Question about HP LaserJet 3150 All-In-One Printer
3150 fax machine outputs a blank page when my fax sends to it
When I send a fax to the 3150 Laserjet my fax says it sent it properly. Status back says OK. The person on the other end says: he gets a blank page, The fax shows "Recieve error ", the fax log has two error indications "Error connection120, and the other a while later in the log says error 791. He also says none of these error codes are mentioned in the manual.
What is the problem?
  • lrmatwork Apr 17, 2008
    The fax is sent from a Ricoh MP1600 to the HPLJ 3150.
    We have no problems with sending from the Ricoh to any other fax. The person with the 3150 says he has no problems receiving from any other fax machine. The HPLJ 3150 is printing the black page with the error indications.
    I had the person on the other end (The 3150) send me a fax. I receive it correctly. I then tried to send it back to him and he got a blank page again
  • B Joan Rapier
    B Joan Rapier May 11, 2010
    Hello Irmatwork
    Just to clarify a bit here;
    (01) You say this occurs when you send a fax **TO** the HPLJ3150. Do you mean **FROM** the 3150 to another recipient on a different machine?
    (02) Or is the recipient who is getting blank faxes the one w/ the HPLJ3150?
    (03) If that is the case, what fax machine are you using?
    (04) On which fax machine are the logs showing errors?
    Please, post back here w/ answers to these questions for clarification and we'll be happy to assist you w/ this issue.
    Thank you
    BJ @:)
    Sergeant:
  • 202 Answers
(05) Would you, please, SEND a fax from the machine that blank faxes are being received from to a different recipient on a different fax machine all together, please?
This will enable us to pin down which machine is really experiencing the issue.
Thank you
BJ @:)
Posted on Apr 17, 2008
  • B Joan Rapier
    B Joan Rapier Apr 18, 2008
    Hello Irma,
    Thank you for answering my questions for me. That's very helpful in clarifying the problem.
    This problem you're describing is intriguing. (Though frustrating, I'm sure, for you and the person on the other end of your faxing).
    This is truly a puzzle. If BOTH ends of the faxing are experiencing no issues w/ sending or w/ receiving faxes to or from anyone else - then that's a real puzzler. One of them HAS to be the one w/ the issue.
    We need to test this more scientifically in order to determine the "problem machine".
    PLEASE, PERFORM THE FOLLOWING TESTS; CAREFULLY RECORD THE RESULTS AND POST THEM BACK HERE:
    Each of you (the Ricoh MP1600 and the HPLJ3150), ...:
    Find a *minimum* of (2) (preferably (3)) different people (each using separate fax machines) w/ whom you can send and receive test faxes to and from.
    The two of you (the Ricoh and the HPLJ) MUST perform these tests w/ the SAME people (using the SAME fax machines) on either end.
    Record your results along w/ the manufacturer and model numbers of each fax machine involved.
    This is the only way to properly test - the two of you must be testing under the SAME conditions w/ respect to the machines your respective fax machines are sending and receiving faxes to and from.
    I look forward to seeing the results of your tests. :)
    Thank you
    BJ @:)
    Thank you
    BJ @:)
HP M1319F Stop Printing Fax Error Reports.
go to the fax repots,conformations,their u select send only.
Dec 02, 2011 | HEWLETT-PACKARD LaserJet M1319F All-In-One...
My faxes are being received as blank page, why?
make sure the faxes you send are face down in the feeder, if you can read what you are sending they will be sent blank
Aug 17, 2010 | Brother IntelliFax-2920 Fax
The faxes being sent from my hp 3150 all in one are receiving only one page and it only has a thick black line on top.
adjust the setting of your faxes machine just right the click the properties of the said printer fax the click it..
Mar 03, 2010 | HP LaserJet 3150 All-In-One Printer
Fax is sending blank page
Make a copy on the machine to be sure it is not a problem with your fax machine nor that the original is being sent upside down. It is very rare to be blank. Black faxes indicate a bad scanner assembly.
Dec 26, 2009 | Samsung SF-560 Plain Paper Laser Fax
Recipient is receiving blank pages when I send a fax
The back-light has gone in the CCD _vharge coupled device) - It would be cheaper to just replace it mate.
