed ,power on? - Fixya
www.fixya.com/.../t25810314-cebora_mini_mig_trigger_no_wire_feed
3 hours ago - Question about MIG Welders ... Weld corp mig 100 turn machine on andwire keeps feeding without ... Welder running but wont feed wire etc.
Aug 05, 2015 | Welding Tools
Need a wiring diagram for a century quick fix wire feed welder
If you can give the code code number I can help you. The code number should be in the same plate as the serial and model number.
Jan 19, 2014 | Welding Tools
Fan runs but nothing else
check small wire on opposite end of Gun. May not be connected well
Nov 17, 2013 | Craftsman 20568N 85 Amp 120 Volt Gasless...
What is required to switch from steel to gas on light duty mig welders
if you mean from flux core wire to gas shielded wire you will need a tank and regulators,and feed hose from the welder to the tank
Sep 06, 2009 | Lincoln Electric LE 83180 Century...
Flux wire on Dual Mig Welder not feeding.
Change the contact tip.This is the most common problem. The tip gets burned and keeps the wire from feeding. You should always have extra tips on hand.
Aug 03, 2009 | RTO Flux Wire Welder Dual Mig 131 Ti 1 Gas...
No arc for craftsman professional wire feed welder
either your not grounded on the vehicle very good or you lost the ground either in your gun or on your clamp
Apr 04, 2009 | Welding Tools
Welding Tools Logo
326 people viewed this question
Top Craftsman Welding Tools Experts
AZBen
AZBen
Gil Shultz
L Pfaff
L Pfaff
Are you a Craftsman Welding Tool Expert? Answer questions, earn points and help others
