Question about Maytag Refrigerators
I have MAYTAG side-by-side refrigerator SS-1 Model # RSW2200E, 21.7 cub.ft. The deep freezer wall at back has ice build up, the freezer and refrigerator does not get cold. Could you please guide me to fix the problems. Thank You.......This is JEFF.......
fridgetech
  • 473 Answers
SOURCE: Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Posted on Oct 10, 2007
Amigaman
  • 248 Answers
SOURCE: Model TFX22ZPDAAA GE side by side
It's usually the defrost heater on this model. Pull rear panel of freezer and remove the heater, (2 screws). It's at bottom of coils. Take to your parts place and they should be able to ohm out for you to see if it's ok. If it's all blackened, probably heater.
A check you can make is to pull refrigerator out to access back. UNPLUG UNIT!
Remove panel over control board on back of fridge. On the blue connector in bottom of board note the defrost terminal as specified on board. Unplug connector and put a jump wire from this terminal on the CONNECTOR, to the terminal that has the wire going to it with no wire next to it. Plug in refrigerator. If defrost heater is good, it should start glowing red within a few minutes. If it doesn't replace it.
Posted on Nov 14, 2007
  • 66 Answers
SOURCE: ice build up in bottom of freezer
Check the ice maker. sometimes they get cracked a will leak water into the freezer compartment. Also check the ice maker fill tube for leaks or someone could have spilled something. Although this is tipical of a clogged drain. What happens is when the fridge go into derfost, it will melt all the frost that is on the evaporator, turning it into water. The water drains down to a trough under the evaporator and down a drain hole in the trough ( this trough is behind the evaporator cover ) Removing the melted frost from the freezer. If that drain is clogged, the water cannot leave the freezer. Then when the fridge starts back up ,it will freez the water that was not drained. After repeated defrosting the water will fill this trough and run off into the bottom of the freezer to be frozzen when the fridge starts to cool again.
Posted on Nov 16, 2008
rpbuice
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
peyton32034
  • 410 Answers
SOURCE: GSS22KGPD WW G.E. side by side 21 Cub ft.
You beat me to an answer for you. the freeze up was most likely in the door. you may want to check with GE if my memory serves me corret there is a servie bulletin for this condition. thanks for using fixya Peyton....
Posted on Feb 17, 2009
What are the dimensions of the kenmore elite 22.4 cu.ft. bottom freezer refrigerator?
26'wide X 19" deep X 21'' front to back. I'll never have a side by side again!
Jul 04, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Maytag 21 cu ft top freezer, not getting cold enough
whats not getting cold ? freezer or fresh food? if FF check for defrost problem by feeling back of freezer panel for ice build-up,
Oct 14, 2013 | Maytag Refrigerators
Ice build up bottom of freezer compartment and water leaking from un der the refrigerator i think maybe a drain is plugged and how do i fix it. and the model #mzd2766gew
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing.By pulling the ref. from the wall there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps,
Gene
Aug 05, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Refrigerator side is not cooling however freezer is fine model mzd2766bew
Check the that the fan in the freezer is running . If so check if there is frost on the back wall of the freezer.
Nov 01, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
The freezer is cold but not cold enough to make ice
Check the back (interior) lower half of the freezer wall. If you see a frost build up, you either have an issue with your defrost cicuit (timer, heater, thermostat) or the evaporator (freezer) fan is not running. If there is not a frost build up on the back wall you either have a sealed system (weak compressor, leak or restriction) problem....or the condensor fan motor is not working. This would cause the compressor to overheat and shut down until cooled, and prevent the deep freeze.
Jun 05, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice accumilation next to fan in freezer compartment
u have a defrost problem need to replace heater and tstat
Mar 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Refigerator 21 cub Top Freezer not able to freeze water
Sounds like you are about ready to loose your circulation fan.It is located in the freezers back wall.You should replace it.Not to difficult.If you need a walk threw let me know.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 21, 2009 | Refrigerators
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
WHIRLPOOL 25.3 CU.FT MODEL ED5FHEXNT00
If the frost is on the back wall of the freezer then you most likely have a defrost problem or a bad evaporator fan motor.
Jan 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Maytag model RTC17A
how is freeezer side doing? Do u have any frost build up in freezer back wall and is you fan in freezer blowing?
Aug 31, 2007 | Maytag MSD2756GES Side by Side...
Refrigerators Logo
134 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
