Question about Toshiba SD-K760 DVD Player
SD4980SU will not play or open (disc in tray)
3 Suggested Answers
  • 35 Answers
SOURCE: DVD disc tray will not open
Without knowing the model for the unit, it makes it a little difficult to troubleshoot, but usually the easiest way to get one of these to open up is to try resetting them. This is done on MOST DVD players by unplugging them for about 30 seconds while you hold the power button down to discharge any power that might be held in the unit, then plugging the unit back in and trying to eject it again. Keep in mind, that if the unit was moved (or even if something caused the unit to shift, like a person jumping near it) then the problem could be the dvd has become dislodged from the tray. Many dvd players will have a small hole on the front (usually below the tray) where if you insert a paper clip in about a half inch, will eject the tray part way, and then you can gently pull it out the rest of the way (making sure you do not keep pulling if you feel resistence as the dvd might have skipped out of the tray track). IF worse comes to worse and you don't have a warrenty on the unit, many dvd players can be opened by removing 1-2 screws from the left and right sides, and possibly 1-4 screws from the back of the unit (look around the edges, the screws near the ports on the back usually holds those ports in place and do not need to be removed to take the case off). Once the screws are removed you would pull back and up on the case to open the dvd player. Keep in mind, this voids a MFG warranty. Once the case is off you should be able to see the dvd and remove it unless you have a cheap dvd player which has an enclosed drive. Remove the dvd and with the case still off, plug the power in (DO NOT TOUCH ANYTHING INSIDE WHILE THE POWER IS PLUGGED IN) and try hitting the eject button on the front. IF it ejects now, you should be good to go, just put the case back on. IF it doesn't eject, then your motor is probably bad (or something is blocking the track) and it is usually safer/easier at this point to just go buy a new dvd drive.
Posted on Jul 31, 2009
  • 16 Answers
SOURCE: Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Posted on Aug 09, 2009
Can the DVD player be played while on it side.
Yes it will play on it's side after the disc has been clamped in the player. If the disc tray is not designed to be upright then the disc will fall out when you open the tray
Sep 09, 2014 | Cyberhome Televison & Video
Yes when I try to open the Xbox 360 disc tray the power button in the center flashes as if the disc tray is opening, but doesnt open. it flashes even when i havnt pressed a button for it to open the d
Try turning off the 360 then turning the xbox on its side, turn the machine back on holding the eject button and the power button together for about 30 secs then the machine should function normally
Jun 19, 2014 | Microsoft Xbox 360 Console
How to play movie dvd in playstation 2 ?
open dvd case.
take out disc.
place disc on ps2 disc tray.
put disc tray into console.
enjoy.
Jul 08, 2010 | Sony PlayStation 2 (PS2) Console
Dvd tray will not open or play
The reason your player keeps reading a disc and do not play is because the the disc tray is not sitting the disc properly on the lens.
The disc tray is faulty, the mechanism that controls the opening and closing of the tray is damaged and needs repair.
To fix this, you have to get the appropriate screwdriver, open the cover of the player.
You will see a mechanism by the opening of the tray that controls the disc tray.
Get a replacement mechanism and change it. Mostly the rubber slacks and does not control the tray properly.
Changing the mechanism will solve the problem.
Take care
Jun 15, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
Put disc in xbox 360, said reading then open tray. wont play no discs
@paulhull58 when the disc tray closes push down firmly on the top of your xbox where the tray is. if not clean your disc.
Apr 04, 2010 | Microsoft Xbox 360 Console
Disc changer won't open, won't play DVDs. RCA RTD
Check the belt inside underneed the tray if this is still in place.
if not put belt back on
Feb 15, 2010 | Bose Lifestyle 12 System
Aug 02, 2009 | Lite On LVW-5005X DVD Recorder
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
I need to change region code for goodmans GDVD200CDGM
Region Code Hack: GOODMANS GDVD-200-CDG:
To convert this player to Multi-Region
1. Open the disc tray.
2. Place a region 1 disc in the tray, but don't close it.
3. Press the buttons 0, 1, 2 and then 3 on your remote control in order, one at a time.
4. Press the play button on either your remote or the player.
To return this player back to Region 2 only and its factory default settings
2. Press the Zoom button on your remote control.
3. Press the Retu To return this player to Region 2 only (alternative method) rn button on your remote control.
4. Your player should now go into Standby mode.
5. Press the Power button on your remote control.
i). Open the disc tray
ii). Place a region 2 disc in the tray, but don't close it
iii). Press the buttons Return and then Play on your remote control in order, one at a time
Aug 21, 2008 | Goodmans Televison & Video
Toshiba SD-K760 DVD Player Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