Jun 29, 2009 | HP LaserJet 3150 All-In-One Printer
Fax sent is received in blank
Here is a possiable problem you got the paper in the wroung way or your lamp is not working check both~)
Jun 22, 2009 | Samsung SF-340 Plain Paper Inkjet Fax
Pages aren't being sent properly
BUILD UP OF INK ON THE POLLERS AND SOME MACHINE HAVE WHERE YOU CAN SETUP INTERMITTING TIME DELAY INBETWEEN FAXING LETTING THE MACHINE COOL DOWN BETWEEN FAXING AND I HAVE ANOTHER PROGRAM THAT MAY HELP IN THIS MATTER CALL GREENPRINT WORLD.COM
ROD
Feb 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Receiver Errors on LaserJet 3150 all in one fax
Sounds like its a problem in the other end, if the machine can send and receviving faxes.
Check your phone lines from the wall to fax and ask the sender to do the same.
Nov 21, 2008 | HP LaserJet 3150 All-In-One Printer
Sending fax error message "low memory"
Try reading these:
General fax problems
Issue Cause Solution The document stops feeding in the middle of faxing. The maximum length of a page that can be loaded is 381 mm (15 inches). Faxing of a longer page stops at 381 mm (15 inches). If no jam exists and less than one minute has elapsed, wait a moment before press Cancel . If a jam exists, remove the media. If the item is too small, it can jam inside the automatic document feeder (ADF).
(HP LaserJet 3015 all-in-one) The minimum paper size for the ADF is 74 x 105 mm (2.9 x 4 inches).
(HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one) The minimum page size for the ADF is 127 x 127 mm (5 x 5 inches). If a jam exists, remove the media. The fax activity logs or fax call reports are printing at inappropriate times. The fax activity log or fax call reports settings are not correct. Print a configuration report and check when the reports print. Set the appropriate log or report printing times through the control panel or the HP Toolbox. The volume for sounds that the device emits is too loud or too soft. The volume setting needs to be adjusted. Set the appropriate sound volume settings through the control panel. Fax send troubleshooting Use the information in the following table to solve problems that might occur when sending faxes: Issue Cause Solution Faxes stop during sending. The fax machine to which the fax is being sent might be malfunctioning. Try sending to another fax machine. The telephone might not be working. Do one of the following:
  • Turn up the volume on the device, and then press Fax/Send on the control panel. If a dial tone is heard, the telephone line is working.
  • Disconnect the device from the jack in the wall, and then connect a telephone to the jack. Try to make a telephone call to make sure that the telephone line is working.
A communication error might be interrupting the fax job. Change the redial-on-communication-error setting to On.
See the electronic User Guide on the CD-ROM that shipped with the product. The device is receiving faxes but is not sending them. If the device is on a PBX system, the PBX system might be generating a dial tone that the device cannot detect. Disable the detect-dial-tone setting.
See the electronic User Guide on the CD-ROM that shipped with the product. A poor telephone connection might exist. Try again later. The fax machine to which the unit is sending to might be malfunctioning. Try sending to another fax machine. The telephone line might not be working. Do one of the following:
Outgoing fax calls continue to be dialed. The device automatically redials a fax number if the redial options are set to On. Press Cancel to stop the redials while the device is dialing.
To cancel a pending fax job, see "Canceling a fax job" in the electronic Users' Guide on the product CD-ROM.
See "Changing the redial settings" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent are not arriving at the receiving fax machine. The receiving fax machine might be off or might have an error condition, such as being out of paper. Call the recipient to make sure that the fax machine is on and ready to receive faxes. The originals might be incorrectly loaded. Make sure that the original documents are correctly loaded into the automatic document feeder (ADF) input tray or flatbed scanner (not available with the HP LaserJet 3015 all-in-one). A fax might be in memory because it is waiting to redial a busy number, other jobs that are ahead of it are waiting to be sent, or the fax is set up for a delayed send. If a fax job is in memory for any of these reasons, an entry for the job appears in the fax log. Print a fax activity log and check the Status column for jobs that show a Pending designation. All of the numbers of a long fax number cannot be dialed. The maximum number of digits of characters that can be entered into a fax number is 50. Try manually dialing the fax number. Faxes that are sent include a block of gray shading at the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent have data missing from the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM.
Jul 16, 2008 | HP LaserJet 3030 All-In-One Printer
Fax sent is sent blank
it seems to me as if the person you are sending the fax to has some problems in his fax machine tell him /her to get it tested or see whether the ink in their machine is suffiecient or not and do the same on yours as well,and also try to see are you entering the page into your machine right way? i think you will get your answer here easily
Feb 22, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP LaserJet 3150 All-In-One Printer Logo
839 people viewed this question
Ben Johnson
