Question about Motorola Mobility RAZR V3
The pins in the usb charge port for my Razor phone are bent -- can they be fixed
    Sergeant:
  • 129 Answers
Hi :) i sure they an fix your pro,juz sent to mobile shop or phone repair shop. good luck :)
Posted on Jul 04, 2010
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
Razor Phone wouldn't charge...battery dead, so I replace with new battery. It still will not indicate that battery is charging. I tried several outlets to plug in charger. Still no charging. Phone...
Sounds like you may have a connection problem where the charging cable plugs into the phone. Not much can be done except to get a new phone. Those micro USB/USB style connections last a long time, but once a pin is bent up it is game over. Sorry!
Mar 03, 2011 | Motorola Mobility RAZR V3
My blackberry 8330 will not cut on....for a second it was displaying a red light...i took the battery out and put it back in and now theres nothing
Look in the charging port (on the phone) and see if all of the pins are intact. You should see a total of 5 gold pins. If one of them is broken or bent, then the port may need replaced. Also check the moisture indicator in the battery compartment. If it is red then the phone may have water damage and will have to be opened cleaned and components tested.
Dec 04, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Reverse Voltage, dead USB port
First take a look at the usb port. Can you see 5 gold pins that are raised a bit as they move back? Sometimes 1 pin will get bent a bit and doesn't make good contact, causes this problem.
Oct 14, 2009 | Samsung I7500 Smartphone
My Blackberry Wont charge?!
look at the 6 pins on the phones charge port and see if one is higher than the others (usually on the end). if the pins is too far up the lower half doesnt connect to the charger. If your usb port will charge on via usb "DOCK" then more than likely the charger itself (which is way more simple to fix)
1.) if one of the pins on the phones charge port is pushed up, grab a sewing needle and GENTLY push the pin back into place,
2.) if the charging dock is working and is a usb charger like your wall charger, buy a new wall charger at your local electronics store.
hope this helps!
Jun 12, 2009 | RIM BlackBerry Pearl 8100
"Unauthorized Charger"
you can try to clean the charger port (but first make sure its not bent, or broken - the pins are really tiny and hard to see, so make sure)
But try cleaning the charge port on the phone and the charger with denatured (rubbing) alcohol, and a toothbrush -
Just make sure not to plug it in when you do this!
and clean both the charger and phone, make sure neither are bent
lastly, try a new charger!
NGK
Dec 22, 2008 | Motorola Mobility RAZR V3
Can't charge my i mate kjam
I recent4ly busted my mini-usb port and the phone could no longer take a charge or sync. I took a high res photo of the port and realized one of the pins was bent. I posted all about it with screenshots on what it looked like broken and fixed.
http://forum.xda-developers.com/showthread.php?t=412098&goto=newpost
Jul 01, 2008 | i-mate K-jam Smartphone
Controller port usb pins are bent
is it in the warrinty / do they cover it
Oct 20, 2007 | Microsoft Xbox 360 Console
Above the Date and time it says -Car Kit- I do not have a Car kit and I can not make any calls I just now banged the connector end against my desk and I think that fixed it. Why would my phone do...
YOWZA .. Car kit means the pins in the charging port are either liquid damaged or bent and touching eachother.
with a tooth brush and some NON Corrosive cleaning spray .. try cleaning out the port ... Canned air wouldn't be a bad idea either.
If the damage isn't bad you can usually take the phone out of car kit, but if liquid has corroded the board then im afraid it's time for a new phone.
Aug 22, 2007 | LG VX3300 Cellular Phone
Razor phone don't charge
you may have some junk in the connectors of your phone pluggin or the charger clean it with an eraser the square kind, see if the pins are bent other wise you may not have the right charger or a bad one and you should probably get a new one.
Mar 20, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
57 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
