Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
None of the display lights will come on. All I can do is lock the drawer.
  • Fisher and P... Master
  • 3,247 Answers
Is this happening with both drawers?
Not sure what you mean by lock the drawer. The drawer will lock only if you press Start and the motor starts to operate.
Do you have a LCD display on the drawer which shows time etc? This is not available with integrated units.
Posted on Jul 30, 2010
Dd603 bottom drawer locked shut, no displays with power on. How do I get the drawer open?
The thermal fuse that cuts of power to the drawer has been tripped. This means you will need to replace the heater assembly at the base of the drawer. It is not cheap - could set you back by $350-400 to replace.
To open the drawer you need to turn the mains power off and then simply pull the drawer out with a little force. The lid seal is jammed shut because the lid seal actuator motors are locked after the power failed. Do not shut the drawer back as this will damage the lid seal. You will have to call a technician to replace the heater assembly and restore power to the drawer. Hopefully the top drawer is working ok.
Aug 01, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Front load washer door will not lock
Hello Phyllis Emmett - Do you notice any error codes displayed on the control panel or lights blinking? If so and the panel displays "DR", the door may have a defective door lock switch. However, if panel displays "DDO" either the drawer is not closing, magnet may be missing or have a defective reed switch, which you will need to contact a professional to diagnose the unit.
Sep 24, 2012 | Frigidaire Affinity ATF7000E Front Load...
My dishwasher is showing signs of a spanner
I am slightly unsure if your double drawer dishwasher is the prefinished model (self standing with LCD display) or the integrated model with no LCD display.
The spanner symbol on the top drawer is telling you that a fault code is actuated. But I am not sure where this symbol is on your unit if it is built -in (integrated model).
You will have to check which red light (from the left) is coming on.
I assume there are 5 lights on the inside of drawer.
With the bottom drawer - again you will have to check which light from the left comes on sometimes as you mentioned.
If you have a user manual you should be able to tell what Fault code it is - something like F1 or F2 etc. Is it continuously beeping when the red light is on? How do you turn the beeps off?
The scrubbing bush symbol on bottom drawer may not be a problem. It appears the drawer is programmed to a particular option. But I am not sure where this symbol is showing if you do not have an LCD display panel. You can reset the option - possibly auto lock or auto power or dish cleaned (depending on your model) if you follow the user manual.
happy to take you through a possible cause of the problem if you post answers to my questions above.
Jan 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water will not drain out of top drawer
To determine if your pump work, before attempting access from the bottom of the top drawer: You can manually pump the water out by doing the following:
1- Press the Power button to turn off the display.
2- Press the Lock button and then the start button the same tim. Hold them until the display showing up.
3- If the display is not clear with all the characters, press power button to see clear the display.
4- The first display is bL, then Er,Ld..dd, FU, P1, P2...by pressing the Start button to go by the sequence until P2 (drain). If you miss, be patient to continue press and release the start button to get back to P2.
5 When is is at P2, press Lock button to tun on the drain. When you hear the water flowing to the drain, you could pull the top drain to see how the water is draining.
6- When the water is out, press the lock button again to stop it.
7-When it is done, press the Power button to get out of manual mode.
If this is working, then your water is there because you are running the bottom and your air gap allow back flow to the top drawer.
Please let me know if this is not the case.
Jun 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
After self cleaning,i noticed the lock light blinking,the door opens but when i try to use the oven dr is displayed on the screen and nothing functions. (Kenmore warm and ready drawer-self cleaning ov
This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
Jun 03, 2009 | Ovens
LG HT503PH Disc drawer will not open and displays "locked"
there should be a key synbol on the remote. press pwr off, then press the pwr on and the key button at the same time. The usual fault is the child lock has been activated.
Jan 05, 2009 | LG Televison & Video
Fisher and Paykel dishdraw DS603
look closely at hte display in theright corner is there a little icon that looks like a "lock". if so your control lock is on. do you get any response from any buttons??? if your able to power it up did you try to stop/andrestart unit. sounds like a silly question but sometimes the lid locks down from a power surge/interuption. restarting or canceling current cycle forced drawer to unlock and lock itself..assuming this is the top drawer is the bottom functioning ok??, behind the bottom drawer taped on back wall of inside of unit is atech sheet, with a pretty good troubleshooter. to remove the drawer push in rectangler hinge locks in hte bottom front corner of drawer front, just below the circles(no noeed to remove the circles)push themin and slide back the drawer will lift off and your able to set it aside(wont come out to far its connected by the hoses but itll come out enough(reset the door unto the hinge slides and pull hte lock latch foward to lock back into place
Mar 16, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water pump on F&P DD603
Feb 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer has no electrical power
I f lock is activated during wash the draw will appear dead when wash cycle finishes ,check for lock symbol in lcd display if it is visible press lock button for about 5 seconds until you hear beep release button and try POWER button
Aug 23, 2007 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
