Question about Ice-O-Matic ICEU220HA Undercounter Ice Machine
I've adjusted my Ice-o-Matic ICEU300FA1 from 16 sec. to 4 sec. the bridge seems to be better but still thick. We have to break it up to bag it. thanks Dan
Short freeze time. no ice
Posted on Jul 16, 2010
How do I adjust bridge thickness on ice o matic
Adjust the Timed freeze. The freeze timer is an adjustable timer used to control the ice bridge thickness. The freeze timer is factory set but may need to be adjusted upon initial start up of the machine. When time is added to the freeze timer the length of the freeze cycle is increased, therefore the ice bridge thickness is increased. When time is removed from the timer, the freeze is shorted and the ice bridge thickness is decreased. The freeze timer can be adjusted by sliding one or more switches to either the ON or OFF position to 1/8'' ( 3mm ). If bridge is too thick remove enough time from the timer to achieve proper thickness. If bridge is to thine add enough time to timer to achieve proper thickness.
NOTE: The freeze timer on ECP models is located on the circuit board. It operates and is adjusted as described above. Now if you have had this machine for awhile and it was making the right bridge thickness and is now making thinner ice i would look at the purge valve to make sure it is not letting water seep out of the sump tray during freeze cycle this will cause the sump tray to keep filling up with water and will cause thin ice.
Sep 15, 2014 | Kitchen Appliances - Others
I have a ice-o-matic 400ha2 ice machine that is not making much ice and is to thick. the timer has been replaced,but no change
reduce the thickness thermostat that initiates the timer to minimum, then increase until good ice made.
Aug 29, 2014 | Kitchen Appliances - Others
Ice o matic troubleshooting
If you have tried to take some time off of the freeze timer and bridge thickness is still to thick then depending on model.
1. Replace freeze timer.
2. Some models the timer is on the control board if so then you will need to replace the board.
Aug 27, 2014 | Kitchen Appliances - Others
Ice bridge to thick
there is a timer, adjusted by seconds, first make sure the condenser coil located under the ice bin is clean. the harvest is initiated by suction pressure once the pressure switch makes contact the time delay will time out initiating the harvest. you can fine tune the bridge with the time delay.
Jul 07, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice to thick
your machine should have a bridge thickness of 1/8 of an inch. you can go to the freeze timer and take some time out to shorten the freeze cycle buy sliding the switches to on and off. example if switch is set to on at 18 then you wont to turn that switch to off and turn the next lowest number switch to on until you achieve the right thickness of ice. if this dose not work then replace freeze timer.
Apr 19, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Cme 506 cubes too small
turn ice bridge thickness screw clockwise to thicken and counterclockwise to get thinner. Do not turn anymore than about 1/8 turn between freeze cycles. the adjustment screw is very finicky and requires patience in setting properly. the distance from the bridge thickness gauge to freeze platen is approximately 1/4 - 5/16 of an inch.
Nov 20, 2012 | Scotsman Ice Machine, Cuber, 1825 lb....
ICEU150 bridge thickness time delay to 1 second and the bridge thickness is still to thick
The bridge thickness on this model starts with the low pressure cut-in control that then in turn starts the timer. It sounds like you have either a bad low pressure control or one that has been tinkered with. To start with if you have a low pressure gauge that you trust what I do is take all of the time off of the timer and unplug the water pump. Then start the unit and watch the low pressure gauge to see at what pressure the harvest starts. an ICEU150 with R-404A should cut in at 44psi. Once that is set plug the water pump in again, put about 400 seconds on the timer, see how thick the ice is after 2 cycles and adjust as needed.
Jun 09, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
ICE-O-MATIC ICEU220HA2 bridge too thick. Is the time delay relay the "finnish" relay that adjusts bridge thickness? If so, I'm not getting any change in thickness with time adjustment.If the time delay...
The bridge thickness on this model starts with the low pressure cut-in control that then in turn starts the timer. To start with if you have a low pressure gauge that you trust what I do is take all of the time off of the timer and unplug the water pump. Then start the unit and watch the low pressure gauge to see at what pressure the harvest starts. an ICEU220 with R-404A should cut in at 45psi. Once that is set plug the water pump in again, put about 400 seconds on the timer, see how thick the ice is after 2 cycles and adjust as needed.
Apr 06, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
I HAVE A ICE O MATIC 0250HA4 which start making ice in 2 minute cut off and havest engine start working it keep doing this over and over
the thickness sensor is too close to the where the ice is being made. you will need to either bend it out a bit or use the adjustment screw. the latter is more preferred.
Jan 12, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice-O-Matic ICEU220HA Undercounter Ice Machine Logo
538 people viewed this question
Top Ice Kitchen Appliances - Others Experts
jasbo
jasbo
mike cooper
JoyEd Stevenson
JoyEd Stevenson
Level 1 Expert
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
